Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
I finally got it all installed including a new IC561. No improvement. I still have no picture and the 4 times blinking error code. Any other suggestions? What about the power that comes to IC561? Is there an input voltage I can check?
  • 1 more comment
  • Jeff M Sep 08, 2008
    I have a Sony KV-27FS100 TV that has no picture, but I do have sound
    and can change channels. The indicator LED blinks 4 times then repeats.
    I'm told that this is likely a problem with IC561 (TDA8172).
    I measured 1.1V at pin #2 of IC561 and 0 volts on pin 9 of the flyback
    (not sure which was pin 9, but measured the pin that the schematic said
    should be +15V on the flyback). I have replaced IC561 (TDA8172).
    Afterwards there is no difference in voltage measurement.
    I don't know what next to check. Should I do check some other parts?
    There must be power sent to IC561, so what would I check to see it is
    getting power? I am a hobbyist and have a DVM, and no other equipment.
    I do have basic knowledge, but don't know anything about convergance or
    other adjustments.
  • Jeff M Sep 10, 2008
    I have a Sony KV-27FS100 TV that has no picture, but I do have sound and can change channels. The indicator LED blinks 4 times then repeats. I'm told that this is likely a problem with IC561 (TDA8172).
    I measured 1.1V at pin #2 of IC561 and 0 volts on pin 9 of the flyback (not sure which was pin 9, but measured the pin that the schematic said should be +15V on the flyback). I have replaced IC561 (TDA8172). Afterwards there is no difference in voltage measurement.
    I don't know what next to check. Should I do check some other parts? There must be power sent to IC561, so what would I check to see it is getting power? I am a hobbyist and have a DVM, and no other equipment. I do have basic knowledge, but don't know anything about convergance or other adjustments.
  • Jeff M Sep 12, 2008
    I have checked the power supply board and it looks OK. I would like to check the power coming to IC561 on the A board, but don't know what to check.
    Novelist:
    Champion:
  • 203 Answers
Have you checked the collector of Q502 for voltage? If there is no voltage there check and see if its shorted to ground. You cannot always troubleshoot off a blink code they are almost always wrong. If the collector of Q502 is shorted then you will need to replace it and the flyback transformer. Let me know what turns out and if I can help some more.
Posted on Sep 12, 2008
  • 1,879 Answers
I think you should consult with either keemo68 or Abrsvcs
Since they have a background on your problem from previous correspondences.
Posted on Sep 10, 2008
  • 2,326 Answers
Measure TP98 found on page # 32 of the service manual. That TP98 should read +12V.
  • Jaime Hernandez Sep 14, 2008
    Try to disconnect the wire assembly from CN706 found on page # 42 of your service manual. The +12V volts line could be shorted by IC701 or you can unsolder pin # IC701 without removing the wire harness and measure TP98 again and see if you get the +12V.
    Genius:
  • 1,239 Answers
Hi i think it should be solved at this time aftter instalisng ic561 check input voltage by multimeter
    President:
  • 1,263 Answers
Was the problem a convergance issue? why did you install the ic561? i can be of greater assistance if you can expalin in a little more detail
Posted on Sep 05, 2008
EmersOn TV has no picture when you turn it on, I noticed that the red light blinks 4 times after pressing on, I'm curious if that means something? Please help!
the 4 blinks are a error code means something wrong inside the tv
type your number and error code in google maybe point you in right direction
Jun 23, 2015 | Emerson Televison & Video
Four flashing red lights then one green - no picture. This hapoens when I try to turn it on, The screen stays black and has white horizontal line.
Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Oct 24, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Have a 4 blink error on a Sony KV36FS120
Yes, there's a posibility that IC561 is partially faulty but on the symptoms you've described, I would advice you to replaced first C539(470uf/25V) and C561 (47uf). I've suspected that these filter electrolytic capacitor is already leaky or dried up...
Dec 08, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV32FS120 blinks 4 times
4 times blink shows TV got problem in vertical deflection section and vertical out IC (IC561) either missing supply volts or itself bad.
Hope this info will help you if you are thinking to repair this TV.
Aug 30, 2009 | Sony Televison & Video
Thank you, it is fixed now.
Happy to help. Thanks for the update.
Dan
Oct 15, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-27FS100
in theses set's there should be a board that has a module that the power chord plugs into this module supllies the motherboard and the componants on it. to be honest it would be best to just let a professional replace any defective chips orboards at this point because i believe it is not just one problem but several and without me beibg hands on it would be difficult to narrow it down to just a simple answer.
Sep 08, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-27FS100 No Picture
Check Horizontal Output Transistor, if found bad / short, replace it.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-32FS120 blinks 4 times
good day.
Have you tried first resoldering the terminals in the circuitry?
Also, try to check for the ABL supply near the flyback. Watch out for the small voltage zener diodes.
response is highly appreciated.
chris
Mar 26, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Lamp bulb burned out I install a new one but still no picture
The ballast board may need to be replaced as well as the lamp. The set should give an error code such as blinking lights from the front button assembly. You need to count the blinks and take note if there is a pause between blinks. (example) an error code of 34 will go blink blikk blink, pause, blink blink blink blink. This process may repeat itself a few times.
Oct 29, 2007 | Philips 50P8341 50" Rear Projection...
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
65 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
