How to repair canon mp830 PIXMA printer
Noisy printer & can not change feed
Hi, here is the service repair manual and parts catalog
http://www.flyupload.com/?fid=954793489
http://www.mediafire.com/?sharekey=3e0c2ce8dff323e3c2b435915e8821d7e04e75f6e8ebb871
Hope this helps!
- Lost In The Beltway
Posted on Mar 24, 2009
  • LostBeltway Mar 24, 2009
    I hope the links for the repair manual above is helpful. Btw, if anyone has any advice on my problem, I'd appreciate it:
    I'm still fighting the MP830 after an auto sheet feeder paper jam. After it's cleared, the auto sheet feeder is still not working properly:
    1) it would feed the paper partially, jolts a bit, then reports no paper found.
    2) When printing and copying from the casette tray, it would start printing at about 2" from the top of the paper, and stop printing after about 1/2 a page (sometimes less, sometimes more). No error, as if the printer thinks it's done. The paper is not fully ejected.
    I've fed envelopes and thicker paper to clear the path and reset the eeprom, all to no avail. Either the feeder gear is off or some sensor is bad.. any advice would be appreciated.
    Thanks
In what store can I buy head nozzles for Canon MP830?
Posted on Aug 12, 2010
What does canon pixma mp830 error code 6000 mean?
That is a line feed error (6000) It also should be flashing 3 times for this error on the on/off button.
This could be
1. Timing sensor unit QM2-2683
2. Timing **** disk film QC1-6229
3. Feed roller ***'y QL2-0925
4. Platten unit QM2-2923
5. Logic board ***'y QM2-3078
6. Paper feed motor QK1-1502
Mar 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Have a 6a00 code on my MP830. Printer made a bunch of noise then froze. Have unplugged and plugged in and started. No change. Tried to reset. Still frozen.
6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You will NOT be able to resolve the problem yourself.
Jan 14, 2011 | Canon PIXMA MP830 All-In-One InkJet...
My screen on my printer says error 6A00 error code. I have turned printer on and off...not sure what is going on
http://www.fixyourownprinter.com/forums/inkjet/39177
See website above for all details to do with this error.
Unfortunately 6A00 is a problem with the sheet feed unit.
You most likely will NOT be able to resolve the problem yourself, sorry.
Your service and repair manual is below, for you to download. All error codes and fixes are in there.
www.pdfoo.com/result-pixma-mp830-service-manual-.html
Sep 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Feed switch & alrm light on
The MP 830 usually will give you an error code in the display. If these lights just come on and you don't hear anything moving inside and no error codes, the main logic board could be bad. A rather expensive repair. Have you tried unplugging the printer and plugging in again?
Jun 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 fault code 6B10
Try to change paper size in the offending tray.
Jun 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I run a Mac OSX Leopard My Canon MP830 seems to be having a paper feed problem. I also get the Error 5010. This happened right after using the scanner. It starts to work ok, but then a noisy clicking...
Is the message 5100. Paper jam? This indicates that the printer head carrier is being interferred with. Open the cover and check the slide bar and the paper path to see if there is something obstructing movement. If the drive belt has slipped it needs to be reseated.
Apr 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp830 printing paused
GO ONLINE AND TYPE
CANON PIXMA MP830 INKJET PRINTER PAUSE PRINTING
OR
CANON PIXMA MP830 PRINT PUASE
OR
CANON PIXMA MP830 FORUMS USERS GROUP
ROD
Feb 09, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error Code 6A00 for MP830
try simply moving the cartridge back and forth a few times first
Because: 6A00 is a problem with the sheet feed unit. Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility. You will NOT be able to resolve the problem yourself.
Dec 09, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon service erore for Pixma IP4200
the prob is in the sheet feed unit, im afraid you cannot repair this pls send to repair shop asap
cheers
Nov 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Pixma mp830
see if you can open a back door on the feed side. sounds like a paper is not feeding properly inside and must be removed.
Would be nice to know the model, make.
Jan 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
2,627 people viewed this question
jasbo
jasbo
