Question about Brother IntelliFAX 4100 Laser Fax
Cant receive faxes
Hi i have a brother intelli fax 4100 and i can send faxes but i cant receive them, it rings and everything but when its ringing it says out of area. CAn you help?
  • dfriend1 Sep 08, 2008
    i dont even see a auto receive on there
  • 2,120 Answers
Set your fax machine for AUTO RECEIVE. Unplug power cord and plug back in.
Posted on Sep 06, 2008
The same thing just happend to me. Check all the buttons on the machine and make sure there isn't one that is stuck. My "Fax" button was jammed and I didn't even know it. As soon as I wiggled it loose everything started working again.
Mar 15, 2010 | Brother IntelliFAX 4100 Laser Fax
Fax not picking up Brother 4100
have you see the display if it was saying the word receiving...?
let me know..
Jun 26, 2008 | Brother IntelliFAX 4100 Laser Fax
I have a brother intelliFax 4100. I cannot receive fax.
While it is ringing press the START button. You are set to MANUAL RECEIVE
Feb 08, 2010 | Office Equipment & Supplies
I can send faxes but I cant receive them.
The first thing is to investigate if the fax machine is recognizing the ringing of the phone. Also make sure the fax machine is set to answer and the ringing is NOT intercepted by an answering machine also connected to the line. The fax machine must be online with paper, ink, etc. Your phones must all be hung up or the line will be busy..
Analyze these things first.
Sep 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother fax 4750e can not receive or send fax. sender said the line just ring and ring endlessly
To set up for receiving Fax, do the following:
Press Mode button repeatedly untin Fax and Fax/Tel lights are lit.
Faxes will automatically print and answering machine will take the calls. If you have a dedicated fax line, do the following:
Press Mode button repeatedly until just the FAX light is lit. Then the machine will answer every call as a fax.
Apr 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Our fax will not pickup incoming faxes
The mode is correct. You can check the rings to answer setting. Default is 4 rings. If your phone line is just for the fax try setting rings to 1. Sometimes sending fax machines go into redial before the 4th ring.
Also, sometimes unplugging the power for 10 seconds will clear any memory that may have locked up the machine.
Hope this helps.
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
After making my post, I went to the official Brothers website for the 4100 FAQs and "Operating Instructions." Here's what I found. Set your 4100 set to the "Fax/Tel" mode. Press "Menu", then the number 2 (Fax), then number 1(Set-up Receive), then number 1 again (Ring Delay). Use right arrow key to increase. Once increased, press the "Set" key. You'll see the message "Accepted." Now press the "Stop" key to exit "Menu." This will now give you up to 4 rings before the fax auto answers. Inorder to send a signal by phone to remote start the fax just follow the instructions I copied directly from Brothers instructions for the 4100: If you answer the call on an extension phone (this is any phone plug into a phone jack on the same line) and hear a beep every 3 seconds (automatic fax) or just silence (manual fax), press *51(remote activation code) on the telephone keypad, wait to hear the Brother machine turn on (chirping sounds) and then hang up. I don't have anyone that can send me a fax right now to test it out. I'll have to try it in the morning. Hope this works for you.
Feb 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Cant receive faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
352 people viewed this question
James Cagle
James Cagle
Jim Keysor
