Question about Apple iPod MA446LL/A MP3 Player
Grays songs in ipod when connected to Computer
First, my old windows 2000 computer crashed. I got a new Windows XP(still deciding if that was the best choice).
So I had to transfer all my songs from my I-pod onto my new computer and new I-tunes...difficult and annoying!!!
However I successful resorted to a third party to do this and I got all my music from I-pod to my new computer/I-tunes. And everything is synced. However when I go to my I-pod's (when it’s plugged into my computer) the music is gray and I can't click on it or make playlists or move it around. When I click on manually manage for some reason, the songs are not gray anymore, and I cant move stuff around. BUT I want to be able to plug in my I-pod though without manually managing and to update and sync itself.
So basically....
My song play from my I-tunes library on my computer fine
My songs play from my I-pod itself fine
But my music library(on my i-pod) when connected with I-tunes on my computer is gray unless I use manually manage and I do NOT want to, I want I-tunes to automatically update? Does anyone have a clue what to do? Am I clear enough on the problem?
You need to set your iPod to update manually, instead of syncing automatically when you plug it into the computer.
To do this, plug your iPod into your computer, and on the iPod info screen that pops up in iTunes when your iPod is connected, click "Manually Manage Files."
You'll now have to click and drag your songs from your library to your iPod, but now you can also play songs on your computer directly from your iPod and delete songs from your library without deleting them from your iPod at the same time.
Hope this helped!
Posted on Oct 19, 2008
Ipod classic won't sync with itunes 10
Restarting your computer is often the solution when your iPod fails to sync with your iTunes music library. But if this fails, there are other troubleshooting steps to take.
Recharge your iPod via a USB cable connected to your computer or AC adapter. b> Click the help menu in iTunes and check for updates. Follow the onscreen prompts to download and install the latest version of the software. Open the new version of iTunes. Click the name of your iPod in the source list and check for updates under the summary tab to update your iPod. Attempt to sync your iPod with iTunes. Slide your iPod's hold switch to the hold position and then to off. Press and hold the menu and center buttons simultaneously until the Apple logo appears to reset your iPod. Open iTunes on your computer and reconnect your iPod to try to sync it with iTunes. Restart iPod service b> Close iTunes and make sure your iPod is disconnected from the computer. Click the 'start' button. Click 'run' if using Windows XP. Type 'services.msc' in the run box in XP and in the search box in the start menu in Windows 7 and Vista. Press 'enter.' Scroll through the list and double-click on 'iPod service.' Click the 'stop' button and leave the properties window open. Connect your iPod to the computer. Open 'my computer' or 'computer' and look for your iPod listed in the devices with removable storage section. Click the 'start' button in the iPod Service's properties window. Open iTunes to attempt to sync your iPod. Close the iPod Service's properties window once your iPod has finished syncing. Resolve "Original File could not be Found" Double-click the name of a song in the iTunes program that failed to sync to your iPod. Click 'yes' or 'locate' to the message asking you if you want to locate the file. Navigate to the folder or directory location where the song is stored on your computer. Double-click the song file to select it and add it back to iTunes. Reconnect your iPod to the computer and open iTunes to restart the syncing process. Some songs in iTunes won't copy to iPod http://support.apple.com/kb/TS1420 iPod classic Troubleshooting Assistant
http://www.apple.com/support/ipod/five_rs/classic/
Apr 12, 2013 | Apple iPod MA446LL/A MP3 Player
Tip
How to fix a error 48 with itunes
The message does not indicate that there is an issue with the iPod but that that iTunes was unable to read the iPod software update it uses to restore or update your iPod. You can delete the folder containing the iPod software update files so iTunes can download a new copy of the iPod software update.
Here are the steps to take if you get this message:
Eject iPod and quit iTunes.
Use Disk Utility in Mac OS X or run chkdsk in Windows to verify there are no other issues on your hard drive.
Locate the iPod Software Updates folder:
In Mac OS X, the folder is
/Users/username/Library/iTunes/iPod Software Updates
In Windows Vista, the folder is
C:\Users\username\AppData\Roaming\Apple Computer\iTunes\iPod Software Updates
In Windows XP and Windows 2000, the folder is
C:\Documents and Settings\yourusername\Application Data\Apple Computer\iTunes\iPod Software Updates
Note: If you don't see the files in Windows, turn on the Show hidden files option.
Windows Vista: Open Computer and choose Folder and Search Options from the Organize menu.
Windows XP and 2000: Open My Computer and click Folder Options from the Tools menu.
Click the View tab.
In the Advanced Settings pane, select the "Show hidden files and folders" button.
Click OK.
Drag the iPod Software Updates folder to the Trash or Recycle Bin.
Connect iPod and open iTunes. You will need to be connected to the Internet to download the files.
Then restore
on Apr 25, 2010 | Computers & Internet
Tip
How to fix error 48 in itunes
Click the View tab.
Click OK.
