FixYa.com
Tags:
Sony CDX-CA400 CD Player
MD/CD Changer Control Options
posted by Guest on Nov 12, 2005
I cannot get my cdx-ca400 to switch to the MD mode. Im trying to plug my IPod into the bus output on the back and I cannot get it to work. If anyone knows of a better way to go about doing this, please share, thank you.
Best Solution
posted on Apr 06, 2008
FixYa! (100)
Penguindave
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
I actually have the same question. There is a bus audio input on the back (L & R phono) I have a cable to go from 1/8" stereo to this. There is also a bus control input. These are for an external cd changer. I wonder if anyone has tried to use the bus audio input without the control input.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 16, 2007
Thanks for Trying (70)
Guest
Guest
Rating: 0%, 0 votes
you need to have a INPUT to send sound from the ipod into the unit. The output is for an external amplifier for a sub.
Solution #3
posted on Nov 15, 2005
Kimi
Rank:Wiz Wiz
Rating: 80%, 620 votes
press source button repeatedly to select "CD" or "MD"
be aware that in order to connecting Ipod to a car stereo you will need to use an extension cable with 3.5 mm stereo connectors on each end to connect iPod to your car stereo system's aux input, or use a cassette adapter if your car stereo doesn't have a sound input jack. Either of these items can be purchased at stores that sell car stereo accessories.
good luck!
Can you Help with these In Dash Receivers problems?
In Dash Receivers
code for cd player
can i know the code for honda... Answer This...
In Dash Receivers
Radio Code
I need help getting my radio... Answer This...
SONY EXCD-206 December 1996
Ineed a wiring diagram for this... Answer This...
High-pitched whine in rear...
My car has a Bose Factory Amp... Answer This...
Blaupunkt Louisiana RCM 148 ......
I have a Blaupunkt Louisiana... Answer This...
Repair Service
Find In Dash Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
