Peavey SP2 PA Passive Speaker Logo
Posted on Aug 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just purchased 2 old Peavey SP-2 and SP-3 speakers. How do I wire from the crossover to the speakers so the horns and 15's are wired in correct.
Fred Yearian
Level 3:
  • Peavey Master 5,603 Answers
  • Posted on Aug 16, 2011
Fred Yearian
Peavey Master
Level 3:
Answers
5603
Questions
Helped
2248550
Points
16162
These cabinets are self contained and you do not use a crossover with them. The speakers do NOT come out to separate connectors. You just drive these with an amplifier. DO PAY ATTENTION to the power rating... you are safe using an amplifier with a MAXIMUM of 150 Watts RMS per speaker cabinet. More than that and running them loud and you will be replacing the speakers. These will cover a 40 foot square room at comfortable level.
I have a pair of peavey sp-2xt speakers if i use the full range input the horn would not work but if i plug it direct to the hi input it works .any sugestions to fix problem thanks
There is possibly a bad solder connection or component on the crossover. I cant remember if that crossover uses a 12volt light bulb or not, for DC current protection, if it does make sure the bulb is good.
Sp 3g crossover wiring color code
Horn is red +, black -, mid is white +, blue-, lows are yellow+, blue-. If you look at the crossover board, you'll see the treminals are labeled what goes to where.
In Peavey cabinets, the woofer is always Yellow + and Blue - and the horn is always Red + and Black -. On the mid the remaining two wires would be the lighter color + and the darker color -
1helpful
PROPER WIRING FOR ATTACHING CROSSOVER TO PEAVEY SP4G SPEAKERS.
In Peavey cabinets, the lower woofer is always Yellow + and Blue - and the horn is always Red + and Black -. On the middle 15" the remaining two wires would be White + and Blue -
Is there a fuse in a peavey sp2 for horns
there are 2 of them in the new ones....but ya probably the blew diaphrams...unless they are old one...then it could still be in the crossover..need to know the exact SP2 model you have, as they have changed the speaker again and again over the years.
2answers
Peavey sp2xt speakers horn makes no sound when plugged into normal input. Horn works fine when plugged into the high side of the crossover.
High side speaker input jack defective, as they are switch also and if you plug the wire from the amp in full range and no hf sound but connecting directly to the bi-amp hi does, then your female 1/4 plug at crossover is defective for sure.
Titanium high frequency drivers not working. Is there a fuse in crossover?
i) I believe you can access the fuse by removing the Input Jack Panel.
ii) If fuse is OK, then unscrew the horn unit, take off one speaker wire & measure resistance. If it is open circuit then you can order a replacement horn diaphragm (if you feel confident to fit it to the horn).
2answers
Whats the wattage of the bulb used in peavey sp2 crossover, my sp2 peavey speaker bulb is blown
The lamp is an "1156" lamp... replace with that part number. Here :
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=524517&k=lamp%201156
Or you can find it at auto parts store.
LIKELY the polyfuse device is ALSO gone... Probably similar to this one (1.1 amp, trip 2.2 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2010-ND
or this one (1.85 amp, trip 3.7 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2013-ND
2helpful
Wiring problem on kb 300
You have probably bypassed the crossover that directs different frequencies to the appropriate speaker/horn.
The speakers are designed to be used the way they were delivered. It is easy to damage them when connected wrong.
I would suggest you restore the circuit to the way it was designed to avoid damage to speakers or the amp.
I have a set of peavey scorpion sp5xt's one works fine but if i plug into the other one ,in full range, only the horn works,
Horn and speaker combo cabinets have an electronic component called a "crossover". The horn and speaker both work off different electrical signal frequencies. If you can take off the back, or get inside by pulling the speaker, check for a small circuit board mounted inside the box or on the speaker or horn. Check for a broken wire or loose connection of the crimp connectors.
A common problem with speakers, often the cone, or paper part of the speaker will come un-glued or separated from the magnet "voice coil". This happens when played too loud, when it's commected to the wrong impedance, or if the signal was shorted and "overdriven" (usually sounds like an awful buzz that's really loud).
Always make sure your output impedance matches the impedance of the speaker. Most auto stereos are 4 Ohms. Older home stereos are typically 8 Ohms. Musical PA gear varies between 4, 8, and 16 Ohms. Peavey gear is typicall 4 Ohms, but some older models are different. The Ohm rating is the amount of the resistance in the circuit. If your speaker is 4 Ohms and you plug it into an 8 Ohm circuit, you can destroy the speaker and sometimes the crossover circuit board.
Good Luck.
Jim
[email protected]
Phoenix, Az
Jan 09, 2009 • Music
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