Then restore the ipod agin -
Lost songs on iPod Classic
First off, whenever working with new software for your stuff, best to bak up your tunes......HOWEVER....all is not lost....you MAY be able to recover by removing the hdd on the old computer, copy you audios....most should be there and intact, unless the virus attacked those.....so copy those files to a clean hdd, then scan it for viruses....then you should be fine...plz post back
Apr 24, 2012 | Apple iPod classic MP3 Player
Brand new 120 gig iPod will not be recognized by Windows XP Home
Does your ipod icon appear in My computer?If yes then right click on it and click on "Format".
Aug 13, 2009 | Apple iPod classic MP3 Player
Transferring songs from old library to a new one
I don't have an ipod, but do you not just connect it to your pc, open ituned, select the songs from your ipod THROUGH itunes - drag and drop them into your library and they should copy. When finished, eject your old ipod and connect the new one. Drag and drop the songs from itunes into the new iPod.
Again I'm not sure if this is correct, but this is how most things function in itunes. If not, someone correct me.
Dec 27, 2008 | Apple iTunes
Ipod not recognized by Windows XP or Itunes
well if you have an itunes then it should work but if you had a revoius computer then um if you go to the file button at the top there will be a button that says sync songs form what ever you named your ipod and then click on that but just to warn you it mught delete the songs you hav eon your ipod alreddy but you can get a cd or usb and put it on to your old computer nad then put it on your new computer
Apr 21, 2008 | Apple iPod nano
Connecting ipod to a new laptop
You can actually (or could have) transfer the songs from your
Laptop & iPod by using you iPod like a removable
Hard Disk Drive
Here is the Apple sanctioned method:
Note: While you can use the Transfer Purchase From iPod option under the File menu to copy iTunes Store purchases from the iPod to another computer you can't transfer songs from other sources from the iPod library to iTunes
So you'll need to follow the steps below to use iPod as a hard disk to transfer music files from one computer to another. This process will require the use of iTunes 7 on all computers. Any computers running iTunes 6 or earlier will need to be updated to follow these steps.
Once you have the files transferred, you'll need to authorize any iTunes Store content. If you won't be using your old computer, you'll want to deauthorize it.
Important: Windows operating systems don't recognize Mac OS-formatted disks (HFS or HFS Plus formats), so you can't use a Mac-formatted iPod to move your music to a Windows PC.
Switch the iPod to manual update and enable disk use The first thing you need to do is make sure have configured your iPod to enable disk use. To do this:
  1. Open iTunes on your old computer.
  2. Connect your iPod to your old computer and wait for it to appear in iTunes.
  3. Select your iPod in the Source pane under the Devices section to display your iPod preferences in the main library window.
  4. Click the Summary tab in the main iTunes window.
  5. Click the Manually manage music button. Changing from automatic updating to manual puts a check mark by Enable disk use. A message says:
"Disabling automatic update requires manually unmounting the iPod before each disconnect."
If you need to copy from old computer:
Copy iTunes folder to iPod To copy all your music files (including the library file that holds all your playlists and other settings) to your iPod:
  1. Quit iTunes.
  2. Locate your iPod:
    Mac OS X: On the desktop
    Windows: In My Computer
  3. Locate your iTunes folder:
    Mac OS X: /Users/username/Music
    Windows: \Documents and Settings\username\My Documents\My Music\
  4. Drag the iTunes folder to the iPod. This can take a while if you have a lot of songs.
OR
  • When the copy completes open iTunes.
  • Click on the iPod in the Source pane
  • Click the Eject button in the lower right corner of the iTunes window.
  • Disconnect the iPod from the computer when the "Do not disconnect" message no longer appears on the iPod screen.
Now:
Copy music to new computer To copy all your music files (including the library file that holds all your playlists and other settings) to your new computer:
  1. Locate your Music folder (Mac OS X) or your My Music folder (Windows) on your new computer:
  2. Drag the iTunes folder in this location out to the desktop. 300173_10.gifFrom the My Music folder to the Desktop on your new PC
  • Locate the iPod on the new computer:
  • Mac OS X: On the desktop.
  • Windows: In My Computer.
  • Double-click on the iPod to open it.
  • Drag the iTunes folder from the iPod to the Music folder (Mac OS X) or My Music Folder (Windows) on your new computer. This can take a while if you have a lot of songs.
  • Open iTunes
    There you go. All your music, playlists, and other information like play counts and ratings have all been moved from your old computer to your new one.
If that doesn't cover it fully..... wow!
Feb 12, 2008 | Apple iPod nano
Ipod mp3 problem
Did you use iTunes to transfer the songs? If you used Windows Media Player, that won't work, at least for me. To download iTunes, go to apple.com. If you think the songs are on the iPod, connect it to your computer and search it through My Computer. Hope that works.
Jan 19, 2008 | Apple iPod nano
Can I syncronize my ipod to two different computers?
Hey Smurf, you would probably lose it if you sync both machines. but the way to do it is connect the ipod, go into my computer and into the removeable drive for the ipod go into the music directory and copy all the music you want to add to the ipod into that folder then go to other pc and do the same should work ok.. All the best John
Mar 06, 2007 | Microsoft Windows XP Professional for PC
Apple iPod MA446LL/A MP3 Player Logo
127 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
