Freeview box just bought a second hand dt16300 trying to scan for tv channels,after ive scanned which it does succesfully how do i save them,it just keeps telling me to scan all the time.do i need to pay subscription to wath freeview i thought i only needed to pay for top up tv
  • 19,396 Answers
After scanning the box should save the channel automatically. If the box does not save the preset after scanning channels, then it is probably faulty.
Some box has a pinhole reset button at the back, if you have this reset button keep it pressed with a pencil for 10 seconds to reset the freeview box.
If it does not work, the nbox is probably faulty.
With freeview you only pay for few scrambled channels, the most of them are free and do not need any additional fee.
Freeview is not available in all areas, check that you have freeview in your location, and that aerial is well connected to the box, otherwise not finding channels is normal.
Posted on Sep 05, 2008
Alba set top digital freeview box
normally its - press menu - install - scan for channels and then save
something similar to this
hope it helps davetech
Aug 08, 2014 | Alba DVBT set top box
Insignia channel auto scan
If its cable and requires a box the set will have to be on a specific channel---if directly from wall etc go into set menu and make sure it is set to CATV or cable----if in air or antenna it will not save channels.
Jun 13, 2012 | Televison & Video
How to tune freeview for digihome PVR80 it wont record bbc how to fine tune it .when we had to re-tune for channel 5 it worked perfect so please tell me how to do that again
On your remote control, press 'menu'.
Then select 'set up' on the screen.
Then select 'Installation' on the screen.
Then select 'Automatic channel scan' on the screen.
The box should then scan for all channels, and with luck BBC will be included. If not, please repost. Some older Digihome PVR80s can't cope with the new multiplexing standard employed by digital freeview.
May 07, 2010 | Televison & Video
How do i save my scan on a Bush BTU160DTR freewview please
On some freeview boxes i have found the only way to get it to store a fresh scan is to find in the menu a factory reset,this deletes all stored channels and the saves the new scan(can be called new installation) i hope this helps?
Apr 27, 2010 | Televison & Video
Bought a new 32inch tv with added freeview. I have a ferguson dvd/vcr combi which has tuned channels 1 -5 ok but how do I tune the digital channels
You're going to need to use your menu button and do a channel scan.
When it completes use the save option if present and exit the menu.
Mar 11, 2010 | LG Televison & Video
On the Library section of the DT16300 I have approx 8.5 hours of saved programmes yet the display says there is only 18% of disc space left! out of 60 hours recording time?.
After Re-loading the Freeview Channels on 30th Sept, the disc space was nearly full on The Thomson DT16300. Go to Set up in the Menu, choose 'Personal Favourites' this will bring up all the stored Channels, For some reason a lot of the Channels are marked 'ON' each one takes up disc space. De-select every one, the channels stay in the recorder but release disc space. I now have 86% free. Trevor Rushton
Oct 02, 2009 | Televison & Video
Similar problem
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Oct 01, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
No freeview bbc channels
just solved the problem
with the variable attenator fitted i did a rescan still didnt work
but when i did a rescan to the restore factory settings it now works
Nov 24, 2008 | Televison & Video
No channels can be detected have tried 2 Daewoo DS608P boxes connected to same telly but same thing happens. Signal strength seems fine boxes have been working fine for years.
I am the same. Not a sausage from my same model Daewoo freeview box today. Scans and re-scans and not a single channel to be detected.
Rob
Jul 05, 2008 | Televison & Video
My Thompson Freeview box keeps stuttering/time lapse freezing.
Hi Ive just bought a thomson dtr box and the picture keeps freezing .new arial new cable etc.well ive just tried a £20 freeview box and its fine good clear picture and dosnt freeze.I had a good signal when using the thompson box and its the box load of rubbish taking it back to shop.
Apr 14, 2008 | Televison & Video
Televison & Video Logo
266 people viewed this question
Top Televison & Video Experts
Electro Med Services...
