Question about Maytag Performa PAV2200
Maytag > Performa > Drains,Rotates, Fills but wont spin
Ok so last night it was working fine.
This morning i put in a load and when it was done i went to change it,every thing looked normal. Until i pulled the clothes out and they weresoaking wet...
Heres where I am at..
Does it fill up? YES
Does it agitate? YES
Does it Drain ? YES
There is a humming sound, like normal,
as if its trying to spin but does nothing. If you were standing here now i would say "you can feel the motor kicking in but going nowhere..."
When you put it on spin and push the "close hood" button it turns about 1/inch if that.
to give you a good idea think of a truck being put in the wrong gear. how it lurches forward? thats about it...
I dont know where to start looking to fix this.. Iv Tryed EVERY Cycle and the same thing, Fills, Agitates, Drains... but no spin..
  • scrfire Sep 08, 2008
    EXACT SAME PROBLEM,no spin movement ...
I had the same problem with you a couple days ago. I disassambled the whole machine and i found out that the belt worn out and the motor also losen so i am looking for parts to replace.
Posted on Sep 09, 2008
Our Maytag PAV2300AWW Performa top load washer fills with water fine, draisn fine, spins fine, but after filling with water (even on "Mini" size load) it begins to agitate and then quits completely and...
If it was the bearing it should be leaking water out the bottom! It is more than likely the water pump. The seal in the pump drops down and then makes noise. The pump should be in rear. tilt machine back remove belt then try turning the pump by hand if tight replace.
List price is about $89.99 you can find it on Ebay cheaper
Jul 05, 2014 | Maytag PAV2300 Top Load Washer
Model 23832100
Sounds like clutch not catching,this may need to bed in .The fact it works okay with no load and no spin with load sounds like clutch/ but also could be motor torque.Ask repair man to recheck work done.
Jan 14, 2014 | Kenmore 24032\24036 Top Load Washer
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
My Performa dryer stopped working.
Unplug the dryer.
Replace the thermal fuse and high limit switch located at the heater element.
The parts come as a set.
Raise the top lid of the dryer. The parts are at the back left side.
Mar 10, 2009 | Maytag Performa PAV2200
Fills but does not wash
Hi!
That happens when for some reason any of the two drain/spin cycles are interrupted. Try this:
have the washer empty, then set the machine to run the last cycle to the end of it, when you usually
lift the cover to take out the clothes, that ought to do it, I had the same problem when diagnosing a
timer problem.
Nov 09, 2008 | Maytag Performa PAV2200
Maytag Performa Washer spins fine but stops instantly
Check the unit next time it is in the spin open the lid up does it do the same thing?? if so it is working ok that is the Brake in the unit doing it Job but if it is really loud it maybe going out??
Jan 26, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
254 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
