Hitachi cp-s235 - does not turn on?
I have been using my projector of and on to watch movies...Now it is dead..completely dead...I do not know why? But the cord is plugged into a socket that works and i recently had cleaned the filter and reset its timer. I do not know what to do now....
  • Anonymous Nov 29, 2008
    Hi, there was a storm and since then my projector cannot start.When the power supply is connected, the orange light remains off.
  • rickyhard770 Apr 05, 2009
    hi duse any one know what kind of fuse it is and what amp
    thanks
Change the fuse!
Posted on Sep 11, 2008
Seeing yellow spots on my CP-S235; getting bigger over past 2 weeks
this is the blue lcd burning out and is the end of the projector.
Jan 13, 2013 | Hitachi CP-S235 Multimedia Projector
My projector is coming up with two red lights. I have cleaned the filter and the lamp, the lamp is lit but nothing is projecting? Help, do I need to replace the projector?
Which lights are red, Power, lamp or temperature?
Does the menu not come up at all. What about the startup logo etc.
I'm assuming the lamp has not exceeded 2000hrs useage, when it will shut off automatically.
Sep 14, 2011 | Hitachi CP-S235 Multimedia Projector
To replace a bulb in the Hitachi CP-S235 LCD Projector, do I just unscrew the two screws under the plate underneath the machine? Are there any precautions I should take, like not handling the bulb? I have...
Yes to replace the lamp you need to remove the 2 screws. You can touch the lamp but I try not to. After the lamp is in you need to reset the hr timer for the lamp. to do this you need to look in manual on page 34.
If you do not have the manual you can get it here at link below.
http://www.aboutprojectors.com/pdf/hitachi-cp-s235-manual.pdf
Good luck
Oct 05, 2009 | Hitachi CP-S235 Multimedia Projector
My hitachi cp-s235 projector has a blueish hue on the left side. how do i fix it, it is a brand new bulb
i think it is mothing to do with the bulb it is the stup of the 3 color frame inside ,or iternal dirt ....need profesional store ....
Aug 30, 2009 | Hitachi CP-S235 Multimedia Projector
Picture settings
You should go to the menu and look for the "Mirror" settings, change the vertical to bring it rightside up, however if it is also backwards (horizontally) change the horizontal "Mirror" there is an option of turning on either both or each separate option. I assume though that you will probably just have to change the setting to H&V Mirror.
Apr 07, 2009 | Hitachi CP-S235 Multimedia Projector
The change filter light keeps coming on
In the manual, it says you have to go in the menu to the OPTION submenu. Go down to FILTER TIME and hold the right arrow down for 3 seconds. It will then go into a mini-submenu that, when you press the up arrow, will reset the filter time to 0. The key is to hold down the right arrow initially for THREE+ SECONDS to get into the reset filter time menu. This is NOT the submenu that has RESET - EXECUTE. That is a different thing that doesn't reset filter & lamp time.
Here's the manual online:
http://www.hitachi-homeelectronics.us/supportingdocs/forhome/DisplayTechnologiesGroup/lcdprojectors/SupportingDocuments/01CP-S235-OG-ENG.pdf
Jan 05, 2009 | Hitachi CP-S235 Multimedia Projector
Hitachi cp-s235
Did you clean the air filter? You should vacuum it or use an air dusting can to clean it out.
Afterwards, reset the time in the menu. In the manual, it says you have to go in the menu to the OPTION submenu. Go down to FILTER TIME and hold the right arrow down for 3 seconds. It will then go into a mini-submenu that, when you press the up arrow, will reset the filter time to 0. The key is to hold down the right arrow initially for THREE+ SECONDS to get into the reset filter time menu. This is NOT the submenu that has RESET - EXECUTE. That is a different thing that doesn't reset filter & lamp time.
Oct 07, 2008 | Hitachi CP-S235 Multimedia Projector
CP-S335 popping noise when powering on
Hi Eva
A Projector does'nt like being switched on and off all the time , if you are going to watch a couple of movies - rather leave the machine running all the time - this will also help you to get more hours out of your lamp - and that's a promise.
As far as the noise is concerned - it is most probably just the machine that was not cooled down properly at that stage.
Apr 02, 2008 | Hitachi CP-S335 Multimedia Projector
Hitachi cp-s235 projector- red lights and projector turns off
There is a small tab on the lamp cover that should press into an "L" shaped slot on the lamp housing. This tab may break off, and not press into slot far enough to make the lamp dectection switch click. When the lamp heats up, the plastics expand and the detection switch opens. The projector quits as if no lamp is installed. The fix is to make an extension for the tab. I cut a small piece of sheet metal and crazy-glued it to what was left of the plasic tab.
Feb 20, 2007 | Hitachi CP-S235 Multimedia Projector
277 people viewed this question
k24674
