Question about Sharp LC-37D4U 37 in. LCD Television
No sound on TV
It acts like it wants to give me sound, it was intermitent for a day or two then fine, then we played an older VCR with great sound and the next day no sound, we moved and still no sound.
  • 16 Answers
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from circuitcity.partsearch.com for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please also refer to post # 373 at: avsforum.com/avs-vb/showthread.php?t=647174&page=13 for some ‘pics’ of the information detailed here.
My knowledge of how to solve this issue came primarily from finding the research efforts of ‘Aureius’ on the AVS forums, and particularly from his taking the time to post the solution publicly so that others might save time, money, and aggravation. I'm just passing along the information. Thanks Andy!
I also wanted to mention that a couple of other very pesky common problems with these series of Sharp TV's involving symptoms of random powering-off and/or powering-on, and 'function lock-ups' of various sorts are easily remedied through two firmware updates (Main CPU: PH1UU112, Monitor: MD1UA104). These are not available to end-users via the internet but it may be possible to get the files from an understanding factory-authorized repair tech. They are installed using an SD memory card (don't use the HC high capacity sort, use only those that are NOT HC) which is inserted into a special slot in the back of the machine. For those of the DIY persuasion, information about how to check whether your TV has old firmware in need of an upgrade is readily available through internet search.
Posted on Jun 18, 2009
My VCR won't interface properly with my TV. Any time I try to play a tape, all I get is a blue screen. I've tried using it with an older TV, and the tapes play fine. Any help is appreciated.
Make sure that the tv set's rf frequency is set to the same rf as the vcr. If both are identical then something is definitely wrong with the tv set since the vcr works fine with another set.
Jun 13, 2016 | Viore 32" LED LCD HDTV
I have a Mitsubishi HS-U448 VCR. It plays my VHS tapes fine, but I can't get a blue screen when I turn it on. When I press 'play', the movie looks great. Once I hit 'stop', it'
It sounds like it is set to a TV station and since all the analogue stations have now gone you will only get static. Without a remote you wan't be able to switch it. I suggest you either shop around for a replacement (try Curry's partmaster) or use a universal one.
Jan 16, 2013 | Mitsubishi HS-U448 VCR
I cannot get the Vcr/ Dvd to play
The TV needs to be on channel 3 not channel 3.1 because is a digital channel and the signal from the VCR is analog. Tune the TV to channel 3 to get the analog video from the VCR.
May 10, 2010 | Toshiba SD-V295
VCR plays 15 seconds, TV shuts off. Same without tape inserted
Sounds like a typical Switched Mode Power Supply fault, or an internal thermal fault that is shutting down the power supply, over & over. Really you need to get it serviced. You need to get a firm "Quote" for repair, remember these days repair can often exceed replacement cost.
Feb 03, 2010 | Televison & Video
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
NEW Samsung LEd TV does not recognized older Toshiba VCR in sourc
Hello callkaren2,
Electronics are so much fun arent they?
The TV does not need to recognize the VCR at all. All it is looking for is a plain Composite video signal from any device - VCR or DVD.
If you are just playing a tape and not using the VCR as a Tuner, then it doesnt matter if the VCR is on Chl 3 or 4.
Do this - play a tape, test the Yellow connector to a regular TV to verify the signal is coming down the cable. Then, try it again on another Video/Yellow input on your LED unit. Have a great day!
Cheers
Dec 28, 2009 | Toshiba M675 VHS VCR
Older TV works great alone including sound. Cable TV but no box. VCR connected with cables (red,white and yellow)to TV and has worked fine. Playing home recorded VCR tape picture OK but sound is low and...
Very likely the VCR audio head is dirty which will give you muffled or low sound on play. Remove the the top cover & using a piece of non-abrasive cleaning cloth & a head cleaning fluid gently rub the audio head to clean it. The audio stack sits to the right hand side of the deck, it is usually a siler block which will be placed in front of a black roller. The head is on the side of the stack facing toward you, give this area a wipe, try a fresh recording & then replay the new recording to see if the sound has improved.
Aug 16, 2009 | Memorex Televison & Video
DVD player not working properly
I have a DVD player, a VCR player, a TV set all hook into an RCA RT2250 Audio/Video receiver. Everything was working fine until 2 days ago. Now the DVD player gives me a great pix but no sound. The VCR,and TV are just fine and I have checked everything out, speaker connections, mute buttons, etc. and nothing seems to be wrong. I am thinking that some thing in the receiver got fried. Is it repairable?
Dec 13, 2008 | Electronics - Others
Tv has no sound
U CAN BUY A VCR FOR ABOUT 10 BUCKS, AND GET BOOK SELF STEREO SYSTEM THAT HAS A SET OF AUDIO INPUT JACKS, USE A PAIR OF RCA JACKS TO CONNECT THE AUDIO OUT FROM THE VCR TO THE AUDIO IN OF THE BOOK SELF STEREO SYSTEM. NOW U SHOULD HAVE SOUND
Jul 21, 2008 | Durabrand DWT1304 13" TV
Sharp LC-37D4U 37 in. LCD Television Logo
159 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
