Question about Inland (08304) 4-Port USB Hub
Inland 7 port usb 2 hub, inconsistent connection
On a Dell Latitude D600, (Win XP SP3) this hub provides only inconsistent connections to the devices attached to it. A scanner, and an external modem, in particular, seem to disappear after a couple of hours. This can be rectified by detaching and re-attaching the USB connector from the hub. This is impractical, especially with the modem, which needs to stay connected for fax reception when unattended for long periods. Yesterday a printer was "off line" according to print manager, but again was restored through the detach, reattach technique.
  • puzzler0373 Sep 05, 2008
    I think I should mention that the USB port on the laptop is a USB 1, the hub is a backward compatible 2. I tried the fix mentioned, but still have the same problem.
  • puzzler0373 Sep 06, 2008
    What I learned from a local wiz is that USB devices like scanners and modems are particularly sensitive to disconnection when on a hub. I connected the scanner to an available port on the laptop and installed a PC to USB card for the modem. After some difficulty reinstalling the drivers for the modem, both devises are now working well.
    I'd have to say that the most recent reply was confusing, perhaps because of a language translation issue. Moreover, it didn't offer a solution.
    I believe there was a money back guarantee. Please contact me regarding obtaining a refund.
  • 1,879 Answers
Http://www.fixya.com/contact for Customer Support
Billing Inquiries - premium.support@fixya.com
Posted on Sep 06, 2008
  • 6,487 Answers
This can be a problem with the power that the hub is getting from the USB port of your laptop , because base what you inform us there are several devices attach to the hub that is the reason it will be intermittent...
Posted on Sep 05, 2008
    Sergeant:
  • 264 Answers
Delete all the Usb Root hubs from the device manager and restart the computer
  • Sameer Kashyap Sep 05, 2008
    steps to do the same
    Right Click "My computer" Open properties
    Click the Hardware Tab. Open teh Device manager
    At the bottom Click the "+" on the USB.
    You will see the Entry of USB Root Hub
    Delete all the entries for the USB Root Hub.
    Restart the computer.
  • Sameer Kashyap Sep 06, 2008
    Another Important setting that you need to check is, under device manager right click the USB Root Hub and open the properties.
    Under the Power Management Tab, make sure that he following option is unchecked.
    Allow windows to turn off the device to save power.
    This should work in your case.
    All the Best
    Sammy
We are connecting a Printer Gadget to DELL D600 laptop and it is getting detected. But when we connect a USB memory device to DELL laptop it is displaying "USB Device not recognized" message....
Sounds like the"device" is using all the current on the USB Bus ... buy a USB Hub ($5 on Ebay) to see if it cures the problem. USB current is very limited, but a Hub has it's own power supply.
Feb 23, 2011 | Dell Latitude D600 Notebook
None of 2 usb ports work, drivers fine in device manager tried uninstall ane restart, drivers all install no issue ,, usb still not working
measure the voltage of the usb ports. if it is higher than 5v, than you have a problem. in this case you have to buy a usb hub and connect it through the pcm cia port.
but for your safety reinstall your os first and see if this happeneds again
Jan 27, 2010 | Dell Latitude D600 Notebook
ONE OF MY 2 USB PORTS DOES NOT WORK ON MY DELL LATITUDE D600. I TRIED THE FOLLOWING FIX, >START>RUN> DEVMGMT.MSC AND UNINSTALLED ALL USB CONTROLLERS, RESTARTED MY LAPTOP (WITH WIN XP PRO) WHICH...
Hi Roger,
The Windows command you used to uninstall the USB port is correct. If they all work bar one, then i think its safe to say it's possibly a hardware issue.
The only other fix i can think of is to update the BIOS with the latest version from the Dell support website.
Good luck.
Nov 12, 2009 | Dell Latitude D600 Notebook
XP crashed on my Dell latitude D600 laptop. I reloaded XP and all drivers. Everything works except it does not detect any device when plugged into the usb ports. They do light up. Utlities suggest that the...
I cant figure out a solution exactly as you have already tried things people have told you previously. but as far as i know dell should solve your problem for free instead of telling you to fix it. did you try contacting them and are you in your warrenty period?
Aug 03, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
go to mfg websight and down load all th proper drivers there is likely a mother board driver not installed that allows it to see the ports
install all of the manufacturer's drivers
dont expect that microsoft wrote windows just for your computer it is a general set of generic drivers that make most things work but not every thing
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=LAT_PNT_PM_D600&os=WW1&osl=en&catid=&impid=
I have a Dell Latitude D600 laptop whose USB port is being used to charge the battery in an iPod Shuffle music player. The laptop shuts down after about thirty minutes of inactivity, preventing the iPod...
You can use a powered USB hub to charge your iPod, MP3 player etc. without connecting to a laptop's computer USB port.
Just connect the mains adapter to the USB hub and then plug your iPod into the hub for as long as you need.
You can also use this hub for your computer/laptop when you need extra USB ports..
Jan 10, 2009 | Dell Latitude D600 Notebook
Inland (08304) 4-Port USB Hub Logo
429 people viewed this question
Top Inland Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
David Payne
David Payne
richie46
Are you an Inland Computer and Internet Expert? Answer questions, earn points and help others
