JVC KD-LH7R CD Player
Problem for JVC KD-LH7R CD Player
Not working "at all"...
By HOSTAKI on Nov 12, 2005
Yesterday I was trying to fix this litle storage thing under my radio and while removing it I also disconected my radio unit .
When finished I reconected but nothing seemed to be working .
Its not a power loss cause when I press the "display" button it shows the time it seems to be "on" ...
The other task it does is when opening to insert a cd it does, its just fine ... and eject it ..
-but not play it .
The tuner is also "dead" . Generally is not working .
It has a reset button, which i presed but only resets the display time ...
How am I going to find out whats happened ?
The troubleshouting section of the instructions say that :
when "the unit does not work at all" then "the built-in microcomputer may function incorrectly due to noise etc."
And the cure is to reset ...
But no ..!
Same Problem
Apr 12, 2009
-   I have all the wires hooked up but i get absolutely no power to the radio... Bout ready to chunk it and watch it brake to many peices
Can anybody give me a hand here/?-   cujo83108
Dec 21, 2008
-   after taking my mercedes 320 ml to be repaired, the radio sound stop working and the cd player now says cd player not intalled? what do you think happened?-   bigst
Dec 16, 2008
-   my 6 cd changer will not work in my mercedes benz cna you help me bc its keep sayin no cd -   drjame3
Sep 08, 2008
-   i recently installed a boost gauge and ran the power from the remote cable. the alpine head unit did work for a few days, but now has completely shut off. The head unit fuse and car radio fuse are fine, Have i destroyed the unit? What can i do now? and yea the boost gauge is working-   king_thang
Aug 27, 2008
-   NO sound, AM, FM, CD, Weather etc. Have removed radio and cleaned the contacts. Have reset the reset button. Only static, volume changes, stations change. -   boomer3304
Best Solution
posted on Aug 19, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Does it have a remote? if it does, there should be "PWR" button. try that, it seems to me that you head deck is in clock mode. cheers.
Solution #2
posted on Apr 10, 2006
Somewhat Helpful)
Jexx
Rank: Guru
Rating: 85%, 266 votes
Ah, easy! The ignition wire isn't connected anymore or is not getting any power! Check the connnection on it and all fuses!
Was this helpful?
Yes
No
Solution #3
posted on Aug 19, 2008
Not Rated)
temesgenf
Rank: Apprentice
Rating: 0%, 0 votes
I had similar problem and found out I had blown a fuse when connecting the wire.
So I suggest you check your fuses first, if it is burnt verify your wire connection, correct as necessary and replace your fuse. This has fixed the same issue you all had described above (Display turns on and CD eject works but no power).
Another way to test/diagnose the problem is connect your old stereo; if fuse is burnt you should get no power to your stereo. Hope it helps
TF
Was this helpful?
Yes
No
Solution #4
posted on Sep 29, 2006
Not Rated)
frizdag
Rank: Apprentice
Rating: 100%, 1 votes
Ah, I'll check that out I'm having the EXACT same problem! :) Thanks.
Comments:
Sep 29, 2006
- That fixed it! Thanks for the awesome insight!
Was this helpful?
Yes
No
Popular Solutions for JVC KD-LH7R CD Player
Questions and Unsolved Problems for JVC KD-LH7R CD Player
Do you recommend JVC KD-LH7R CD Player?
Answer
Answer
ive got a standard stereo in my 06 mercedes vito van and the cd has jammed inside how can i get my... (More)
Answer
Mercedes-Benz 6 disc CD player # A 203 820 90 89 MODEL # MC 3010 To replace the above with a new... (More)
Answer
I have a 2003 E320 - The problem I'm having is when listening to the cd player or radio the power... (More)
Answer
convert audio tape to cd what free downloadable program can i use to do this
Answer
Whenever I click on CD it says NO CD installed. I dont have Single CD Player installed but do have... (More)
23 Other Users Have The Same Problem - Continued
Comment by jacobjohn34, posted on Aug 24, 2008
i hAVE THE JVC sk-980 and i can press display and see the clock but it doesnt turn on..help!
