Question about Emerson MS3105 CD Shelf System
CD's NOT PLAYING
My cd's have suddeendly stopped playing. at first they would just spin forever and it would say "no disc". now they don't even spin. can someone please help me?
  • randym60 Jul 27, 2008
    Yes I bought a 3 disc player for my wife and it worked great for about 3 months and then the disc would just spin and not play. Now all it does is show on the display TOC READ...Is this a chip failure??? I thought that Emerson made a much better product than this.......Does anyone have a solution???
  • rchin2005 Aug 12, 2008
    The Emerson MS3105 is not a good product. Yes, i have encounered the same 'NO DISK' prompts (usually preceded by disk not spinning at all). I'm very disappointed, since this is a nice looking set.
  • 513 Answers
How often was the player used? Four years is a typical lifespan of a cheap CD player section if it sees constant use, and on this specific model i ran across a few cases in which the system died after a few months, and it makes you wonder why the warranty is only for 90 days(the ones i saw)... First, let's see if the player tries to read the disc. Load a disc and listen. Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable. Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word. This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces. You could try to clean the optics. It would involve taking the cover off and finding a way to take a slightly damped swab and gently rub the objective lens on the pickup clean, followed by a drying with the dry side. But, unless the player is prone to dust accumulation (which was a big problem with quite a few Aiwa shelf systems with the 3 disc changers), cleaning it may not help. Another possibility could be that the transmission ribbon which connects the pickup to the player electronics may have developed breaks, which is another typical problem with many shelf systems. Yet another possibility, which is the worst case: the pickup may have worn out. Again, if the player is four years old and was used constantly, it is very possible that the pickup has decided to give up the ghost. Another possibility, which is EXTREME worst case and is not likely to happen at any time with any CD player is a failure of the CD decoder chip. The decoder chip handles the 8-14 demodulation and error correction of the CD signal and outputs the processed signal as PCM for upsampling and conversion. If this chip fails, the CD player will spin up and synch to the disc but, without decoding, the player will be unable to read the TOC and play the disc. But, as I said before, this usually never happens as the semiconductor parts are the most reliable components in a CD player and usually never fail unless they were deliberately damaged by an external influence, like shorting out one or more leads with a screwdriver while the player is powered. In the latter three events, replacement parts may not be easily sourced, if at all, and the required labor to effect the repair may not be worth it. (In addition, a new pickup has a protective solder short designed to protect the laser pickup from static discharge damage. This short has to be desoldered in order to allow the pickup to function.) In this case, replacement of the entire shelf system becomes necessary. If buying a new shelf system, stick with some of the better brands in this area like JVC, Sony, Panasonic, Aiwa, Pioneer, and even Philips. Brands to avoid include Sharp, Sanyo/Fisher, RCA, Emerson, and any cheap store brands like Durabrand or CurtisMathes. But, in general, even the finest shelf systems are a compromise in design which can affect reliability. Most, even from the recommended brands, weren't designed to be serviced very easily when they break as people usually dispose of them rather than have them repaired.
Posted on Jan 23, 2006
Old Sony CD Walkman plays Disc for a bit then stops Spinning still playing Music then starts Spinning again continuous playing of Music is this Normal . can see all this through top of lid
Yes, this would be normal. It spins the disk and fills an internal "buffer", which then plays until it is ready to fill the buffer again. This improves resistance to being moved around while playing.
Jul 21, 2018 | Sony Audio Players & Recorders
Why did CD model-1493 player stopped working;since all other functions work fine?
It spins out of control when it can't read the disc.
Dirty or faulty laser
Sep 15, 2014 | Audio Players & Recorders
Hi guys my technics sl-eh770 has started to skip and this can become very anoying. what would be a fix or do i have to get a new 1
if this is happening on all cds then it would indicate that your lens maybe dirty.
you can by cd cleaners discs that go into machine like a regular disc but when they play they rub the lens clean.
you should only try this one time if it still is a problem there maybe some dust in there getting in the way. this would need to be opened to check.
I hope this was useful.
Jan 24, 2011 | Technics Audio Players & Recorders
My DCM-360 has stopped playing discs after my moving house. It spins the carousel, picks up the disc and then puts it down without spinning the disc up. Laser problem or disc-spinning-motor problem or...
Had a similar problem with my Denon. When I inserted CD it takes it in but immediately stops - like it doesnt sense the CD. Same problem with Single or Multi changer. Removed cover, removed reader ( 4 screws) and found lens had fallen out. Cleaned, reinstalled with touch of super glue on rim - works fine.
Oct 12, 2010 | Denon DCM-360 5-Disc CD Changer
CD takes too long to play or read
OEM cd players are set up to keep burned cds from playing well or at all. Some will work better if you use a better cd brand or quality cd.
May 29, 2010 | 1999 Honda Accord
One more Time CD Jukebox Skipping
The fault is one or the other unit unless you have some sort of physical drag on the CD. There is a problem playing copy CDs too. Some work some dont.
Jan 04, 2009 | Wurlitzer Jukebox 1015 One More Time...
Stopped playing...all DVD/CD
TRY CLEANING THE LENS WITH A SPECIAL CD LENS CLEANER.. YOU CAN BUY IT WALGREENS OR WALMART
Mar 07, 2008 | Mintek MDP-1020 Portable DVD Player
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Cd player gets "stuck"
Built up dirt particles like dust or smoke on the lense can cause this. Buy a cleaning kit with a disc that has brushes that you dab with a small amount of alcohol which spins in the CD player and cleans the lens.
Jan 14, 2007 | Yamaha CDC-765 5-Disc CD Changer
Emerson MS3105 CD Shelf System Logo
385 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
