Question about Maytag Kitchen Ranges
Adjusting air flow on gas kitchen stove burners?
    Genius:
  • 1,665 Answers
Proper air velocity over the burner is critical on a direct fired gas unit. If the air velocity is not within
specifications, the unit will not operate efficiently, can produce excess carbon monoxide (CO) or other gases, and may have sporadic shutdowns. Proper air velocity is determined by measuring the static pressure drop across the burner.
To measure the static pressure drop, the fan should be running and be discharging 70° air. Using an incline manometer or equivalent, insert one sensor into the entering air access opening (plugged test port) and the other on the downstream side, through the view port (see page 12 for locations). The proper static pressure reading should be from .625 in. to .675 in.
If this reading is higher or lower and the air quantity (cfm) delivered to the building is acceptable, then the burner baffles will need to be adjusted (see diagram).
Open the burner access door. Using a wrench loosen the 4 screws to adjust the baffles. To increase the static pressure loss, decrease the opening size and to decrease the loss, increase the opening size. The top and bottom baffles should be of equal distance from the burner. Tighten the baffle fasteners, replace the door, turn unit on, and recheck the loss. This process may need to be repeated
until the proper pressure reading is attained.
This adjustment will change the air quantity delivered by the unit and therefore should be rechecked.
Posted on Sep 05, 2008
WHEN LEFT FRONT BURNER IS ON SIMMER ITS FINE..WHEN PUT TO HIGH IT GOES FOR A FEW MINUTES THEN THERE IS A PUFF OF FLAME AND A BANG..WHAT COULD THAT MEAN ALL OTHER BURNERS WORK FINE
Hello, Bob -
I hope I am correct in understanding your question is in reference to a gas stove. If so . . .
The following information is from:
http://www.home-repair-central.com/gas-stove-troubleshooting-guide.html
Personal opinion: You need to have a gas stove repair person who is authorized to work on your make of gas stove inspect it and determine what repair is needed.
Jan 12, 2018 | Kitchen Ranges
Flames are mostly yellow, vent black soot
There is a flame adjust ring on each burner where the gas exits the inlet nozzle. Before adjusting these, be sure all other gas appliances are working ok (water heater, etc.) . If they are then focus on the pressure regulator on the stove itself. That is the part that the gas line from the wall connects to on the stove. It is most likely bad. If not then go back to each burner , loosen the screw that locks the adjustment ring, turn the burner on and move the ring back to allow more air to mix with the gas so the tips of the flame just turns from orange to blue. Tighten the screw and move to the next burner that needs adjustment.
Feb 02, 2016 | Kitchen Ranges
The gas flame on my 4 burner Chambers stove top is very high. How do I adjust it?
Now That the range operates like new, learn to use it. Don't die.
Jul 06, 2017 | Kitchen Ranges
Burner on the top of the stove does not light,doesn't seem to have gas flow
i have the same problem with mine but i was cleaning mine with mr muscle which got in the holes where the gass comes out. i havent found a fix yet. im just hoping it will dry out n start working again
Jul 05, 2012 | DCS RGS-486GL Stainless Steel Gas Kitchen...
Stoves sterling 1100DF hob burners will not ignite there is no spark to any burner. Gas flows as normal.
More than likely the spark module has malfunctioned and needs to be replaced.
Apr 23, 2012 | Stoves Kitchen Ranges
Installed stove, no flames on burners?
It may still have air in the system, turn on one burner on and allow the gas to flow with a lighter in the path of the gas see if the gas lights of at least explodes I mean until it goes Poof, once it does that if it does not light then pull the top off the stove and adjust the vents on the pipes to focus the flames and how much air is blended in with the gas, also turn the burner so that the holes are half way open, I am not sue about your stove but most have an adjustment by turning the burner 1/4 of a turn to change the flame characteristics. if this does not help post here and I will see what else I can find out on your stove. I need the modle of the stove and the regulator number where the gas hooks up.
Jul 23, 2009 | Kitchen Ranges
Jenn-Air JGR8855BDS Gas to propane conversion
propane is higher pressure than natural gas, there should be some orifices on the stove for the top burners, some have them near the top in a metal clip, some have them in a lower location, usually you can see them from the back of the stove. the oven and broiler may only need "tightened down", and the air blend will probably need adjusting for "flame color", you don't want yellow flame tips, good luck!
Jul 18, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
700 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
