Question about Tappan TGF363 Gas Kitchen Range
Too much heat - therm problem?
I set the temperature on my oven, but then everything cooks too fast because I think the oven temperature is not being regulated and just continues to get hotter as time goes on. Is it the temperature sensor that is broken? (I am assuming it's a sensor because it's a digital readout, otherwise they usually use bulbs). If so, where do I get the part and how do I fix it? I do not have the owner's manual. Thanks!
  • 108 Answers
Dear Leann
I hate to tell you this, but I think you are going to have to call a technician about this problem. There is no way to assess the electronics online. My suggestion is to call customer support and then a technician. Sorry
Posted on Nov 22, 2008
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
Why is my chocolate mud cake developing a hard crust whilst not cooking through. The fan oven is 140C. (gas 2 to 3) I am thinking of using the conventional oven.Would the oven shelf still need to be on...
  • Either the oven was not fully preheated before baking so it dried out a bit on the edges.
  • Or The temperature was just up to high and it baked to fast making it crisp on the outside yet not done on the inside.
  • Or there is to much batter in the pan and while the temperature is set proper there is to much batter to throughly cook.
Regards, Tony
May 05, 2011 | De Dietrich Ovens
My electrolux EOD 3360 bottom oven is getting too hot. The oven temperature light stays on even at the lowest setting or defrost setting. The inside of the oven is literally roasting hot, and anything I...
1 . If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
2 . If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
3. A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Mar 22, 2011 | Electrolux Ovens
Oven will not heat to desired temperature
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
Apr 20, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Oven does not cook at temperature set at. 2 hrs.
Could be the gasket is not sealing in the heat and you are experience heat loss through the door. Does it seal tightly? Can you feel heat coming around the door area? If so, replace the gasket
Nov 05, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Everything cooks to fast and usually burns, even though i set the oven at a lower than the recipe states
The temperature control needs to be replace to get it
back to its' original condition. E-mail back to me if otherwise.
Sep 24, 2009 | Ovens
Gets hot too quickly food cooks too quickly
no oven heats to what the dial says, all are to hot or to cold. try reducing the cooking temperature by 50 *, so instead of cooking a roast at 350, set at 300. i have never seen a stove that is heating to the temperature of the setting.
Jul 05, 2009 | Zanussi ZBF260 Electric Single Oven
Oven does not heat to proper temperature
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
Oct 02, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
Tappan TGF363 Gas Kitchen Range Logo
111 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
