Question about ATI ALL-IN-WONDER 9600 (128 MB) Graphic Card
Ati 9600 all in wonder- no sound when using tv componenet.
Ati 9600 all in wonder- all components work fine, including dvd, but there is no sound when using tv component.
  • liamknujrp May 11, 2010
    How does it connect to the audio input?
    Genius:
  • 1,027 Answers
The TV portion uses the audio input on the sound card in the PC.
Posted on Sep 05, 2008
I couldnt get the vedio capture driver of my tv tuner card of ati wonder would you be kind enough to send me the link for that
Go to site
http://support.amd.com/us/Pages/AMDSupportHub.aspx
on right side of webpage you have Download driver.
Select component as TV tuner, product line as all in wonder series ,select product model
and your OS.
Hope it will help you.
Thanks for using FixYa.
May 18, 2011 | ATI TV Wonder Video Capture
TV plays audio while on dvd, but when we switch it back to cable, there is no sound
If sound works with the DVD, it shows your TV is fine, there is just something wrong with the sound signal getting from your cable box to the TV.
There are a few options here. 1) If you are using a single coaxial cable to connect the TV to the cable box, you can either try another one, or try the 3 component cables. 2) If you are using the 3 component cables, you should have more than one input row to the TV... try an adjacent row 3) If that doesn't work for the 3 component cables, try a new set of component cables. 4) Check the sound settings on the cable box itself. Maybe resetting the cable box will get it to go through the initialization sequence to get the sound set up correctly
Oct 31, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Toshiba dvd when plugged to componet to tv picture balck and white... The picture is fine when plugged to composite or s-video... Component from sat box plugged to tv works fine too..
Sounds like either the cables you are using are bad or the component out on the dvd player is bad. Try using a different set of cables and make sure there are no loose connections on the dvd player
Aug 21, 2009 | Televison & Video
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
How to Hook up ATI 9600 to PC
Did you switch the TV input to S-Video on the TV control panel (usually accessible via the remote)? You will also likely need to fit a 1/8" (mini-headphone jack) connector from your PC to RCA (Red and White audio standard) connectors on the TV - this cable can be purchased in many places. The S-Video connector doesn't carry audio like an HDMI connector will.
Dec 16, 2008 | Abit AGP Video Cards: /ATI 9600XT 256M...
NO TV on All in wonder 2006 agp
Recently had a similar problem and solved it today!
The fix starts by first doing a "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers (observing WDM drivers).
You should have downloaded the most recent catalyst drivers from ati, and the most recent multimedia center completely (about 80+Mb) that are available for your card.
Also visit the previous versions of the catalyst drivers, the all-in-wonder 2006 seems to be only compatible with the WDM drivers up to ver.8.4 and download it "alone" (don't worry if the latest drivers include the WDM, you can write v.8.4 over it any time).
Now proceed with the "deep uninstall" following this directions, taken from somewhere on the internet, thanks to the one who wrote them...
1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI Multimedia software and/or the ATI DVD software.
2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.*
This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
5. Next...time to go to your Registry. Go to START -- RUN -- regedit
Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too. So if the ATI key is not found in the CurrentControlSet section, don't worry about it.
Once all keys are deleted, proceed to the next step.
6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean. Though you might want to even run a registry cleaner, like the one included in the freeware program CCLEANER, it's very good, can be undone and it's safe enough to use it almost blindly.
8. Close all windows and reboot.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are done. You may want to reinstall your ATI MMC software and DVD software if you use them. DONE!
ONCE YOU'VE DONE ALL THE INSTALLING OF THE LATEST CATALYST DRIVERS AND MULTIMEDIA CENTER (is a 4 part download, be sure to install the 4 parts "only the dvd codec is optional" and leave the MMC part to install at last) BE SURE TO INSTALL V.8.4 OF THE WDM DRIVERS (for the all-in-wonder 2006), OTHERWISE YOU'LL HAVE THE SAME BLACK SCREEN WHICH IS ALSO CALLED AN OVERLAY FAIL.
Restart and run your TV, it will work. Please check if your TV comes out at 240i resolution instead of 480i, you might need to disable the TV ON DEMAND feature of the tv program. This is done at the registry. Close the TV program and Run Regedit, then look at HKEY_CURRENT_USER\Software\ATI Technologies\Multimedia\Features\DTV\Channel Manager, the Key you need to change from 0 to 1 is the one called LiveMode. Close Regedit and restart. Start the TV program, and check, you should see the 480i resolution (at the top info bar), if not press ALT+3 and then ALT+2 and then ALT+1 (don't check any of the boxes in any of the questions), that should finally do it. Any problem? Just close TV program and do it all over again from the begining more carefully or trying some little variations in the ALT part.
All this solves many problems as with the TV program showing CORRUPT and BLACK or BLANK SCREENS with AUDIO which are also called OVERLAY FAILURES in many or maybe even all of the ALL IN WONDER (PCI Express or AGP) cards and even with the TV WONDER cards and USB adapters, the only difference between the cards might be the top WDM driver version you migh be able to use with an especific card. Please watch that you might need to try all the versions of the WDM available untill you find the one that works for you (the AIW2006 uses v.8.4, but for example the TV WONDER USB2.0 is able to use the latest available.)
Dec 04, 2008 | ATI ALL-IN-WONDER 2006 EDITION, (256 MB)...
Driver is not working
strange... even WinXP has got the drivers for that ATI AGP card.
Apr 07, 2008 | ATI ALL-IN-WONDER 9600, (128 MB) AGP...
Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Jun 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
No picture using component on Toshiba 32HL66
It may be a synch issue. Make sure your component input is set for the proper type of output. Your XBOX 360 is likely set to 1080i, but your DVD and PS2 are only 480i (or maybe 480p for the DVD if progressive scan). Sometimes component inputs are 'self adjusting' to the signal, but others require manual setting.
May 30, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
ATI ALL-IN-WONDER 9600 (128 MB) Graphic Card Logo
359 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
