Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-73827 with degrading color
2 yr old TV. Picture comes on fine but after 30 minutes or so it begins to degenerate into darker, fuzzier tones with purple faces and psychodelic-like color splotches that change with the background color. Sound is never a problem.
  • Anonymous Nov 28, 2008
    execpt for my tv being a year older i have the exact same problem, Degrading color,purplish screen after 20-25 min
  • Anonymous Dec 18, 2008
    We purchased WD73827 Mitsubishi in lat 06 and have had the same problem with the light engine twice and also with the lamp cartridege. The customer service at Mitsubishi in horrible to deal with. You would think with after paying so much and the high quality tv this is suppose to be, they would stand by their product more. The first thing they ask is if we had an extended warranty. We do, but if they were standing by the quality of the tv that shouldnt be a question.
  • 927 Answers
Good Day;
More then likely your 2005 MODEL has a bad "LIGHT ENGINE". Call an Authorized Service Center and have them give you an estimate, then call MIT's and try to get them to give you a "CONCESSION". It's costly. Good Luck, big IRISH.
Posted on Sep 23, 2008
Sound no picture
Like stated before--May be another bad blub, especially if you used a generic or Neolux one. A phillips bulb WILL work right. Mits sets do NOT like generic bulbs !!
Apr 05, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
How do you hard reset an Mitsubishi WE65737?
Hello
Plug out it from the wall power socket, and wait for at least 30 minutes or so. It will be best to unplug it overnight. OK.
Jun 29, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
How do you do a convergence on the wd73286?
Mitsubishi WD-73286 is DLP tv that does not have any convergence circuit inside.
Convergence is required in old model rear projection tv that has three basic colors picture tubes to generate color picture that projected on front screen of tv.
DLP tv has light engine to generate picture, it is similar to multimedia projector that throws its picture on wall.
Hope this info will help.
Thanks.
Mar 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a 2 year old Mitsubishi WD-73732 - 1080p 73" Medallion Series DLP HDTV - WD73732. I am getting blotches of color when there are large areas of blue color. Looks like irregular moving stains...
It will cost you probably in the area of $700.00 to replace the Light Engine. I don't think it would be a good idea to repair it. DLP sets have been out of production a few years now due to high failure rates of the light engines for all makes and models and the consumer cost for the lamp.
Nov 10, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a 6 yr old Mitsubishi DLP WD-52327 does not fire up... When power is turned on tv makes a noise like a small air compressor for a few seconds and then stops after about 1 minute it does it...
No.The tv have a colors wheel is dead.The colors wheel make loud motor noises,squiling noises and flashes picture with black&white.The colors wheel is dying and spinning off of it motor axis.Hire a Tv Tech. to change the colors wheel.Because is require take out alots machanical parts,before u can even come to the colors wheel itself to replced.
Oct 23, 2010 | Televison & Video
Picture flashing, weak color. whenflashing stops
I have the same problem with a WD 73732. After about an hour fleshtones go blue / purple, and picture flashes. I gutted the set, and ran it on the bench, and found that a sensor on the color wheel (a small external board), acts up when it gets hot. Cooling the board fixed the picture. I'm going to try to find a replacement part, and then make vents in the color wheel cover so it doesn't get so hot in there.
Jan 22, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Picture getting darker over the years
It could be your Light Engine. However, I would first check a few things:
1. Make sure your Low Power/Lamp settings are adjusted so that they meet your brightness needs.
2. Make sure you used a Mitsubishi original lamp, as generics get chewed through fast and hard.
3. Try another lamp; sometimes you can get a bad one in the bunch.
All those things don't work, consider a Light Engine ($400 + for parts; $300+ for labor)
Mar 11, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
119 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