Comment by Guest, posted on Aug 15, 2008
i wanted to fit this unit to my caravan but cannot get it to work at all can anyone help regards he wiring side of things thankyou
Comment by darknezfalz, posted on Jul 24, 2008
i have a similar problem with my p4800mp. How do you reset the unit? Also, my source button doesn't work. I am not able to turn the unit off nor switch to AM/FM. Anyone got any ideas?
thanks
Comment by Guest, posted on Jul 05, 2008
cd does not work , it say to eject cd
Comment by Guest, posted on Jun 26, 2008
turns on no sound
Comment by shakespear91, posted on Jun 20, 2008
hi, i have a cda 9812rr. the problem is that it dosen't work! it lights up just fine and then you can't use it. the buttons are locked, no matter what you do it just beeps when you press a button. i tried to do the reset but everytime you turn it back on it starts right back again with the buttons locked. please help i love this radio!!!
Comment by ebluebill, posted on May 18, 2008
player worked fine one day, then next day it shows IT HAS POWER but no sound comes out. I have checked the wiring behind the radio, and it all seems fine....no loose wires. Would there be a separate fuse for the speakers for some reason? Seems like alot of folks have same problem but no one has a solution.
Comment by Nicas, posted on Apr 27, 2008
My kid hit the on Volume button, and then the radio kept a high volume I stopped the Car turnrd of and from then my radio is dead.
Comment by madmachines, posted on Apr 25, 2008
Hi all. I too am having the same problem. I can put CD's in and they load, I can change between tuner, AUX, and compact disc - but no matter what I do, there is NO SOUND whatsoever. This just started happening. I have reset the head unit many times now but not one of the reset attempts helped any.
Anyone have any ideas that might help? The only response to any of the problems I have seen posted is to check for power but I definitely have power.
thanks for any help.
Comment by jakeq, posted on Apr 20, 2008
i just put this radio into my new car. first time i tried it, it worked fine. now however it doesnt turn on. unless i press the display button when it only displays the time. what is going on ???
Comment by jph8158, posted on Apr 05, 2008
I have removed the face plate and the red led lite is flickering so I seem to have power. When I reattach, I cannot get the unit to power up.
Anny suggestions
Comment by Guest, posted on Jan 13, 2008
same exact problem. :-(
Comment by amediaz, posted on Dec 26, 2007
I have the same probleme on my KD-S890 i reset it, but nothing, it give the time, the cd can go in and can be ejected, that's it.
thanks
amediaz
Comment by Guest, posted on Dec 22, 2007
where is the reset botton at on the radio
Comment by Guest, posted on Dec 01, 2007
Unit just stopped working. Only the CD will play but repeats same track over & over. Tried cleaning with alcohol, but to no avail
Comment by TJsargent, posted on Nov 25, 2007
i recently set up my subwoofers and amplifier in my car. i took out my panasonic cq-c1100u but didnt unplug anything i striped off an inch of wire so i could attatch my remote turn-on wire to it and electrical taped it so there were no bare wires showing. i pluged my RCA cables to the pre-out plugs and put it back in. now it wont even turn on at all. it said security behind the faceplate but the light wasnt flashing when i took it out. i need help. did it die on me or should i just get another player?
Comment by Guest, posted on Nov 21, 2007
Greetings!! I have the same problem, but first it's started with the turner and then with the CD player. Some times the CD play and others not. I check DC power, check fuse, check the turner antenna, check the ground and still works in time to time. ¿¿What I have to do??. Thanks.
Juan H.
Comment by bulls31, posted on Nov 15, 2007
i bought a brand new kenwood kdc-w534 connected the wires but the face part does noy light up or come on i can hear the cd unit moving but thats it
ive done a circut test and all the wires are fine
can anybody help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top In Dash Receiver Experts
Top Audio & Video Equipment Repairmen
in , CA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
