Question about Compaq Presario Notebook
LAPTOP MY CD DRIVE NOT WORKING AND ALSO BLUE TOOTH NOT WORKING.I WANT SYSTEM RECOVERY BUT MY RECOVERY DISC IS NOW CORRUPTED,SO WHAT CAN I DO?
  • 53 Answers
Hello
Install your drivers or download them from producers site.
Posted on Sep 07, 2008
My HP laptop isn't booting up and saying an operating system wasn't found what do I need to do
Make sure you do not have a CD or Flash Drive in the computer and then restart. If you still get this message, your hard drive has become corrupted or has failed. Your data may still be recoverable. Pressing F10 or F11 as the computer starts should start recovery options if that part of the drive has not been damaged. If that does not work, other recovery options depend on if you have another computer or if you have a Windows install CD.
If there is important data that you have not backed up, be very very careful because the recovery process can wipe your data.
HP PCs Obtaining HP Recovery Discs or an HP USB Recovery Drive
HP PCs Performing an HP System Recovery Windows 7
HP PCs Performing an HP System Recovery Windows 10
HP PCs Performing an HP System Recovery Windows 8
Feb 14, 2017 | HP Computers & Internet
Rename C hard drive correctly.
First,you didn't post the Make, model of laptop or the OS you are using? Second have you unplugged and removed the battery in the Laptop, plugged in, rebooted? Can you enter BIOS setup? At boot try a System Restore/Recovery.
Mar 02, 2013 | Computers & Internet
Laptop start up repair
The hard drive has issues or the window files are corrupted, press ALT and F10 together this will access your recovery partition for a full install of your operational system to factory setting, if this fails use your backup recovery disc if available, now! if the CD does not work have the hardware checked out for possible replacement.
Apr 23, 2012 | Acer Computers & Internet
Windows 7 laptop won't boot to OS , only has a black screen with a blinking cursor
Insert your system recovery disc to repair your startup.
1. Change your Bios to boot from disc:
When your computer powers on, hit F2 (on some computers, F8 on others). Use your arrow keys and move to the right to your BOOT option. Hit the down arrow until you select your CD/DVD drive. Look at the bottom of your screen, and it should say to change the option hit F7 or F8. Use the specified keys, and move your CD/DVD drive above your hard-drive. Save your settings.
2. Boot from your disc. Insert your system recovery disc and restart your computer. Let the recovery disc load. If the option comes up to hit any button to boot from CD/DVD, then hit any button. Once it loads, it should come to a spot where it wants your language. Select your language, then select the option "Startup Repair". Click on it, and let it repair the startup. If it automatically starts correcting your startup then great! If not, then select your operating system from the list and click the Repair Startup option. Restart your computer, and hopefully it will boot from your hard-drive correctly.
Hope this works.
P.S. If it continues to boot from your recovery disc, then using the same method in step 1, go to your bios, and move your CD/DVD drive below your hard-drive.
Mar 01, 2011 | Computers & Internet
Toshiba U400 - when switched on the toshiba logo will appear and followed by a black screen. kindly help me with this problem. I tried F8 but F11 and pressing to reboot but nothing happens.
This probably means it can't boot off the hard disk or the CD ROM.
Make sure there's no CD in the drive.
Try holding F1 as you turn on the unit to see if you can get into the setup if it still won't boot with no CD.
Feb 28, 2011 | Toshiba Computers & Internet
Good day sir/ma'am, my problem is that every time I open my laptop, there's a blue screen flashing when I'm about to enter Windows. after that quick flash of blue screen, my system is quickly restarting....
Hi, this is clearly a corruption in Windows itself. I would recommend running your HDD based recovery (if you have one), or run the recovery discs that you got with your laptop. This will however delete all of your personal files. You can backup your hard drive before doing this by purchasing an appropriate HDD enclosure for your hard drive and plugging it into another laptop or desktop PC. Once you have done this, then run your recovery discs (or HDD based recovery). If you provide the model of your laptop, I can elaborate further. Hope this information helps
Nov 06, 2010 | Computers & Internet
I just receiver recovery and system disc from Acer to restore my laptop to factory settings. I tried couple times and followed the instructions. The recovery disc formatted partition 2 on the computer but...
Looks like your recovery cd is corrupted. You must obtain a copy of Ms Windows cd and install it using the license from the back of your laptop.If that doesn't work either its a hardware related (hdd) problem.
Aug 19, 2009 | Acer Extensa 5620-4677 Notebook
Compaq Presario C300 Recoivery Disc 2 corrupt
Hi John.
F11 process is not working and you get a NTLDR missing when you turnon the notebook.
Steps to be performed:
1. Perform hard drive self test from BIOS.
2. If it is passed then use retail version of operating system disk to install XP or try using new recovery disks which nay cost you $15.00.
In your notebook model this issue appears if there is any issue with the hard drive.
Jul 04, 2009 | HP 435768-001 - Compaq Presario C300...
Non installment of acer erecovery solution
eRecovery expects there to be both C: (system) and D: (DATA) partitions on the drive as well as the hidden recovery partition. If you use Disk Management to shrink the C: drive, and create the D: drive, things will install properly.
Oct 03, 2008 | Computers & Internet
Unable to reboot from recovery disc
if yo want to load the recovery disc, you need to find a way to open your cd drive and place the recovery disc in there. then turn the computer off, leave it for 5 seconds, turn it on again, press F8 continuously and choose 'boot from cd'. follow the instructions on screen. if this still does not work, you may need to upgrade ram, or you have bad sectors on your harddrive that has been caused by corrupt programs or viruses. Hope this helped.
Regards,
Vistapro
May 21, 2008 | Toshiba Satellite L10 Notebook
Compaq Presario Notebook Logo
20 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
