Question about Ricoh Aficio 450 Copier
Scan Reads How do I get to SP mode to retrieve the count? Can I track by looking at the journal? Any elaboration on this would be great.
  • Ricoh Master
  • 2,794 Answers
Press the user tools/counter button. Select the counter in the lower right corner on the lcd display. If you need a hard copy. Press print on the screen. Press the green button on the copier.
Posted on Sep 07, 2008
HOW I WILL GO IN SERVICE MODE OF A PRINTER
Clearing the Maintenance Count and Service Message: HP LaserJets servicepin.jpg
If the display panel on your HP LaserJet reads "Perform Printer Maintenance", "Perform User Maintenance", "Maintenance Kit Low", "Maintenance Kit Very Low", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count.
Oct 31, 2014 | Ricoh Aficio SP C410DN Laser Printer
Print SP & Scan SP are not avaible
check f the printer and scanner kit r installed!
Feb 02, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
Teac md-h300
There is no unit with the name you gave.
Does the unit itself say MDLP on it? If it doesn't, theres a good chance it doesn't support the LP modes and will only playback/recor unit only plays in SP or MONO.
Sep 19, 2012 | Teac MD-H300 Personal MiniDisc Player
Retrieving old fax transmissions
Usually the journal only holds the last 50 sends / receptions.
Feb 02, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Device monitor application problem
Make sure that the Lexmark Imaging Studio program is running. This was installed when you set up your printer.
If you see the multi-colored icon in your task bar for Lexmark Imaging Studio then try pressing the scan mode button twice. You should be able to scan then.
Sep 28, 2008 | Lexmark X3550 All-In-One Printer
Ricoh Aficio Scan Reads
the system can track scans however is accessed through SP mode only.
www.p4photel.org
Sep 05, 2008 | Ricoh Aficio 450 Copier
VCR running badly
The 180 tape is thinner than regular 120's, and they tend to stretch. Your VCR "knows" the speen and that there is information on the tape by looking at and counting the pulses on the "control track" which is like the sprocket holes on a film. The control track is a series of pulses (regularly spaced pips or electronic clicks) on the edge of the video tape. (They are magnetic and can't be seen with the naked eye.) There is a counting mechanism which - based on HOW MANY pips there are - helps the machine to determine whether it an SP, EP or LP recording, and whether there's a recording at all.
If the tape stretches, the number of pulses becomes very irregular and the machine goes haywire. (There are normally about 60 pulses in one second of tape - 59.94 to be exact!)
If the count - because of stretching - is too far away from the norm the machine the machine will "hunt" (and never find out the real speed) - trying to figure out what speed the tape ACTUALLY is running at. If there's no control track at all the machine will just stop.
Your problem is any or all of the above. Throw the tape away.
Sorry!
Aug 14, 2008 | Televison & Video
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
only).
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
playback.
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
Sony VCR plays/recordes in EP mode but not in SP mode - need schematic
sounds like it needs a good cleaning, you will notice this problem in sp first when needs cleaned. however if you had done this I would go over it again and if not then change the video head
Nov 19, 2007 | Televison & Video
Volume
Your MD player probably isn't LP capable. Attempting to play an LP recorded MiniDisc in a player that is only SP capable will produce no sound even though the display (time counter, track name) looks like everything is operating properly. Record the MD you were attempting to play in SP and you will get sound.
Mar 05, 2006 | Pioneer MEH-P5000 MiniDisc Player
Ricoh Aficio 450 Copier Logo
64 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
