Question about Toshiba 27AX61 TV
Toshiba 27ax61 television chassis tma509b power led flashes
Power led flashes and relay clicks, problems in deguass circuit, any help appreciated
  • Anonymous Dec 22, 2008
    I have checked the power supply- all voltages are correct, the set still wont turn on, the relay keeps clicking - i am getting pulses of hv
I am working on one with the same symptoms after doing a lot of checking.I connected it to an isolation transformer and stepped the voltage down and noticed a ticking sound coming from the flyback.You may have the same problem.The bad thing is i can't find that flyback as it is no longer available.Sounds like they may have had issues with the flybacks on these models.
Posted on Jan 29, 2010
TV was working fine. Now it does not start. It makes a clicking sound as if its trying to start. It did this one day and after a few minutes it started. Next day same problem except it failed to start just made the clicking sound. Also it does not shut off to stop the clicking unless you pull the plug.
Posted on Jan 06, 2010
    President:
  • 3,130 Answers
I dont think your problems in the degussing my friend. Sounds like the sets doing whats its supose to when theres a power supply overload??? we really need more info on this one please.
Posted on Mar 24, 2006
Sony KV-24fs100 -Blinking front panel LEDS when attempting power up
count the number of RED blinks..You should have a pause inbetween counts.then count starts from 1..let me know
Dec 26, 2007 | Sony KV-32FS10 32" TV
DEAD NO POWER LED FLASHES 4 TIMES NO RELAY CLICK
4 flashes usually indicates trouble in the vertical circuits. Replace the Vertical output IC and the bypass 220mf Cap. to insure reliability. I don`t know about not hearing the relay click, you may have just blown the power fuse or also may have to troubleshoot the the power supply. ------ Eagle2
Jul 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Relay clicks, but No sound, No picture.
Hello, just try this first.
Unplugged the unit the power outlet for about 60 sec.Then power it on again. If you have surge strip along the line. You should directly switch in on power outlet only. If this doesn't help.
As the relay is working you have power in standby mode. Check its supply voltages if its ok. Secondly you can check the the B+ supply it is in DC, If this is a crt type tv, check its horizontal output transistor, Check its flyback for short circuit. Capacitor near to it rated almost 800V, and deflection coil.
Just for input, hope it helps
Apr 19, 2009 | Daewoo Televison & Video
Toshiba TV32C50, chassis TAC9307, no start, but relay 'clicks'. No obvious electrolytic capacitor failure but power supply C801 (470 mfd, 200 V) replaced, no change.
Relay picking usually means the low voltage circuit is OK. You have a High voltage problem. Try changing the Horiz Out Transistor.
Mike
Apr 04, 2009 | Televison & Video
Toshiba 36HF71 has sound but no picture
Same problem with mine. Relays click, sound, no picture and a flashing power LED. I finally found a schematic online. I went through the high voltage circuits and found the power transistor 2SC5570 was shorted out. There is also a pico fuse in that area but my was not open. I replaced the transistor and prayed the flyback transformer was not shorted. It wasn't, I'm watching my old 36" right now. Not a bad fix (17.00) bucks. Wonder what a service tech would have charged ;)
Jan 02, 2009 | Toshiba 36HF71 36" TV
RCA Model 32V434T chassis ATC010A
for shure your fly back transformer is bad is a commom problem in this chassis
Mar 29, 2008 | Televison & Video
Toshiba TP61F80 Projection TV
Check power supply for open micro fuse{s}-- If the fuses for the convergence circuits B+ are open,replace convergence IC,s and fuse devices.Then perform re-alignment in servicer mode.test run.Don't forget--PVAT! solder any/all bad connections.
Sep 28, 2007 | Toshiba TP61F80 61 in. Rear Projection...
Flashing LED on front panel
The place is call wwww.servicemanuals.net ,you can get it download or a paper copy,for this set I dont know the price but it will give it to you when you put the model number.Check for shorted horizontal output and loose conections,sometimes intermitant conection damage this transistor.Be careful
Oct 04, 2006 | Toshiba 57H81 57" Rear Projection...
Toshiba 27AX61 TV Logo
150 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
