Set up 2 wireless routers, 1st for printer, 2nd for internet
I tried to set up a wireless printer. Have 2 wireless routers, 1 for printer, 2nd for internet. When set up, the pc can't find the printer. The ip address for router #1(printer) is 192,168.2.10 and router#2(internet) is 192.168.1.122.
Printer support said that my pc can't reach both ranges, ie printer and internet. I am able to connect to the internet, ie router #2.
What can I do?
  • Patrick Au
    Patrick Au Sep 05, 2008
    Because of restricted space situation, it is not possible to have the printer placed where router #2(internet), hence I tried to set up a router just for the printer.
    Problem Solver:
  • 16 Answers
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Posted on Sep 05, 2008
  • Matthew Rodela
    Matthew Rodela Sep 05, 2008
    If the printer is a wireless printer, you should be able to place it anywhere in your house that can receive the wireless signal from router #2.
    If the printer is not a wireless printer (no wireless card installed), and simply a network printer with a network jack, then you should connect it to a computer or a wireless printer hub (search for "wireless printer hub" in google), and not a router.
    Unfortunately most consumer routers are not smart enough to take the information from a printer and transmit it wirelessly without some sort of help.
    Hopefully this helps clear things up!
Wi-fi extender
using a wireless uplink sucks and most equipment won\'t do it and the ones that try suck at it.
that said:
-set the 1st router up normal
-set the second router up EXACTLY the same (SSID/password)
-now change the IP on the second router so that if the 1st is 192.168.1.1 the 2nd is 192.168.1.2
-last turn off dhcp on the second router
-NOW run a ethernet from the 1st to the 2nd and plug it into any port but the internet port. (that port won\'t be used anymore)
-ta-da! 2 networks but as far as your wireless device is concerned they are the same 1.
i have done this many times.... I have 3 routers at my place and can walk the whole length of my condo without losing a single packet!
Nov 06, 2013 | Computers & Internet
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
Tip
Samsung ML-2525W printer & Mac OS X 10.6
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable (3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch (4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless) (5) WiFi to router, with Mac/PC via Ethernet to router/switch (6) WiFi to router, with Mac/PC also via WiFi
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Also required different driver for wireless config (as opposed to USB).
How can i cascade a Comtrend CT-5621 with a Netgear Wnr2000v3
works best if you hard wire from LAN port of main router to LAN port on second router. 2nd router never has anything plugged into internet port. 2nd router has dhcp turned off. 2nd router has a ip inside the 1st routers ip range but not the same as anything else
Jul 06, 2012 | NetGear WNR2000 Wireless Router
Can i setup the belkin f7d4302 as a wireless bridge
belkin does not support this. The only way you can do it is by running a cable to the router to extend your wireless signal around the house. I did a similar setup with a powerline network adapter if running a cat5 cable is not a option. just make sure you change the main ip address for the 2nd router to like 192.168.2.2 and disable dhcp since the main router will handle dhcp. also make sure the wireless settings are the same and channel is different if 1st router is channel 1 then use channel 6 or 11 for the 2nd router.
Feb 26, 2012 | Belkin Wireless Play Router (F7D4302)
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
DGN2000 router problem. I have 2 pc connected on the router and only the main one has access to the internet. Am i doing something wrong with the settings or does my router has a problem? Is it true that...
I'm not aware of any problem with the DGN2000 that only lets you connect 1 computer (If it was I dont think they would sell many and EVERYBODY would know about it)
Anyway - try swapping the network leads over (remember which port is the "live" one) does the other PC now have internet access and the 1st one not?
if the 2nd pc DOES have internet access the yes you have a suspect router.
if the 1st computer DOESN'T have Internet access you have suspect router.
if the 2nd pc DOESN't have internet access but the 1st pc DOES - then the problem is something on the 2nd pc.
Hope this helps.
Jan 30, 2011 | NetGear DGN2000-100NAS Router
Connection issue
Hi! I believe your having some issue with your router and I will be more than glad to assist you in this concern..Time warner cable is your isp and if the computer is connected directly to the modem, you have a perfect internet connection but if you are going to connect the cable from your modem to the router and you connect your computer to port 1 to 4 of your router it will not give u an internet connection. This is what we are going to do.
