Question about Aiwa XR-M55 Shelf System
Noisy transformer after about 10 mins use, my XR-m55 has a terrible buzzing noise coming from the main(big) transformer/powersupply, it would appear I'm not the only one with this problem. Is there an easy fix without replacing the transformer? If not what are the specs for the transformer so i can buy a new one.
    Novelist:
    Champion:
  • 277 Answers
Read here for the all the unit specification: http://www.fixya.com/BrowseManual.aspx?prdid=199676&hlt=specification&mnlid=1020&__PAGED_=33
Posted on Nov 15, 2005
Peavey XR 122D powered mixer developing hum noise dispite pressing the noise filter. anything more to be worth doing?
I need a bit more information but from what i can tell it's about the power supply capacitors issue, as this devices are known to develop such kind of humming annoying noise when they go under the specified value, let me know further,
Regards.
Jul 20, 2014 | Peavey XR 1220 Powered Mixer Mixer Powered
Viking oven buzzes all the time when not in use
the low voltage transformer on the ERC control is vibrating from not doing anything,when you put a load on this transformer it will quit,only fix is to possibly remove ERC and jam a piece of NON-Flammable/NON-electrical metal to keep it from vibrating and try this first,if this doesn't help,replace the noisy board with this transformer on it
Jan 12, 2013 | Viking 27" Professional Select Built-in...
I have a buzzing noise coming from the back end of my ford explorer after I turn the car off it comes and goes for about 5 mins after than stops . The noise
I think you are hearing the electric fuel pump running, when they get old they can get fairly noisy and it is buzzing sound.
Feb 23, 2012 | 1997 Ford Explorer AWD
Chrisaclementsgettying buzzing noise from motherboard and won't start
The "Buzzing" may come from the fans.
There are fans in the powersupply, on the CPU, in the front.
It could be a faulty:
- powersupply
- motherboard
Aug 18, 2010 | Dell Dimension 9100 PC Desktop
Bugera 333xl every few seconds there is a loud buzzing. from
It looks as though you have ripple noise that amplifies into the output. First of all check if the mains voltage is going down to produce the low voltage hum. If not you will have to check the DC filter capacitors , couple in parallel to confirm the capacitor. IF the buzz is still coming through then you will have to isolate the preamp and wait it the fault is coming in. If not connect the preamp output to another amp to hear the same buzz to confirm the preamp to be faulty. If so you will have to trace by a voltage check when the buzz occurs to confirm if the preamp IC or the selector Ic is faulty. Some logic IC's can also produce this noise on static switching. If teh noise is appearing on both the channels, then I would still bet on the power section. So check once again on the rectifier/ regulators and capacitors. Hope this advice helps. Good day
May 16, 2010 | Audio Players & Recorders
Tape deck won't open Aiwa XR-M55
I think the main drive belt is worn and I am going to buy a new one when I find a source.
Feb 24, 2010 | Aiwa XR-M55 Shelf System
A couple of weeks after initial setup of my brand new Onkyo XT-SR606 receiver, I noticed a loud buzzing noise that starts up approximately 10 min after the receiver is turned on. The buzzing is definitely...
The "buzz" you hear is a power hum made by the power supply transformer. It's technically called "Lamination hum" caused by the revering of electrical current through the power supply transformer. In some cases the hum can vibrate the chassis causing other loose material to vibrate. If you can, go to your dealer and check to see if other units of this same type typically make a hum this loud, and if not, see if he can solve the problem for you.
Feb 27, 2009 | Onkyo TX-SR606 Receiver
Buzz in amplifier power transformer. The amp is a Marantz Model 240. It functions perfectly well, and there's no noise from it in the speakers, but the transformer buzzes whenever the unit is plugged in...
All transformers buzz though you cannot hear it normally. The big transformers on power lines like to buzz for all to hear. When a transformer in a stereo amp gets old and deteriorates or gets hot and  expands the coils, melts the coil varnish and epoxy coatings then rattles at 60 times per second.    You can ignore it or change the transformer. There are too many layers of windings to try to stick anything in there.  Disconnecting a transformer results in inductive kickback -that's not money. It's a big, whopping electrical gotcha! Be careful! Good luck, Steve Medley
Nov 09, 2008 | Marantz Audio Players & Recorders
Noisy magnatron
First of all, if you press against the right side of the outer cover of the oven, does that lessen the noise? If so, it may be that a rubber cushion on the side of the HV transformer has fallen off.
If it had that hum but was not heating, I would first check the HV rectifier diode.
But since it's cooking, I would say your magnetron is on the way out.
Unless the warranty is about to expire, I'd continue to use it and watch and wait.
Apr 06, 2008 | Sharp R-520LK Microwave Oven
Aiwa XR-M55 Shelf System Logo
258 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
