Question about Panasonic DVD-RP62 DVD Player
Won't display in 16:9
I've had this DVD player & recently purchased a 16:9 HDTV. Even though I've set the aspect ratio to 16:9 in the setup, it only displays in 4:3 and Panasonic support's only solution was to use the Zoom feature (only applicable when aspect is set to 4:3, so doesn't do any good). Has anyone else seen this? I think it is a defect w/ my player (or software/firmware). Any ideas?
Kimi
  • 277 Answers
SOURCE: Troubleshooting -- Displays H07 code
The H07 error message in Panasonic DVDs means problem in the motor. It can be something like "motor isn't spinning-up" or "spindle motor problem". When you call Panasonic, they will tell you that they cannot tell what H07 means until a technician look at it. Obviously, they won't admit it is a known problem. Estimate cost: from $50 to $70 dollar to replace the motor + labor + tax.
Posted on Dec 26, 2005
SOURCE: Panasonic DMR-EH75V DVD Recorder
I have the same unit and luckily there is a service center here in dallas tx called bayard electronics. I just dropped mine off there. check out the website at www.bayardelectronics.com
Posted on Apr 02, 2008
zair
  • 82 Answers
SOURCE: Panasonic DVD-S27 Region Free setup
A special service remote is needed to change the region.
Posted on Apr 06, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
nandosnut
  • 112 Answers
SOURCE: panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
Posted on Apr 24, 2009
How to adjust aspect ratio on sony kdl-v40xbr1
Hello
To take advantage of the wide mode feature on your TV, Set the DVD players' aspect ratio to 16:9. For details, refer the operating instructions supplied with your DVD player. Aspect ratio must be set with DVD player. Not with the TV. OK.
Feb 05, 2012 | Sony BRAVIA KDL-V40XBR1 Television
Change screen from wide to regular our cable guy put it on wide my control will no longer change it
Vizio has a set of buttons on the left side where you can access your settings and change the aspect ratio of your TV. Though why you want it changed is beyond me. Wide screen is for 16:9 aspect ratios. At 4:3 (Standard) you won't be using your full TV picture.
May 19, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
Hi. We have a Sony dvd player dvp-sr200p and have a wide screen tv, when we play a dvd we get a small square picture with black sides. We would like the have a full picture like we had before. Could...
With the player in STOP mode, or without a disc inserted, press DISPLAY on the remote. Then press either the UP or DOWN arrow keys (on remote) to scroll down from LANGUAGE setup to SCREEN SETUP, then highlight the aspect ratio which best suits the connected TV, in this case 16:9 widescreen (according to the manual the default aspect is 4:3 letterbox). Once you have made the change, exit the setup. It should remember the setting you have made.
Pages 26 to 27 of the owner's manual illustrate the setup procedure for this model DVD player.
NOTE: some DVDs may be encoded as 4:3 titles, hence you will see black borders at the left and right sides of a widescreen TV. Not all DVD movies are encoded in the 16:9 aspect ratio.
However, you can check your player's setup menu just to be sure.
Apr 08, 2011 | Sony DVP-SR200P DVD Player
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
Letterboxes on my LG 42" LCD HDTV...
Have you tried the Aspect Ratio button on the remote control, this will change the oicture size through 4:3/16:9/ etc.
Mar 22, 2010 | LG 42LC2D 42 in. LCD HDTV
Occasionaly a wide screen dvd plays only in full screen
The aspect ratio on your DVD player is not set correctly. Look for a SETUP button on the remote control, there should be something like "QUICK SETUP" or something similar on the setup menu, if not then go to the menu that has the aspect ratio settings listed. Change your aspect ratio to 16:9 WIDESCREEN, and this should solve your problem. Your aspect ratio is 4:3 which is for a regular TV, if the images (especially people) look real skinny and tall on your TV then your aspect ratio is not properly set. Good luck to you!
Jul 30, 2009 | Oppo Digital DV-981HD DVD Player
LG 32'' LCD TV aspect ratio self switching
I have an LG LCD TV with the same problem.
The solution is to go to
MENU
OPTIONS
FACTORY RESET
And select HOME rather than STORE on initial setup.
Mine was set to store as it was a display model.
That means that whatever picture setting you make they will reset after 10 minutes.
Nov 19, 2008 | LG 42LP1D 42 in. LCD HDTV
Aspect ratio
push setup on remote. go to video, select "16:9".
i was looking for a way to get rid of zoom logo from screen and decided to select 16:9 instead of 4:3 in setup. hope this helps
Oct 30, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD portable player - protron DVD player model PDV-288
The 4:3 is an aspect ratio the ratio of horizontal to vertical size and the non-HDTV standard; the latter is 16:9.
The PAL and NTSC abbreviations refer to the picture and synchronization standards whereby NTSC is the American standard and the PALs are European. The setting "sp-raw" refers to an unprocessed video format that requires further processing before it can be viewed.
If the disk you have was made for the American market, you should be set to NTSC and the aspect ratio to whatever the disk is specified, most recent disks will be made to conform to HD specifications, but may also  be viewed in "letterbox" form which is a shrunken 16:9 box with pronounced edges around it.
Oct 06, 2008 | Protron PDV-288 7" LCD Portable DVD Player
Panasonic DVD-RP62 DVD Player Logo
53 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
