Question about HP Compaq nx5000 Notebook
Both USB ports suddenly don't work on my Campaq nx5000 notebook. I get power from both because the light under the mouse lights up. Any ideas what could be wrong? Thanks.
  • nirraddog Dec 31, 2008
    mine has the same problem. The device manager shows 4 hubs. One with 6 ports ans three with two. It also showed a system reserved memory of 10% on the 6 port and two of the two ports. It showed 20% on the other one two port. The next time i checked the dev. manag. it showed no system reserved pover to any of them. ?????????
    Scholar:
  • 94 Answers
Try to check the device manager.
by right clicking my computer, then hardware tab, device manager.
on the device manager check for the usb drivers if they are installed properly, if there is a problem you will see a yellow exclamation point on the usb.
try also to check for the updated drivers for the usb controllers on your laptop.
Posted on Sep 05, 2008
  • vic donald somera
    vic donald somera Sep 12, 2008
    conisidering what you did, i would recommend to have the hardware checked, check also the bios if it needs an update.
Just installed MS 3000 wireless mouse. Won't run. no light on mouse. Have put new battery in and still no light. Flash drive has light. What to do now? Yes, I pushed the connection pins on both.
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
don
Feb 24, 2011 | Microsoft Wireless Notebook Optical Mouse...
The USB port on my DELL Latitude C400 does not recognize the mouse
try to use otehr usb ports on your computer. check if the light on the bottom of the mouse lit up. open device manager. under mouse - delete otehr mouse components then restart computer.
Mar 08, 2010 | Dell Latitude C400 Notebook
Compaq nx5000 with new battery and new power
Dear,
Try pressing the CAPS LOCK. If CAPS LOCK is responding then it is surely your inverter.
It is a known problem with the nx5000 series laptop.
The FAN switches off because Intel SpeedStep which is absolutely normal.
I faced and solved at least 6 - 7 such problems on different nx5000 laptops
If CAPS LOCK is not responding then its your motherboard.
Good Luck and Regards
Nov 25, 2009 | HP Compaq nx5000 Notebook
Microsoft wireless mouse 3000; put in new battery, still nothing
nikcorra2488,
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Hope this helps.
-samson39
Jul 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
Receiver light is steady green. mouse won't light up. cursor won't move.
Why don't you try at the moment of placing a new battery to see if the small button that protrudes, where the receiver is located at the bottom of the mouse is pressed down. Without the receiver in place that **** on must be out for as long as the receiver is in the USB port.
Good luck!!!
Chawah.
May 19, 2009 | Microsoft Wireless Notebook Optical Mouse...
MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 20, 2009 | Computers & Internet
USB Port not working
Turn off the computer and remove the plug and battery wait for 20 mins then put it back in. Try again. Also check if you have a question mark or exclamation point in device manager.
Click start then run then type in devmgmt.msc then click ok
Nov 07, 2008 | HP Compaq nx5000 Notebook
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
USB ports are not working
Sounds like the power portion of the USB port is working but the data portion is not. My guess is that the drivers for the USB hub inside your machine are not installed, damaged or never installed. Check the "device manager" under "Universal Serial Bus Controllers". You might be able to fix it by deleting the hub. When you power off and power back up it should find the hub and reinstall the drivers.
Jun 19, 2008 | NEC Versa TXi Notebook
Wireless mouse is not working
ya..there is a small button on back side of the receiver..plug the receiver to the USB port and press the button for few secs and red light will start blinking..then a similar button is there for the mouse below it..press it and it will work fine.
Sep 26, 2007 | Dell Wireless Keyboard Optical Mouse w0147
HP Compaq nx5000 Notebook Logo
239 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
