Question about Nikon F4s 35mm SLR Camera
Will not auto focus
Motor winds lens in and out, but will not autofocus, just shows red X and locks shutter out
    Novelist:
    Champion:
  • 277 Answers
"... Autofocus Lock ("AF-L"). Pressing the AF-L (Autofocus Lock) button enables the Nikon F4 to lock the focus. Simultaneous lock of AF-L and AE-L is possible. "'FREEZE FOCUS" - is another great function in the F4. It allows automatic shutter release when subject enters a pre focused distance - available with Nikon MF-23 and/or the 250 exp. MF-24 Multi-Control Back. i.e. with the shutter button fully depressed, the shutter is automatically fired when a subject comes into a preset manually focused position. This function is recommended for sports races because the racing course is usually known beforehand. It also works well in wildlife remote control photography, scientific, forensic and other technical photography. ..."
Posted on Nov 15, 2005
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
I got this lens (Nikon AF NIKKOR 50mm f/1.4D) for my D3100 and it doesn't autofocus. I don't knowhow to intervene since there's no switch on the lens itself (because I understand it is small and it doesn't...
The D3100 can't autofocus with this lens. The D3100 does not have a focus motor, depending on the lens to have one. The AF-Nikkor 50mm doesn't have a focus motor, depending on the camera to have one.
To autofocus, you need lenses designated AF-S.
Dec 24, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Jan 02, 2010 | Nikon D3000 Digital Camera
I have a nikon d-40 is there a seeting on it that well let the cameras lens focus when you push the button half way down. I took picture but I had to manual focus I don't know if it the lens or this camera...
Any of the autofocus settings will attempt to focus when the shutter is pressed halfway. What lens are you using? If it doesn't have an internal focus meter, then the D40 won't autofocus with it no matter what. If it does have an internal motor, then check to make sure the lens is set on autofocus.
Check Custom Setting 12. If it's set on AF-On then the shutter button won't focus.
If this doesn't fix it, specify the lens and any other details.
Oct 09, 2009 | Nikon D40x Digital Camera
My nikon d70 wont focus at all
  • Make sure both lens and body are set for autofocus. There are two switches near each other with "AF" and "M" settings.
  • Check the camera's focusing settings, or do a factory reset (from menu) to 'start over'. Usually helps to have AF-Assist on.
  • Try setting the AE/AF-lock button (upper rear, near right thumb when holding camera) to turn on AF. The camera may respond better to this than half-pressing the shutter release.
  • Make sure the lens is fully attached to the camera. You shouldn't be able to rotate the lens without depressing the lens release button, and you should be able see a tight seal between the two.
Jun 23, 2009 | Nikon D70s Digital Camera
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT...
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
Jul 14, 2008 | Pentax K100D Super Digital SLR Camera
Nikon d40 autofocus
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Jul 11, 2008 | Nikon D40x Digital Camera
Nikon d40 digital camera
When the camera is in auto focus mode, it will not take the picture until it locks onto a subject. If there is not enough light, the camera will "hunt" for something to focus on. Since it can't define any edges, it won't allow the shutter to release.
The D40 base model does NOT have a powered focus lever for autofocus, so if the autofocus is not working, suspect the lens.
Mar 23, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 autofocus
This happened to me once on a D70... When mounting the lens, make sure it clicks in all the way when turning counterclockwise. Also it may be worthy to note that both the lens AND the camera must be set to autofocus mode ("A" switch set on both lens and cam).
Marky
Nov 25, 2007 | Nikon D40x Digital Camera
Auto focus
there should be a tiny little switch on the lens that shows 'AF' and 'MF'.  Make sure it is on 'AF' for auto-focus.  Also, is the lens rotating and locking fully?
Oct 11, 2007 | Nikon D50 Digital Camera
Nikon F4s 35mm SLR Camera Logo
292 people viewed this question
Top Nikon Photography Experts
Ric Donato
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Nikon Photography Expert? Answer questions, earn points and help others
