Question about Food Mixers
Kitchenaid stand mixer automatic safety shut-off
Is there a way to adjust or install an automatic shut-off for this mixer? I tend to break gears, shafts and gear covers when the mixer gets bound up under a heavy load, if it would shut off it would save parts. Thanks for your help.
SOURCE: I have a Kitchenaid Professional
hi
there is a ring clamp on top of the main worm follower gear on the drive shaft. you might not see it due to the grease.
you need to get one of those weird little pliers with points on them to spread the ring clamp to remove it. Then the gear is just friction fit on the shaft...it's pretty tight. I carefully used a screwdriver to slowly separate the main follower gear from the lower gear and it goes up the shaft....
after a bit you can wiggle the follower gear by hand and it will come up. Then you can see there is a pin holding the drive gear underneath it in place. The pin in my mixer was actually bent (must have been some tough dough).
then you reverse the process to put the gear back on -- except that the top follower gear has to go on the pin in the right orientation or the ring clamp won't fit.
buy your parts from mendingshed.com
hope it helps.
Posted on Aug 25, 2008
  • 118 Answers
SOURCE: Repair manual for a KitchenAid K45SS stand mixer
You should be able to look up your manuals HERE
Posted on Nov 30, 2008
ricardok45
  • 135 Answers
SOURCE: Kitchenaid stand mixer oil leak
Hi. The grease that your mixers are lubricated with has reached a stage where the oil is leaching away from the grease. All your machines need this grease changed. Shell Darina EP-2 or Chevron FM ALC EP-2. These machines need to be internally cleaned and re-greased. It's important to remove the oil from any place that it drips. The planetary gear must be removed, cleaned and re-greased also. It's a messy job, but you can do it yourself if you're familiar enough with machinery. If not, then a suitable service outlet can easily do it.
If you choose to do it, go to the Kitchenaid website and locate the parts files for your particular model, these drawings will assist greatly with the project. If you can, take digital photos at every step of dis-assembly as a reference for re-assembly. If this solution assists you, please rate it. Good luck! ricardok45
Posted on Mar 06, 2009
ricardok45
  • 135 Answers
SOURCE: Need Kitchenaid k45ss manual
Hi. All of you should goto www.kitchenaid.com and enter your model# into the search window. You can download Operators and Parts manuals for your model. Kitchenaid does not provide Service Manuals but the parts drawings will be very helpful with disassembly and reassembly.
If this solution has assisted you, please rate. ricardok45
Posted on Mar 22, 2009
hslincoln
  • 235 Answers
SOURCE: KitchenAid Mixer is not rotating.
Hi MANILYNTHEOB. I’m sorry to hear about your mixer not working. Unfortunately from the symptoms you describe, your mixer has experienced a transmission failure. You don’t mention how old your KA mixer is or how hard it’s been used, but for your particular model, KA has a plastic gear designed to fail, instead of the whole mixer ‘going up in smoke’. And what it sounds like is that this fail-safe gear finally ‘failed’ (stripped) so that the power from your electric motor is not getting to your planetary (“elliptical rotating part”) and the agitator shaft. What can you do?
The good news is that this can be fixed quite easily (OK, maybe a little effort) by yourself, if you are a DITY type person, feel adventurous, and your mixer is not under warranty you can troubleshoot it yourself. Be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> then enter the visitor type “Consumer” and then enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 4 & 5, titled: Case, Gearing And Planetary Unit for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 58, Worm Gear Bracket & Gear, including Illus. No. 12, Worm Gear (23 teeth). I suspect this is the weak link in your mixers transmission and causing the problems. After clearing all the grease away, you’lll probably find that is has been stripped.
You can order a replacement gear and install it yourself. While you’ve got your mixer this far apart you can check for any other unseemly wear and tear on the on the gears and other components. Besides a replacement gear, and grease you might consider replacing the gasket, too. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as this should be filled with debris from the stripped gear.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. Good luck, I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Jul 09, 2010
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
How to replace motor in kitchenaid artisan mixer
Sounds like a worm gear problem to me, it's impossible for the motor (armature) to move far enough to not drive the gear. There are driving pins in the system from fuse gear to paddle.
1) in the fuse gear
2) inside gearbox above planetary joining shaft to bevel gear
3) through planetary and shaft
There is also one joining the little gear inside the planetary to the shaft, doubt you'd break that one though.
