Philips FWC870 Shelf System
Problem for Philips FWC870 Shelf System
FW-C870 NO FUNCTIONS
By KLINE on Nov 12, 2005
MY FW-C870 HAS NO FUNCTIONS...NO SOUND, CD TRAY WONT OPEN, RADIO DON'T WORK.....BUT ALL DISPLAY PANEL & LIGHTS WORK FINE.....TRIED UPLUGGING, ETC
NEED SOME CLUES OR POINT ME TO REPAIR FACILITY.
SURE WAS NICE WHILE IT WORKED!
THANK YOU!........CHARLES K
Same Problem
Jul 31, 2008
-   Red light comes on but canot operate manualy or with the remote. Have unplluded and tried different outlets but nothing happens when I try any of the buttons.-   brenandlov
May 05, 2008
-   I have JVC FS-V100 and have the same problem nothing works but the power turns on
-   jhacharya
Mar 31, 2008
-   Please send user manuel -   Guest
Mar 09, 2008
-   aLL LIGHT ARE ON BUT WHEN I MASH CD OR FM THE SYSTEM CUT OFF-   Guest
Feb 20, 2008
-   My jxcd6700 will not p;ay any CDs It started by not playing entire cd and now no cds at all will play Cds will not spin on any of the slots and the Fm stereo function will not come on stuck in CD mode.-   jonnfern
Best Solution
posted on Mar 13, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
On the back panel, push the RESET button in. You can use a pen to push it in.
Solution #2
posted on Feb 10, 2008
Helpful)
Eva_
Rank: Apprentice
Rating: 92%, 2 votes
The solution I received for my TEAC DC-payer's CD stuck in it and the door did not open, was absolutly the best. I pushed the reset button at the back and it WOW worked.
Thanks to your FIX IT TEAM.
Eva_
Was this helpful?
Yes
No
Solution #3
posted on Apr 29, 2006
Helpful)
techman
Rank: Guru  Philips Expert
Rating: 86%, 7641 votes
Unless you've been inside the unit wires dont disconnect by them selfs. there are no litttle disconnecting wire knomes LOL.. Your problem is in the power regulator curcuit of the unit. Was there a storm or power surge that occoured recently?? Most likely then the unit was just tired. You can take to almost any decent repair place if you dont understand how to repair electronics But I would contact NAP (North American Phillips)first to see if theres somewhere close to you. if your not in the states then consult your operators manual and it will have a location that you can contact for service. Wish i could be more help. Good Luck
http://www.usasupport.philips.com/caseSu
Was this helpful?
Yes
No
Solution #4
Somewhat Helpful)
dovi
Rank: Guru
Rating: 88%, 2498 votes
Its look like a power problem cause a disconnected wire or a poor conntacts.
Was this helpful?
Yes
No
Solution #5
posted on Feb 09, 2008
Not Rated)
pelicon
Rank: Apprentice
Rating: 0%, 0 votes
can anyone suggest me from where i can buy a new jvc HX-D77.. i,m from india.. is it available in delhi.. please reply.
Was this helpful?
Yes
No
Solution #6
posted on Dec 25, 2007
Not Rated)
brown baron
Rank: Guide
Rating: 70%, 5 votes
Look inside the unit and try and locate a fuse inside it could be bad. If you locate the fuse look inside the fuse and see if the wire inside is broken, if it is, replace the fuse.
Was this helpful?
Yes
No
Popular Solutions for Philips FWC870 Shelf System
Questions and Unsolved Problems for Philips FWC870 Shelf System
Do you recommend Philips FWC870 Shelf System?
Answer
Answer
powers on has no sound have to hold buttons on panel that has cd/fm/am/tape to keep the light
Answer
My Yamaha GS-5 Mini Shelf system will not play CDs. When I turn on the power, the CD shelf... (More)
Answer
doesn't matter which CD slot - Perpetually says "No Disc" even though there are discs in... (More)
Answer
I use my unit as my sound for my PC and it sits on my home office desk. I was moving my unit so my... (More)
Answer
The "co not finalized" messagge appear with all kind of cd. I use original cd's (not... (More)
10 Other Users Have The Same Problem - Continued
Comment by Eva_, posted on Jan 10, 2008
My TEAC DC_D2831 digital Hi-Fi System 3 CD payer door wont open, the CD is stuck inside.
Comment by Guest, posted on Dec 15, 2007
power wont stay on i have to unplug to restore but it keeps shutting down
Comment by TiaMarie, posted on Dec 11, 2007
I have the same problem except its just that the cd is stuck half way out. it sounds like it is trying to either open or close, but for some reason it wont.
any suggestions?
i also tried unplugging it, and checking the wires. everything is plugged in just fine.
HELP
Comment by Guest, posted on Nov 27, 2007
jvc hx-d77 shelf system im trying to open the cd track but it says lock is their a lock why it wont open
Comment by Guest, posted on Nov 16, 2007
Doesn't turn on... I am in India, 220 and I have used a transformer.. from 220 to 110. Help!!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Audio Shelf Systems Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
