On Off Switch for Gateway 7322
It seems like the On Off (power) switch is broken. Is there a way to fix it or do we have to replace the BEZEL ?
Where can I order this part?
  • jegeek Dec 23, 2008
    I guess I don't quite understand "use a pointing object" to turn the machine on and off!?!?
    It seems the machine will turn on but when the power button is depressed, it won't turn it off. The button is loose. Where can a person get instructions to remove the case and repair the switch?
Under the computer there are many screws. but the two under the screen area (on the bottom of the laptop) that are on the inside (not the outside edge) of the laptop hold down the bezel with the power button. once these are out, slip a screwdriver or butterknife under the bezel from the gap between the keyboard/bezel. gently pry up and it will pop out. MAKE SURE the screen is lying flat because the parts of the bezel that cover the screen hinges go behind that area.
Posted on Apr 28, 2009
    Sergeant:
    Champion:
  • 271 Answers
For temporary useyou can use a pointing object to switch it on...but for repair you need to call Gateway...
Posted on Sep 06, 2008
How do I actually replace the power switch?
Darlene,
Most Power Switches on PCs are located behind the front bezel of the unit. They are typically a micro-switch that can be purchased at your local Radio Shack if you choose to do it yourself.
Best bet is to have the switch examined by a local Repair Shop or IT Technician you trust. It has been my experience that typically the button hardware around the switch can end up broken as well.
I hope this helps.
Jun 22, 2014 | Gateway E-6610D PC Desktop
Dell unstick power button on PC desktop
It sounds like either the push button assembly is broken on the front bezel cover, or the power switch is broken. Follow these steps to take the covers off.
Front Bezel: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/bezel.htm#wp1181855
Side access cover: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/cover_re.htm#wp1193123
Now look for either a broken piece on the bezel push button assembly or a broken power switch inside the computer case.
Dec 02, 2012 | Dell Inspiron 620 ST Desktop Computer...
Replace power button gateway sx 2311
Computer unplugged from power, FOLLOW Anti-Static Precautions.
1) Remove the Side Panel.
Viewing the computer from the Front; the Right Side Panel removes. Remove screw, pull Side Panel to the rear of the computer.
http://www.newegg.com/Product/Product.aspx?Item=N82E16883113140
Click on the large main photo.
There are 9 smaller views shown. 3 across, and 3 rows.
Bottom row, click on the photo in the Middle.
Shows Rear view of computer.
Along the back edge of the Side Panel, is a finger pull handle formed out of the Side Panel. There also looks to be two screws. One above the pull handle, one down towards the bottom.
2) Remove the Front Bezel.
Click on the Middle row/middle photo.
Also look at Middle row, 3rd photo. (Photo all the way to right)
There are 3 Black tab locks, formed out of the plastic of the Front Bezel. One towards the Top, one in the Middle, and one towards the Bottom.
If memory serves these tabs are gently pulled to the outside, to release the Front Bezel. Ease the Top tab out a little, and Middle tab.
Start easing the Front Bezel away from the metal framework, of the computer case, a little. Then release the Bottom tab.
Front Bezel should swing, and then come off.
Not your Gateway model of computer case, but this Gateway model shows the plastic Tabs to release,
http://support.gateway.com/s/CASES/3501975/3501975faq6.shtml
The Power On Button is an assembly. The plastic housing of the Power On Button assembly, has a Power On switch inside.
I gently heat the plastic with a hair dryer, moving the hair dryer back, and forth at it.
Once the tabs of the plastic, of the Power On Button assembly, is softened; then I remove the Power On switch.
I have found this ATX power on switch, fits a LOT of desktop computers,
http://www.directron.com/atxswitch.html
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 19, 2012 | Computers & Internet
My power button on my Gateway ML6232 is loose
Keyboard/Hinge Cover with Power Button Bezel,
http://www.laptopswer.net/products.php/GATEWAY_ML6000-MT6000_POWER-BUTTON_3CMA7KBTA07/cPath,1_97_102/language,en_US/osCsid,8d147ed2c28ef93651edc40940d868e7
The Power On switch is not part of this small cover. The Power On button that you see, is merely a little button cover. The actual switch is under it, and mounted to the laptop.