Jun 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
How do i change the brushes in my kitchenaid mixer?
Solution for these KitchenAid Stand Mixer Models
  • KitchenAid Stand Mixer Service Manual - K45SS
  • KitchenAid Stand Mixer Service Manual - K5SS
  • KitchenAid Stand Mixer Service Manual - KP50P
  • KitchenAid Stand Mixer Service Manual - KSM50P
  • KitchenAid Stand Mixer Service Manual - KPM5
  • KitchenAid Stand Mixer Service Manual - KPM50
  • KitchenAid Stand Mixer Service Manual - KSM75
  • KitchenAid Stand Mixer Service Manual - KSM90
  • KitchenAid Stand Mixer Service Manual - KSM103
  • KitchenAid Stand Mixer Service Manual - KSM110
  • KitchenAid Stand Mixer Service Manual - KSM150
  • KitchenAid Stand Mixer Service Manual - KSM151
  • KitchenAid Stand Mixer Service Manual - KSM156
  • KitchenAid Stand Mixer Service Manual - KSMC50
Fix KitchenAid Stand Mixer Workshop Service Repair Manual Download
Jun 18, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Do th gears in a kitchenaid mixer need oil
Hi SHIRLAFINK, you do not need to 'oil' the transmission gears on a KA mixer. Your KA mixer comes with enough grease to 'last a lifetime' - whatever that means?
Depending on the age of your mixer and how heavily you use it, there may be a time when you might want to replace the grease, but that period is usually measured in years of useage.
Of course if one of the gears strips or breaks, you will need to replace all the grease when you replace the broken gear. Attempting to use salvaged grease jeopardized the remaining gears if pieces of metal or plastic debris are suspended in the old grease.
I hope this helps - hslincoln, Burke, VA
If this solution has been helpful, please rate it, thanks! hslincoln
Mar 14, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Professional 600 - makes loud noise when mixing,often stops as it blends 8 cups of bread flour and "needs a break", flat beater seems to get caught on bottom of bowl - this mixer is 1 yr. old!!
Several things:
The Professional 600 has a metal gear housing with a metal gearing. Because of this, the Professional 600 will generally run louder than other stand mixers that may have a nylon/metal mesh gearing.
How long is the bread dough being mixed for? Kitchenaid stand mixers must be used on speed 2 for bread doughs, using the spiral shaped dough hook, and mixing for no longer than 7 minutes.
If the flat beater is getting caught on the bottom of the bowl, pleasure assure the bowl is being seated correctly. You will place the bowl on the mixer arms on the left and right hand side. You will also want to take your fingers along the back of the bowl, where it butts up against the base of the mixer, and press downward. You will hear an audible click as the bowl falls into a spring latch and allows the bowl to sit flush and secure. If this is not being done, the flat beater may strike the bottom of the bowl.
If this was not the cause of the problem, please consult your Use and Care Guide about the beater to bowl adjustment. This is an easy adjustment made with a flat head screwdriver that can quickly correct the problem of a flat beater hitting the bottom of the bowl.
Jun 24, 2009 | KitchenAid Food Mixers
KitchenAid wobbles when mixing
The "wobbling" sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Also, leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Dec 24, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid Artisan 10 speed 325Watt Mixer
Hi, The KitchenAid mixers are usually quite easy to work on if you are competent at DIY. It sounds like a gearbox fault. Gearbox parts are easy obtained for most of the models and are easy to repair.
This is a service manual for a lot of the KitchenAid mixers. Might give you an idea on how difficult it is to work on before taking the plunge.
Hope this helps
Oct 30, 2008 | KitchenAid KSM150PS Artisan Series Stand...
The motor runs but the beater doesn't turn, as though the gear drive has failed. How do I take the mixer apart to check the gear drive?
http://www.fixya.com/support/t636606-kitchenaid_ksm90_stand_mixer
Kitchenaid service manuel gives step-by-step instruction on a stand mixer.
Sep 07, 2008 | KitchenAid K45SS Classic Stand Mixer
Mixer speed switch is haunted
Here is where you can download the repair manual. Read the section on speed control adjustments and repair. This might not be difficult for someone who is mechanixcally and electrically knowledgible.
Mike H.
Feb 07, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Food Mixers Logo
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
