Question about Nikon D70s Body Only Digital Camera
When I change lenses I get a 'fee' message
Any suggestions?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
There are several possible reasons for this.
A) The lens is what Nikon calls a non-CPU lens, lacking the electrical contacts for things like autofocus and aperture control. With such lenses, you must use the Manual (M) mode. You won't be able to use the camera's light meter, and you have to adjust the aperture by turning the ring on the lens.
B) The lens is a D-type lens, with an aperture ring. You have to turn the aperture ring to its minimum (largest F/number) and lock it.
C) The contacts are dirty or otherwise not engaging properly. Clean the contacts on the back of the lens and on the lens mount. Reattach the lens and jiggle it slightly to try to engage the contacts.
If none of the above apply, then the camera and/or the lens may need service.
Posted on Jan 05, 2010
When I am trying to take a picture and press the button to so, I see an "err" and a battery (the batteries are new) message that will not allow me to do so. I have tried taking the battery out...
On these cameras, if you're using ANY of the auto modes (P, A, S on the dial), the lense must be set to the lowest aperture setting (the highest number). Check to make sure this is the case. If it isn't, that's most likely your issue.
If you're using a non-CPU lense, this camera can only be used on M(anual) mode on your dial. If you haven't changed lenses this isn't likely an issue. If however you're using a new (to you) lense, this is a possibility.
According to the manual, the only other possibility is that your attached flash isn't set to the proper setting when using "P" mode. In this mode, the attached flash MUST be a Nikon dedicated flash unit set to TTL mode, otherwise fEE flashes with a little lightning bolt symbol. If you're not using a flash specifically designed for this model, remove it and try again. If you are, cycle the mode button on the flash until it reads "TTL" on the flash's LCD panel.
The manual makes no mention of fEE (error) and the battery indicator blinking, so these are the only things I can suggest with the information given.
Aug 19, 2011 | Nikon N75 35mm SLR Camera
What does FEE mean? The camera won't take a picture and I see that in the display of my Nikon N90S
FEE error message displayed on SLR camera LCD Description If the cameras LCD screen displays "FEE" in the area where the aperture is normally displayed, please ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens such as the Nikon AF or Nikkor P lenses. Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
The FEE error message
Set to F22, or the highest aperture number - normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experence the the error display FEE, please contact your local Nikon office. Before doing so please also check the following.
1157d.gif That the EE servo coupling highlighted above on the lenses has not been broken. That the F-min switch highlighted above on the camera body has not been broken. If either of the two items above are broken please contact your local Nikon service center.
Apr 19, 2011 | Nikon N90S 35mm SLR Camera
I have a Sigma 70-300mm lense which, when I attach it to my D300 gives me an error message of FEE. I was assured when I bought the lense that it would work. Am I doing something wrong?
You didn't specify which Sigma 70-300mm lens (Sigma has at least five different versions, and I'm not referring to the lens mount), but from the error message I assume the lens has an aperture ring. Turn the aperture ring to its smallest setting (largest f/number) and lock it in place. Control the aperture from the camera, the same way as on a lens without an aperture ring.
If the lens doesn't have an aperture ring, please reply to this post specifying the exact model of the lens. That's all of the numbers and letters around the 70-300mm, like AF, DGO, f/4.5, etc.
Feb 27, 2011 | Nikon D300 Body Only Digital Camera
I have just bought a 60mm micro lens. when i put the lens on my Nikon D50 the message FE3 appears on the screen. i have tried taking of the lense and putting it back on but the message still appears.
I hope you mean FEE.
Turn the aperture ring on the lens to its smallest setting (largest f/number). If the ring has a lock, lock it in place. You control the aperture from the camera body, just as you would on a lens with no aperture ring.
Dec 08, 2010 | Nikon Cameras
Error message FEE on aperture
Make sure the lens is mounted on the camer fully. Make sure the aperture ring is set for the largest numbe like 22 or 32 if the lens has it. Some lenses have a lock to lock the aperture ring on the largest number for you. Also make sure the lens you are using is compatible with the F65 camera. if the lens is older then it will not give you any electronic data and the camera will never give you the f information in the viewfinder.
Nov 19, 2009 | Nikon F65 35mm SLR Camera
Nikon D300 reading fEE
double check you have a good batteries double check you didnt hit the button to release the lense and check the focus it is not a large problem it is a warning errer just lookupp the manual online or call the supplier you bought it from
let me know if i helped please
May 27, 2009 | Nikon D40x Digital Camera
FEE message in display when using 50mm lense
The FEE message indicates that the lens is not set to smallest aperture (highest number). The camera body expects this so it will have full control of the aperture. It sounds like you may be accidentally bumping or turning the aperture ring on the lens while using it or changing lenses. There is a little slide lock to lock it at f/22 to prevent this. Turn the aperture ring to 22 and move the slider so the white dot is next to the orange mark on the lens barrel.
Feb 28, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
FEE display contant
defective focus lens circuitry, you need pro fix.
Sep 14, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D70s Body Only Digital Camera Logo
61 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
