Acer Aspire One Netbook 8.9" Notebook Logo
Posted on Aug 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you take ot the hard drive of an acer inspire 1
joecoolvette
Level 3:
  • Acer Master 5,660 Answers
  • Posted on Aug 15, 2011
joecoolvette
Acer Master
Level 3:
Answers
5660
Questions
0
Helped
2192861
Points
18014
They say, "A picture is worth a thousand words".
Here is a video,
http://www.youtube.com/watch?v=VFnIVZn3Wqk
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery.
2) Put the screws in a container. They roll quite easily off of a table.
Here is a link to a free Service Manual for the Acer Aspire One,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Click on the blue One to the right of Aspire One.
This is a PDF file. It may take up to 30 seconds for the first page to come up.
It may also take additional time to fully download.
Be SURE to observe Anti-Static Precautions before you begin, and during.
For additional questions please post in a Comment.
Regards,
joecoolvette
When I go to start menu to shut down and press shut down it will just reboot and will ot shut down
Step 1:
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
2answers
Aspire one can not detect hard drive
Repair laptop hard drive is not detected
Solution 1
1. Open the hard drive cover (remove two screws)
2. Remove the hard drive screws, then slide the hard drive (see the arrows)
3. Wait 15 minutes, then plug the hard drive
4. Turn on the laptop.
Solution 2
1. Remove the hard drive
2. Clean the gold layer with a pencil eraser
3. Plug the hard drive, then turn on your laptop
Solution 3
2. Plug jumper on the hard drive
Solution 4
1. Remove the hard drive, plug the external cable.
2. Connect the hard drive to another computer, with USB connection
3. If the hard drive can be detected, eject the hard drive
4. Plug the hard drive to the laptop, then turn on
Intended to make the hard drive can work with the help of another computer
Solution 5
1. Remove the laptop hard drive
2. Plug the laptop hard drive to my PC.
SATA1 - PC hard drive
SATA2 - Laptop hard drive
3. Boot the computer from a PC hard drive
The purpose of using a PC computer main-board as drivers of the laptop hard drive.
I hope this information helps. Thank you for using FixYa!
Have an aver inspire 4520 dont boot up compleatly and dont have the back up disk
on the acer aspire range there should be a recovery partition hidden by turning your note book off completely then press the power button as soon as you have done this press ALT on the left hand side and keep it down while continuously tapping the F10 button "fast" as this will start the internal recovery partition, if you have formatted the hard drive and this partition does not exist anymore you can go to microsoft or a torrent site and download the correct operating system making sure it matches your Operating system genuine sticker by using this key on the back of your computer you wont have to buy a new operating system, if your hard drive has developed a fault which is the main cause of you doing this then you will have to buy a new hard drive to replace it with using the same method above if you need further help please drop me a line, If i have helped please rate me Kronoguy
Acer inspire one netbook, ntldr missing, will not boot up or recover with inbuilt f10
Good day sir/maam, the ntldr missing is usually caused by a change in chipset, or mother board, in your case laptop. you may need to reformat the hard drive. Reinstall the OS. hoipe this helps. feel free to ask again. let me know your progress. thanks
2helpful
When I play a cd the drive vibrates very noisily
The vibration is from the fast rotation of the drive spinning the cd. Many newer drives do this. the only solution would be to place an older slower drive into the computer.
Acer aspire 5100 mic does not work
wont shut down locks up or freezes and task manger wont come up
Maxtor 80G won't work with ACER Inspire One notebook useing linus
Here is the support section for Maxtor:
http://www.seagate.com/www/en-us/support/downloads/
Seagate acquired Maxtor a few years ago and is handling all support on Maxtor products.
Hi , My Acer aspire 5920 wont switch on the battry light is green and the power button is blue and should b good to go but when pressed nothing happens
take the hard drive ot and the pote ti bake in the prese bote if theat dote work take the bater ot and pote it bake in
Acer hard drive
Hi, the problem is one hard drive ie the 1/3 one is a SATA hard drive, the other is IDE.
to set them both up you need to do this,
Connect the IDE Hard Drive using the IDE cable like before.
With the Acer Hard Drive you need a Sata cable cost about a £1 from any shop.
You connect the sata cable from the hard drive to the motherboard, but on the motherboard you are looking for a small red connection same size as the cable, SATA is on most motherboards for machines that are just over a year old.
Hope it helps.
Have a nice christmas
John
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
