FW754p 37 When I have power to my system all the lights/bulbs are on, and my unit seems to be locked up. any suggestions?
  • 5,568 Answers
You are probably right; this sounds like a normal startup routine that puts some circuits to a test for function but in your case, it doesn't complete the test, indicating that something has failed.
Try pull the AC plug and ingoring it overnight to see if the condition will change. In most of the modern home systems, there are simple microprocessors to handle the many tasks available and, like any darned computer, they may trip over themselves now and then.
Posted on Sep 06, 2008
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Oct 10, 2016 | Volvo 850 Cars & Trucks
I have a 60pl9200d/37 philips dlp tv. I replaced the bulb with a brand new one and I am still receiving the bulb issue indicated by the blue lights. Any ideas?
I don't know the model but it would seem a reset would do the trick. See if there is a button on the cpu board and that should do the trick if not try unplugging a re plugging unit . Logic needs reset by a switch or by removing power
Feb 19, 2015 | Philips Televison & Video
Timer is lock replace bulb
This set has all kinds of problems--
try the self check:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
Jun 01, 2012 | Televison & Video
No indicators working found fuse box which fuse?
When you are talking about "indicators" we could assuming that your are refer about signal lights. This work with "flashers" devices.
For 1996 Audi A4 2.8L SFI 6cyl the Flasher is located in front seating area, driver side, under dash, behind dash lower panel, mounted above driver side of steering column.
About generic fuses, open the driver side door. Remove panel on left side of dash. Fuse box is behind panel:
Fuse # / Description / Amps
1 / Heated washer jets / 5
2 / Turn signals flasher unit / 10
3 / Headlight washer, illumination of glove compartment, engine compartment, climate control, automatic transmission, instrument cluster / 5
4 / License plate light / 5
5 / Instrument cluster, seat heating, test connection for cruise control, bulb monitor for auto-check control, Automatic transmission display, switch lighting, mirror switches and actuators, airbag warning light, outside temperature indicator, Climate control / 10
6 / Central locking system / 5
7 / Anti-lock brake system / 10
8 / Vacant
9 / Mirror heating / 10
10 / Vacant
11 / Cruise control (automatic transmission) / 5
12 / On board diagnostic system / 10
13 / Brake lights / 10
14 / Interior lights, reading lights, anti-theft alarm system, vanity mirror / 10
15 / Instrument cluster, power windows, climate control, automatic transmission / 10
16 / Anti-lock brake system, Anti-Slip-Regulation / 5
17 / Heated door locks / 10
18 / High beam right / 10
19 / High beam left / 10
20 / Low beam right / 15
21 / Low beam left / 15
22 / Tail and side marker right / 5
23 / Tail and side marker left / 5
24 / Wiper and washer system / 25
25 / Blower for heating, climate control / 30
26 / Rear window defogger, mirror heating / 30
27 / Rear window wiper / 15
28 / Fuel pump / 15
29 / Engine timing / 20
30 / Sun roof / 20
31 / Tail lights, cruise control, automatic transmission / 15
32 / Engine timing / 20
33 / Cigarette lighter / 15
34 / Engine timing / 15
35 / Trailer receptacle / 30
36 / Fog lights / 15
37 / Radio / 20
38 / Luggage compartment light, central locking system / 15
39 / Emergency flasher / 15
40 / Horn / 25
41 / Anti-lock brake system / 25
42 / Vacant
43 / Vacant
44 / Seat heating / 30
Hope this helps (remember to rate and comme this free answeer).
Jun 16, 2011 | 1996 Audi A4
Hi. We're having power outages in TX right now. When power in house came back on, our Philips Home Theatre System (HTS 3544) seems to have lost all its power. We've plugged and unplugged the unit, and...
These are prone to power spikes...and for that reason have a fuse located on the power supply board...known as fast blow fuses...which are glass and easy to see if they have blown..sometimes all you need to do is replace the fuse on the rear of the unit if you can locate a fuse cap...just unscrew and replace....Always unplug televisions and audio equipment and routers during power outages and thunderstorms as a preventative to blowing psu panels on electrical devices connection to your house mains for this reason .
Feb 05, 2018 | Philips HTS3544/37 Theater System
Fuel Pump Fuse Number for a 1998 audi a4 2.8 quattro
Fuses: Fuse arrangement in fuse panel, behind instrument cluster, left
Fuse Arrangement In Fuse Panel 62624464
1 - Heated washer jets 5A 2 - Turn signals 10A 3 - Headlight washer (relay), illumination for glove
compartment, climate control, Automatic Transmission, instrument cluster 5A 4 - License plate light 5A 5 - Instrument cluster, seat heating, test connection
for cruise control, bulb monitor for auto-check display, Automatic Transmission display, switch
climate control 10A 6 - Central locking system 5A 7 - Anti-lock brake system (ABS) 10A 8 - Vacant 9 - Mirror heating 10A 10 - Vacant 11 - Cruise control (Automatic Transmission) 5A 12 - On board diagnostic system 10A 13 - Brake lights 10A 14 - Interior lights, reading lights, anti-theft alarm system, vanity mirror 10A 15 - Instrument cluster, power windows, climate control, automatic transmission 10A 16 - Anti-lock brake system (ABS), Anti-Slip Regulation (ASR) 5A 17 - Heated door locks 10A 18 - High-beam, right 10A 19 - High-beam, left 10A 20 - Low-beam, right 15A 21 - Low-beam, left 15A 22 - Side marker and tail light, right 5A 23 - Side marker and tail light, left 5A 24 - Wiper and washer system 25A 25 - Blower for heating, climate control 30A 26 - Rear window defogger, mirror heating 30A 27 - Rear window wiper 15A 28 - Fuel Pump 15A 29 - Engine timing 30A 30 - Sun roof 20A 31 - Tail lights, cruise control, automatic transmission 15A 32 - Engine timing 20A 33 - Cigarette lighter 15A 34 - Engine timing 15A 35 - Trailer recptacle 30A 36 - Fog lights 15A 37 - Radio 20A 38 - Luggage compartment light, central locking system 15A 39 - Emergency flasher system 15A 40 - Horn 25A 41 - Anti-lock brake system (ABS) 25A 42 - Vacant 43 - Vacant
Apr 05, 2010 | 1998 Audi A4
HTS3410D power light keeps blinking
This seems to be a common problem with this model. It seems as though there are about FIVE electrolytic capacitors in the power supply PC board that have failed or dried out.
They can be replaced by someone that has the dexterity, knowledge and tools to de-solder and re-solder PC board components. Otherwise you may seek a local electronic technician. The parts cost about $5.00. Labor may run you $30 or more.
Hope this helps. I also am looking for a remote for mine, if someone has a dead HTS-3410D.
Thanks!
Jun 30, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Optoma ep739 color was going greenish so i replced the bulb and now it seems to be getting no power at all? i tried several outlets and still no power, no flashing light, no led, nothing. Any suggestions?
These units have many safety interlocks. First make sure that all of the doors that you opened are replaced correctly. If not, the interlocks will prevent any power from getting to the unit. Update this with what you find.
Dan
Jan 29, 2009 | Optoma EP739 Multimedia Projector
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Controll panel says lock
Try unplugging the unit from power for 10 minutes then plugging back in to try to reset the system. If this does not solve it you may have a faulty ejection circuit in the unit, when the circuit is activated it locks the system.
May 21, 2007 | JVC TH-A5 System
69 people viewed this question
 Grubhead
Grubhead
