Question about Zanussi ZWF1440 Front Load Washer
Zanussi zwf 1440
My washer has the error code E50. it's not drained the water from a previous cycle. now it will not do anything please help
    Champion:
  • 249 Answers
Something wrong with the pump,leave out let hose down as flat as possable into a basin or whatever,to drain water,remove pump test and check it.
Posted on Dec 02, 2008
When I switch machine on it is stuck on drain mode
most probably the solenoid valve that controls the draining is stuck and the water has not drained from the previous cycle or so the machine thinks.
You need a replacement of solenoid valve.
Feb 22, 2015 | Zanussi Washing Machines
Washer skips rinse cycle
Possible defective washer control panel.
Jul 13, 2017 | Zanussi Washing Machines
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
Our washing machine (Zanussi ZWF 1632 W) flashes 5 times
This is a motor problem the end light flashing 5 times indicates error E50. The motor has either got wet or has just failed i would suggest trying to dry it 1st but i would suspect the motor has gone down to earth usually having to replace it. The part no. DST1246179079 Motor aprox £195 but shop around you may find it cheeper.
Dec 11, 2008 | Zanussi ZWF1430W Front Load Washer
E50 code
hiya
i'm sure that e50/e51 is the insulation in the motor breaking down, in which case its usually new motor time i'm afraid.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Jul 20, 2008 | Zanussi ZWF1640 Front Load Washer
Zanussi zwf 1432 front loader
check the filter down on the right and cleane it
May 28, 2008 | Zanussi ZWF1430W Front Load Washer
Zanusi zwf 1631 w wont work
all of the e50 codes indicate motor check your brushes. if you still have problems email me
Feb 10, 2008 | Zanussi ZWF1630 Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
575 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
