Question about RCA D52W19 52" Rear Projection Television
It turns on for 8 secs then powers off no noise
I have 2004 model 52w19 rca ican turn it on with remote it will power up for 8 seconds then power down in about 3 minutes the remote will power it up again with same results any idea? thanks in advance
  • 2 more comments
  • kc5cym Sep 22, 2008
    where is these Bad capacitors located?
  • alycat_38 Sep 24, 2008
    could you help with the location of them thanks
    where can i order the board? what is the web site thanks in advance
  • Klfevans03 Oct 04, 2008
    I have the same issue. I hit power then hear two clicks. The Tv then turns off ? Help
  • RCA Master
  • 5,138 Answers
Bad capacitors! 3 of them 220uf 16v/ 220uf 35voltsx2
Posted on Sep 10, 2008
  • ladywinn
    ladywinn Sep 24, 2008
    Located on deflection board cp150,other 2 capacitors in same area Look for the Green&Gold capacitors. you can order new board for 77.99 and SSB board is 252.04 MCM wants 325.00 plus shipping.SSB board is the one with tuner and AUX jacks.It also can cause no power.Another thing to check is second ribbon conntector on deflection board, these sets have several different problems even conntector plug ins.
  • ladywinn
    ladywinn Sep 25, 2008
    Union Electronics Distributor.
How do I program my rca universal remote model number rcr350?
These are the general proceeding for RCA remote controls set-up:
1. Manually turn on the device you
want to control.
2. Find your device's brand in the
Brand Code list section of the
accompanying code list. Circle
the number for your brand and
keep the list handy.
3. Press and hold the device key you want to program. The
POWER key illuminates.
While you're holding down the device key, use your other
hand to press and hold the remote's POWER key at the
same time. The POWER key turns off.
4. Wait until the POWER key comes on
and stays on. Then release both keys
5. Look at the numbers you circled for
your device's brand code number.
Press those numbers on the remote
keypad.
Note: For single-digit brand codes,
press the 0 key first (for example, 0-5
for 5).
6. Point the remote directly at the
front panel of the device you want
to control. Press POWER on the
remote and wait 2 seconds. The
remote is testing a single code for
your device's brand.
Aug 01, 2012 | RCA RCR350 Remote Control
Had a power surge and tv blew. hooked ps3 to another t.v. and Ican,t get video
Press and hold down the power button for 5 sec .
You should here it beep twice . This will restore
your standered video out. (The red white and yellow rca plugs)
will now be active.
Rob
Jan 18, 2011 | Sony Playstation 3 (PS3) Console
How can I re active the wireless remote control system ?
sit in car all doors closed put key in ignition and turn from OFF to ACC 3 times as fast as you can leaving it in ACC on the last cycle then press your remote button. your blinkers should flash to tell you this has worked.... may take you a couple of tries to get it!!
Jun 30, 2009 | 2002 Toyota Camry Solara
FPA Lock
press and hold the power button on the remote for 8 sec
set should come on.
regards,
daniel
Jan 09, 2009 | RCA 14F512T 14" TV
Powers on then 8 secs later powers off
Bad capacitor 2200uf 16 volt and two 220uf 35 volts .Green and Gold writing on capacitors.these are on the Deflection board that has the Flyback transfomer on it.
Sep 05, 2008 | RCA D52W19 52" Rear Projection Television
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
76 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
