Question about Emerson NV-5000 GPS Receiver
My NV-5000 will not display the map program?
How can I reset the system or reload the program. When its turned on.. it only displays windows CE. Thanks,
2 Suggested Answers
  • 3 Answers
SOURCE: Emerson NV 5000
It is called a transponder and I have one if you would like to buy it. defcend@hotmail.com
Posted on Feb 08, 2010
  • 3 Answers
SOURCE: map for Canada is missing
There are no maps of Canada for this gps.
0 characters
1 Points
Can you fix my polaroid mgm 0550 gps that is now a microsoft windows ce can you turn it back into a gps
Hi danpro,
You may try to reset your system (Polaroid MGM 0550) to put it back into gps. You can follow the following steps I have below:
To reset GPS.
1. Go to navigation mode.
2. Press and hold the map button below the display for 5 seconds. Then the GPS resets.
3. Verify that the GPS system is turned on. Touch Menu, Map Options, Settings, GPS Signal.
Hope it helps.
Thank you for using Fixya.
Mar 25, 2011 | GPS Devices
Screen is all white. How can I fix? Reset button not the answer
If you unit has been sitting in the sun you may have burned out the screen or th overheated the ROM tha contains the Windows CE operating system. The only real solution to this problem is to send the unit to Nextar for either a repair by swapping out the ROM or get into their exchange program and get another unit with an updated map.
Windows CE Core 5 is the operating system for most portable CPU controlled units. GPS units included.
May 04, 2010 | Nextar X3-08 Car GPS Receiver
I got files from internet to update 2009 map for my gps, but I don't know how to get them into the gps.
1. Download the SONYNAVU_U73T_3.2.CN.BIN file to a temporary or download directory.
2. Connect your nav-u personal navigation device to the computer using the supplied USB cable.
3. Power on your nav-u personal navigation device and wait until the "Connect to PC" message is displayed on the nav-u screen.
4. Start the nav-u Tool software on the computer.
5. At the "nav-u tool" window, click "Upgrade System".
6. On the right side of the Upgrade Screen, verify that the target version is 3.00.
7. On the left side of the Upgrade Screen, click the "Browse" button, and go to the directory where the SONYNAVU_U73T_3.2.CN.BIN file was downloaded and then click "OK".
8. In the "Name" box, click to select "3.02 cn NV-U73T" update, and then click the button.
9. After the update file is transferred to the nav-u device a "Transferring Upgrade file completed." message is displayed on the computer.
10. After the system software update is complete, the nav-u device will automatically shut down and restart.
Mar 18, 2010 | Sony NV-U73T GPS Receiver
InVion 4v106 not booting up, Alturion GPS error message!
It is not a matter of just copying the GPs map program to the card. You have somehow deleted the Invion Formatting back to Windows CE.
Special programs are used to get the invion program written into WinCE and then to apply the Icons specific to your GPS like PHOTOS and VIDEO etc.
These programs are installed using the reset and on buttons to get them to boot much like haveing a CD boot up other than the HDD The process of reinstating these to get the maps on and working is about 45 minutes and then the maps can be loaded. At $120 an hour the $40 fee is cheap, so if you want your GPS to work i would take up the offer
Please rate our help++++Thanks for using FIXYA
Sep 25, 2009 | InVion 4v1 GPS Receiver
NUVI 260 lethargic, navigation guidance and map take 15-20 minute
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good explanation you gave. More than most do.
Make sure you have the latest nuvi "Firmware"
then update the maps. I would start with making sure you have the latest WebUpdater on your computer before you proceed with any updates.
If a nuvi 200 is has an older version of system software glitches may occur. The device may be missing letters or have jumbled letters or displaying duplicate letters or strange symbols on the address screen. To correct this you will need to update the system software of your nuvi. You can easily do this by using Garmin’s WebUpdater program:
  1. Click the following link to download the WebUpdater program: http://www.garmin.com/products/webupdater/howtoinstall.jsp
  2. Follow the on screen prompts from the website
  3. Choose RUN/OPEN
  4. Follow the on screen prompts
After the program has been installed it should run automatically. If it does not please use the steps below.
To run WebUpdater:
  1. From the Start menu, click All Programs and find the Garmin folder
  2. Click WebUpdater
  3. Connect your nuvi to an available USB port on your computer
  4. To search for an available update, choose NEXT
  5. As the program automatically finds updates, choose NEXT to load the update. Once the update is complete, you can search for other updates such as voice languages, Bluetooth, and Traffic Receiver.
  6. Disconnect the unit to ensure it powers on.
Take your unit outdoors and keep it in a stationary position with an open sky view until it reacquires satellites.
Aug 22, 2009 | Garmin nuvi 260W GPS Receiver
Sony Sat Nav NV-U53G, display works perfectly but the touch screen stops working without any reason.how much is only touch screen
nav u 82
i update to europe germany after updating it the map does not show on the screen i have reset it sevral time and still the same problem
Jun 13, 2009 | Sony NV-U53G GPS Receiver
Etrex vista will not display any map
I had the same problem for months. i don't know what part of this worked or if it was a fluke that it finally worked. I downloaded the newer firmware for the garmin and installed it ( http://www8.garmin.com/products/webupdater/ ) then tried adding maps, that didn't work, then tried 3-4 times resetting the garmin, and each time tried adding maps and it didn't work - turns out I wasn't really resetting it (I think) it appeared that the successful reset was holding down the clicker key and the pages key while starting up, and keeping them held down for a long time (15 seconds?) - there was no sign that it was resetting except a faint illumination, then when I let go of those 2 keys it went through the setup sequence. the only way I knew it had finally reset was when the page came my pointer was in the middle of the united states. I had repeatedly tried resetting before and the pointer/map page came up to where I was last at, so it hadn't really been resetting. I'm very displeased that it took 5-10 tries to get this to work and this happened on 2 units.
I reloaded the maps after it had properly reset and they actually display and are on the map list!
this is the second etrex unit ive had this problem with, and the first one was just as flaky - taking many reset events (see master and super master reset on other etrex threads at this site)
Mar 15, 2009 | Garmin eTrex Vista GPS Receiver
Emerson NV 5000
Jul 11, 2008 | Emerson NV-5000 GPS Receiver
GPS Error Message on Start Up Model GM-7-1
sounds like your firmware or sd card is corrupt, unfortunately this is common on these. I created a dvd with the map and program data to reload everything in your unit, it also updates the map data to the last version issued. you can find it in ebay by searching for finedrive 400 map...
Jun 01, 2008 | Fine Digital FineDrive 400 GPS Receiver
Map for Canada is missing
Oct 16, 2007 | Emerson NV-5000 GPS Receiver
Emerson NV-5000 GPS Receiver Logo
19 people viewed this question
Top Emerson GPS Devices Experts
yadayada.
yadayada.
Walesarumi
Walesarumi
k24674
Are you an Emerson GPS Device Expert? Answer questions, earn points and help others
