Question about Brother MFC 420CN All-In-One InkJet Printer
Red Menace I have a Brother MFC-420N, and it keeps telling me that my magenta is low despite the fact that I have already replaced the cartridge. Despite being new, the printer won't print magenta.
  • Jerzydeb Sep 08, 2008
    Same problem here - I've cleaned my printheads dozens of times - still nothing. Hoping someone has a solution (other than buying a new printer LOL)
    Problem Solver:
  • 9 Answers
Try unplugging the printer for about ten to fifteen seconds; then replug.
This may clear the printer's memory about the low magenta. I had a similar thing with yellow, and when I replugged it stopped complaining about the yellow and told me that my cyan was out, and magenta low. I replaced the cyan, and voila! I can print!
Posted on Jun 05, 2009
Printer will acknowledge only 3 of 4 new ink cartridges - keeps saying change LC51M
doesn't LC51M refer to Magenta(red) not Cyan(blue). on my J435W the colors goes as follows: BK Y C M LC71 Series cartridges. Maybe you have them switched around? just a thought.
Sep 17, 2012 | Brother MFC-5460CN InkJet Printer
Brother MFC-5440CN wont feed 2 colors of ink, Yellow and Magenta and also says
This may be due to the fact that you have not removed correctly the small label that seals the air input to the cartridge. Normally on brother cartridges it's on the back or on the top of the colored label. Please check that. If no air is allowed in then your ink will not be provided thus generating your problem.
Oct 27, 2011 | Brother MultiFunction Center MFC-440CN...
I cannot get the mfc-240c to print any red color (magenta)
A: run the cleaning routine
B: Replace the red cartridge
C: remove red cart. clean contacts, replace red cart.
Oct 19, 2009 | Brother Multi-Function Center MFC-240C...
Brother mfc-240c
The digital display on the printer will tell you which color is low and when it needs to be replaced, either black, magenta, cyan, or yellow.
Oct 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother 215c printer no red when print out. please help ?
HI,
did you check the ink cartridge of your printer maybe the Red or magenta color is already finish.
thanks,
Apr 26, 2009 | Brother MFC-215C All-In-One InkJet Printer
Brother mfc-410cn colour cartridge problem
There may be three problems here.
1.Not doubting your skills for one minute, nor wishing to offend you in any way, but did you remove the protection strip off of the Magenta ink cartridge? Sometimes we forget to do that.
2.Once a new ink catridge is installed, it's best to go to the Brother diagnostic tools section, and run a test. Sometimes an error code is kept, (Ink cartridge is empty), and the diagnostic tool checks this out. It then clears the error code, and 'recognizes' the new ink cartridge.
3.Ink may have dried, for the tiny little holes for the magenta ink cartridge, where it attaches to the body of the printer. Just this one ink cartridge. Suggest you don a pair of rubber dishwashing gloves. MFC-410cn -> Unplugged <- from the surge protector, use a clean, lint free, warm water, damp cloth, and wipe the holes for the ink cartridge, where it lines up with the printer body. This will be where you see that copper metal strip. (Or perhaps it's brass)
To clarify, you are cleaning the printer body. The area where the ink cartridge goes, and the metal strip. The ink passes from the ink cartridge, and goes through holes in the body of the printer. The metal strip is where these holes are located. Allow this area to dry. You may want to use a hair dryer set on low heat to speed the drying process up. Constantly move the hair dryer back and forth. Keep it about a finger length away.
Once you are satisfied this are is dry, reinsert the magenta ink cartridge. Plug the printer back into power. Advise waiting one minute, then turn the printer on.
Use the Brother diagnostic tool.
Should you not be able to find the Brother diagnostic tool, I suggest you go to Start>Hover your mouse cursor on All Programs>Go over to Brother>MFC-410cn>and to the Help section. The Help section, will tell you how to open the diagnostic tool.
Aug 19, 2008 | Brother MFC-410CN All-In-One InkJet...
How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Jul 04, 2008 | Brother MFC 420CN All-In-One InkJet...
Mfc 3249c
Ensure that you are replacing the cartridge with a Brother LC41M ("M" denotes magenta) cartridge instead of replacing it with a "knockoff" (third-party equivalent) or refilling the cartridge. Some third-party inks -- found in many knockoffs and ink refill kits -- do not work well with their intended cartridges and/or print heads. I discovered this the hard way, and then verified it with representatives of HP, Canon and EPSON.
If you have tried two or more actual LC41M cartridges and still receive the Near Empty error message, your unit might need service. Contact Brother Customer Service for further troubleshooting -- see page i of the Users Manual. (Opening the Users Manual with this link requires a PDF viewer such as Acrobat Reader or Foxit Reader.)
Feb 29, 2008 | Brother MFC-3240C All-In-One InkJet...
Keeps saying to replace cartidge
you have to go int the ink leval thing i think and tell it you installed a new ink cartrige that should fix it
Dec 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-420N : Color Problems
You need to start the ink cartridge changing procedure over. Try unplugging the machine for a few minutes.(from the wall and the computer) Then try the ink change over...If that doesn't work don't waste time. Download and install the latest drivers for your printer. Uninstall then reinstall with newer drivers. Let me know what happens. Good Luck, Tim
Feb 19, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
103 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
