Unlocking laptop region code
Once I've used the limit of times I can change the region code on my laptop, is there a way to unlock it and continue to play DVDs from different regions?
  • softnov Dec 15, 2008
    same problem with my laptop.
    My system has locked the rigion code changing option. I'm staying in the USA and the last selected option was Region 3, so,.none dvds are working. Any help is greatly apreciated
Samsung laptop dvd unlock codes
You have probably used up all your region changes. These are limited for copyright reasons.
Download Anydvd from Slysoft.com
This will run your dvds as "region free"
Burn them with Dvdshrink
Mar 03, 2014 | Computers & Internet
Unlock region code
You will need to contact www.acer.com and talk to customer support and possibily the technical department to see if a solution can be offered.
Jul 28, 2012 | Acer Aspire 5742 Notebook
I need to unlock a Toshiba DVD player/VCR Combo SDV395 to view DVDs' purchased in Francs
You can change the Region Code of you DVD player but be aware that you have a limited number of changes, then the DVD player will be stuck to a certain region.
Search in the Options menu and change the region code to one printed on the french dvd case. To watch DVDs from your region again you have to change the region once more. Watch for changes left.
Nov 02, 2010 | Toshiba SDV395 DVD Player/VCR
I have a laptop that only plays region 2 dvds where can i get a code to unlock to play all regions
if your useing vista press the start button go into control panel select classic view ,then select device manager, find your dvd player click on it select dvd region pick the one you want but you can only change it a limited number of times
Feb 02, 2010 | Compaq Presario C700T Notebook
Unlock code for dvd drive for a Compaq Presario V2000
You can only change the region code 4 times and then it locks onto that region. There are firmware upgrades for various model DVDs on the Internet that makes the DVD drive region free, but if you make a mistake in upgrading the firmware or installing the wrong firmware version then the DVD drive is turned into a piece of junk.
The best way to solve your problem is to install software that defeats the region code so you can play DVDs from any region.
I use a region free program fronm DVD Idle, it is not very expensive and there are other similar programs on the Internet. Use Google to search for them.
Have a look at www.dvdidle.com
Jul 18, 2009 | HP Compaq Presario V2000 Notebook
Unlock code for DVD player
when u insert disc log out of  dvd player,,, go to mac hd and click on the disc u inserted,,,click n drag the video_ts folder on to desktop wait for import,,,,once done take out the disc,,,now click n drag the video_ts folder onto the dvd player icon...
Mar 03, 2009 | Apple iBook G4 Mac Notebook
Need to unlock laptop DVD
You can change the region code for your DVD player but not more than 4 times.
There are firnware updates to change DVDs to region free, if you are not carefull you can screw up your DVD drive.
Suggest you install a program to allow you to play any DVDs regardless of which region the DVDs were created for.
Go to www.dvdidle.com for their Region-Free program
Nov 15, 2008 | Computers & Internet
Region code unlock
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} What do you mean region code?
Sep 30, 2008 | Computers & Internet
Hi i want to unlock my laptop to any region, can you help
PC DVD drives can have the region code changed 5 times only.
Whatever region you set it to on the last available change will be the units permanent region from then on!!!
Any hardware modification to the unit to 'unlock' it is a violation of many countries laws and absolutely unlawful in the U.S..
The region codes are there to protect the copyrights of the media producers and ensure the units proper operation with inserted media.
Jan 05, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
889 people viewed this question
David Payne
David Payne
