Teledyne Laars Platinum II gas heater for spa/pool Heater will not startup, it has electric start, no pilot light. Repeated startup procedure listed on the front cover, but does not light up. Thanks, Patrick
sloooo44
  • 235 Answers
SOURCE: I have an older Teledyne
You need to see what what pressure is required to turn the heater on. If you don't have enough flow or pressue, the heater will not ignite. Was it working before?
Posted on Sep 28, 2010
IFIXALL
  • 868 Answers
SOURCE: teledyne laars pool heater wont kick on
The safety valve isn't opening .It's very possible that a spider is trapping the opening of the orifice.
Posted on May 26, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Pool heater
Make sure gas valve is turned to the "On" setting. If it is, you may have a bad thermostat or break in the wiring. Check for mouse chewings.
Posted on Jun 02, 2008
tborn6
  • 700 Answers
SOURCE: I have converted by Teledyne
did you also change out the oriface to the pilot assembly. you have to do that, also do you have a manometer (preferably digital) to check the gas pressure on theinlet and outlet of the gas valve? do this and set it up to the manfacture's recommendations and you should be good to go. Thanks for using Fixya and Merry Christmas!!
Posted on Dec 25, 2008
shuggie73
SOURCE: Laars lite II Pool and spa Heater LG model
Bad pilot generator? Flow issue?
Posted on May 25, 2009
How turn on pilot on teledyne laars series 2
turn gas valve to pilot hold down for 1 minute keep holdibg and light pilot hold for 2 minutes then turn to on
May 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Jun 15, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
570 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
