Question about Brother IntelliFAX 2800 Laser Fax
Recieving faxes How do you get the fax off sleep mode so that it can rcieve incoming faxes? And also which part are you supposed to put the paper in?
  • Anonymous Sep 11, 2008
    I can send faxes but not receive. It shows in sleep mode when I go by it on occasion however, I don't know if it wakes up when it is sent a fax because I never receive it.
    I also need a manual to check it's programming.
  • Anonymous Sep 26, 2008
    Stupid thing is in sleep mode. I went through the menu choices and there is no obvious solution.
  • 2,120 Answers
Go to to download the user manual.
Posted on Oct 21, 2008
Cant get incoming fax
be sure phone cord is plugged into line port..not tel. Or your machine is in manual mode. Press button under lcd panel that says recieve mode until display reads fax/tel.
Apr 12, 2012 | Canon LaserClass 2050 Plain Paper Fax
Sleep mode will not disable, even when send button pushed, paper put in for fax or receiver taken off hook. Sleep mode set to default 5 minutes.
Press Menu 1,8
then set minutes to 00
press Stop/Exit
This should disable Sleep mode. Please post back with any questions or to rate this solution. Thank you very much.
Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Our Brother Fax Machine 2820 stays in sleep mode. How do we get it out of sleep mode?
Machine goes into sleep mode when not being used When it recieves or you copy something it will come out of sleep mode If its not recieving then you need to check your recieving settings
Jun 10, 2009 | Brother IntelliFax-2820 Laser Fax
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
Fax machine Canon L220
Ok first of all you have to deside how you are you going to use the fax,there is a option for Manual mode,Fax only and Fax Tel mode.
I normally set all my faxes with Fax only mode and then set the incomming ring to 7 rings before it switch to fax.This give you enought time to answer the phone.If you answer the phone and it is a fax you just press the green button.
You load your paper at the vertical tray,this is the last paper tray from thefront.
For sending faxes-put your documents face down in the dockfeeder dail the number and press green button.
Remember to connect the incomming fax line to the "L" jack on you machine and the extention tellephone to the jack with a handset showing on top of it.
Jan 14, 2009 | Canon L220 Plain Paper Laser Fax
Fax Machine
Make sure the receive mode is not selected as manual. If it is, you must pick up the phone handset and press start. There is a long skinny button that is Receive Mode, just select Fax.
Also check the incoming phone connection, make sure it's plugged into the LINE connection hole, not the EXT hole.
Jul 03, 2008 | Brother FAX-575 Plain Paper Thermal
No incoming Faxes
first you have to set the fax machine in auto answer that you can automatically recive the incoming faxes.
Apr 09, 2008 | Samsung SF-515 Plain Paper Laser Fax
Can not recieve Faxes
These machines goe into sleep mode automaticly and should exit when they detect a ring.
You MAY have a problem with your main board.
First make sure your phone cord is plugged into the correct port. There are two, line and ext. It must be plugged into line.
You can try a factory reset if that doesn't work. Unplug unit, hold menu button, plug back in and wait for lights to blink and display to read Maintenance.
Press 0 and 1
Now press 99
Now try sending to the machine again.
If this doesn't work, you likely need the unit serviced.
Dec 28, 2007 | Brother IntelliFax-2820 Laser Fax
I cant recieve an incoming fax
Check receive mode, probably set to manual receive.
Sep 03, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
You should be able to send and recieve faxs in the sleep mode. You need to reset the machine, pull out the plug, hold down the menue key while you plug the machine in. When maintanence comes up in the display enter 01 and wait. Whwn maintanence comes up again press 99. DO NOT PRESS ANY OTHER NUMBERS OR YOU WILL DAMAGE THE MACHINE BEYOND REPAIR. Your fax is now reset and completley empty, you will have to put in your name etc and sleep mode will be set to "0" minutes
May 15, 2007 | Brother IntelliFAX 5750e Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
101 people viewed this question
James Cagle
James Cagle
Jim Keysor