[ The Power On switch is a Momentary Contact Switch.
Much like this example of an ATX power on switch,
http://www.directron.com/atxswitch.html ]
Removal and Replacement of the Hinge Cover with Power On bezel:
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery.
2) This strip cover pops up. It has small plastic protrusions, or tabs molded on the outside edges.
These tabs snap into place in the Palm Rest Cover.
I use a small flat tip Jewelers screwdriver, and ease up on the end opposite of the Power On button. Then carefully go along the edges.
Replacement is to just line it up, and snap back into place.
Regards,
joecoolvette
Jan 14, 2012 | Computers & Internet
Compaq Presario s3310cl starts when hooking in power plug and will not shutoff using power button. Just started doing this today. Someone said to unhook everything and hold power button in for 20 seconds...
The On/Off switch is mounted inside of the Case Front Bezel. It is
very unlikely that it is broken. The problem is the front bezel
plastic switch (which is not really the switch) is more like a cap or a
knob that comes in contact with the actual switch is somehow broken.
You can remove the front bezel to see I am talking about.
Manually push On/push Off on the actual switch and your system will turn
On and Off like it should.
Jul 17, 2011 | Compaq Presario S3310CL (DF246AR#ABA) PC...
How do i replace the switch on my system
Dear sir,
Welcome to Fixya
No worry ! I will help you!
According to you, your PC switch is faulty.I am right?
Before replacing switch,you have to confirm the problem is from switch side,or from any other side. To confirm this, remove side cover of your PC cabinet,search for front panel connections of mother board,check for loose contacts.If it is correct,remove power button jack from the board.Take one plat head screwdriver, short +ve and -ve ends of MBD frontpanel power ON switch terminals.If your PC starts normally, PC switch is faulty,you have to replace switch.If PC fails to switch on problem is not from switch side.
Steps To Replace PC power ON switch.
Remove both side covers of cabinet then,remove front glossy panel which is having power on switch. After removing glossy front panel,open the lock of power ON switch,then replace it with new switch.
I think it helps
If you have any problem regarding this issue leave a comment. We are happy to assist you,
Have a Nice Day!
Mar 27, 2010 | Gateway GT4022 PC Desktop
Gateway M520x Keyboard bezel power on/off broken.
Ebay is where I get all my parts, there are literally hundreds of stores that have used and salvaged parts, I have visited many of them and save them to my favorite sellers list. Then, even if something isn't listed in Ebay doesn't mean they don't have it in the their inventory. You can search each individual store and you do not have to go through ebay to buy something, Ebay is just good to find the stores to do business with.
Oct 08, 2009 | Computers & Internet
I have a Gateway 7322 laptop. I'm trying to hook
Press the Fn key down, hold it down, then press the F2 key.
Here is the download page for the Gateway Notebook User Guide,
http://support.gateway.com/s/Mobile/Gateway/7305GZ/4429ul.shtml
Aug 05, 2009 | Dell Inspiron 1525 Laptop
Replacing Power Button Circuit Card on Gateway W730 K8X Laptop
The instructions for replacing the keyboard include the cover you have to remove to replace the power button pcb. The power button pcb is attached to the bottom of the bezel that covers the hinges/button array. In a nutshell you just remove the 2 screws indicated in the instructions, pry the hinge covers up a bit, then gently pry the bezel up from the bottom. remove the ribbon cable, pull back the small piece of tape, remove the three small screws holding the pcb on, and remove it from the spring clips.
Apr 11, 2009 | Gateway Computers & Internet
Gateway inverter board replacment
The inverter board is the circuit board inside the screen, with all the capacitators etc that controls the backlight. It looks like this:
http://cgi.ebay.com/GateWay-7322-7330-7340-7410-Inverter-83-120082-3000_W0QQitemZ290289050786QQcmdZViewItemQQimsxZ20090114?IMSfp=TL090114125004r29293
You can just google 'changing inverter board gateway' and see if you can find the closest guide to your model..
I found this one 4th on the list..
http://www.pcgeekdom.com/2006/02/replacing-laptops-lcd-backlight.html
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Gateway 7322GZ Notebook
Computers & Internet Logo
617 people viewed this question
David Payne
David Payne
