Question about Canon CLC 1120 Color Copier
E020 02FF Error
I have a CLC 1100 that is giving me a E020 02FF error. I am a former CLC Tech. I worked for Canon Business Solutions but have been out for some time now. Just need to know what the subcode means. I know it is a problem with Cyan.
Thanks
Bob
  • Anillll Feb 28, 2009
    SAME PROBLEM
    Problem Solver:
  • 5 Answers
The problem this in tolva of cian
Posted on Nov 23, 2008
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
CANON CLC 1100 ERROR CODE E079 CAN YUO HELP ME?
Have you tried to reset? maybe you can reset first meanwhile I will be looking for further solution
Feb 18, 2008 | Canon CLC 1120 Color Copier
Error Code: E071 0007
I got an error code on my canon clc 1100:
E071 0007
Aug 19, 2010 | Canon CLC 1110 Copier
Error code e020 with sub code 140 on canon clc
This code refere the developing assembly locking plate.Please verify the plate mounted and the developer sensor,the toner hopper sensor or the toner hopper motor.
Dec 12, 2009 | Canon Office Equipment & Supplies
Canon CLC 1100 E072 0202
E072 0202 means :
The transfer drum cleaner brush motor (M8) is faulty.
The polishing roller motor (M9) is faulty.
The motor drive system is subjected to an overload.
The attraction/transfer locking cam motor (PM7) is faulty.
The attraction/transfer locking cam HP sensor (PS8) is faulty.
The registration path driver PCB is faulty.
The DC driver PCB is faulty.
The CPU PCB is faulty.
The attraction/transfer looking cam HP sensor does not go '1' within 4 sec after the attraction/transfer locking cam motor has started to rotate.
May 06, 2009 | Canon CLC 1000 Color Copier
Error code E000001-0003 on Canon CLC 3200
E001 on a canon is a fuser problem. check to see if the fuseer lamps come on, if yes then the problem is a Thermistor (controls the temperature of the rollers) change.
Jul 16, 2008 | Office Equipment & Supplies
CANON CLC 1100
Transfer frame connector try pulling out the transfer drum and look to th rear of the machine and see if there is any paper stuck in the female connector at the rear of the machine.If the problem persists change thr connector.If you need more help get back to me 00447764303923 i am in the uk
Feb 16, 2008 | Canon CLC 1120 Color Copier
Error Message E020, 0400 for canon CLC 1120 Color copier. please give your assitance
This error has to do with Toner concentration of the Black ( 04 ) part of the sub code. The "00" has to do with the reference level or signal value for black. Look to see if the Black toner sensor is soiled. You have to swing out the toner hopper assembly to access the sensor. You will see two thin gray cables coming down from under the control panel. Since you have access to both assemblies - toner and paper jam detect - carefully remove both and clean with canned air. Be careful since you are so near to the $800 drum. Replace both and test. If you still have problems and the drum is old, several years, and has over 40,000 copies on it, you may have to have the drum changed and I recommend a tech do it. Good Luck.
Oct 29, 2007 | Canon CLC 1120 Color Copier
Canon CLC 1120 Color Copier Logo
285 people viewed this question
old marine
old marine