1. connect your computer that can get an internet connecttion thru time warner cable to the router on port1.
2. pull up a browser and type in the default gateway of the router, to check the default gateway of the router, right click the network icon on the lower right of the task bar and click status and it will show the ip address, subnet and default gateway, ex the default gateway is 192.168.1.1, u are going to type in the default gateway ip address to the url of the browser.
3. It will ask u for the username and password, by default the username is admin and the password is 1234 or just leave it blank.
4. It will pop up the setup page of the router and you have to look for the setting for doing a mac clone, you need to clone the mac address of your pc that can connect to the internet thru time warner cable modem.
5. once its done, save the settings and on the internet connection settings, manualy configured it to auto-dhcp. save the settings.
6. once its done..unplg the power of the computer, router and modem.
7. cable connection should be, cable from the modem goes to the WAN port of the router and connect cable on port 1 of the router to your computer on the lan port.
8. Plug in 1st the power of the cable modem, once all lights are lit then plug in the power of the router, once all lights are solid on the router, like the power, WAN, u will notice that there is no light on the port1, computer is still off, once the computer is on port1 will lit, then power on the computer..once computer is completely boot up, pull up a browser and it should gives u an internet connection.
9. Once you have an internet connection, u can access again the setup page of the router to setup the wireless connection settings.
10. If you are going to connect another to the existing router that is conneted to the time warner cable. that is possible, but before u connect the 2nd router to the 1st router..
a. connect the 2nd router to a computer to set it up..you have to access the setup page of the 2nd router.
b. once you access the setup page, there is a menu for the lan settings that is for the router side. u need to change the 3 octet of the ip address of the 2nd router. ex your 1st router ip address is 192.168.1.1 and the 2nd router ip address is 192.168.1.1 to change the 3 octet of the 2nd route, the 2nd router ip address should be 192.168.2.1. then save the settings..
c. the router will reboot and need to access the setup page of the router by using the 192.168.2.1 and u can set the wireless connection settings.. once its done..
d. cable connection should be---cable from the time warner cable goes to the WAN port of the 1st router, connect a cable to port 4 of the 1st router going to the WAN port of the 2nd router.. this process is called cascading two routers on a network.. this should work.. good luck
Aug 16, 2009 | ViewSonic (DHWMG120) Router
Connecting Compex 28g to mobile broadband and home network
please check following points:-
1) IP address (some wireless AP's follows ip address such as 192.168.1.1 for AP and 192.168.1.2 for 1st workstation, 192.168.1.3 for 2nd workstation and so on).
2) check connection options in IE. it should be lan setting and detect automatic setting and use automatic configuration script(put IP address of AP)
3) if DHCP is enabled then obtain IP automaticlly
4) check for any WEP security options i AP.
5) user must have internet access rights.
6) if Static IP is Used please give gatway ip (your AP's IP address) and same for DNS IP address.
then restart your system and enjoy internet.
May 01, 2009 | Compex NetPassage 28G Wireless Router...
Linksys wrt54gs Set up
1. Unplug your cable/dsl modem.
2. Unplug your Router
3. Plug in your modem ... wait for it to come completely up.
4. Plug in your WRT54G Router and wait for it to come up.
5. Go to your 1st PC and get into Command Prompt. Type is ipconfig /release .... then type ipconfig /renew
6. Check for internet connectivity.
Repeat step 5 for for your second PC.
If your second PC is wireless go into the wireless config utility and search for access points. Connect to your Access point and check for connectivity.
If you still have no internet. Press the reset button on the back of the router for 45 seconds while it is powered on. Repeat steps 5 and 6.
Be sure to lock down your wireless SSID so neighbors and people passing by are unable to connect to your access point and do bad things on your network.
Jun 10, 2008 | Linksys Wireless-G WRT54G Router
709 people viewed this question
jasbo
jasbo
