Question about HP Pavilion dv6000z Notebook
Horizontal lines on the monitor
Five horizontal lines on monitor
  • Anonymous Nov 25, 2008
    how will i fix my laptop this has horizontal lines on my display i re installed the video driver already still theres the problem is there
    Problem Solver:
  • 13 Answers
You can try connect the notebook to any external desktop monitor available and check the display. If you don't find the lines in external monitor, you can confirm that it is a LCD issue.
If you don't have any external Monitor with you, you can start the notebook and keep on tap F10. You will get BIOS Setup Utility. You can check whether the lines are present or not. If you find the same lines in BIOS setup utility screen, the defnitely we can confirm that it is a hardware issue with the notebook LCD. At that point, you can use your notebook factory warrenty and send the notebook for free mail in service.
If you don't find the lines in BIOS, then it is a software issue. Just reinstall the Video Drivers and that may resolve the issue.
Posted on Sep 09, 2008
Samsung syncmaster magic cx 715B my samsung cx715B monitor, have a multiple horizontal line.what is the solution of this?
The multiple horizontal lines are indicative of screen failure. There really is no repair, except to replace the display.
May 05, 2015 | Samsung Computers & Internet
My Dell monitor E228WFP has a horizontal line
Anonymous,
Click the link below for troubleshooting and resolving monitor issues that you may be experiencing.
Dell Monitor Support http://dell.to/1nCPtaV
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 28, 2014 | Dell E228WFP LCD Monitor
Single horizontal line
you need to replace the horizontal integrated chip (IC), but can be done by only the expert technician. and the availability of IC for monochrome monitor is very rear.
Aug 21, 2012 | Goldstar MBM-2195A Ttl Monochrome Mga...
When i switch on my system, my Crt monitor is showing horizontal lines(not perfectly horizontal). It seems that the original display is breaking down into strips of horizontal lines. I googled the problem...
I would suggest getting a new monitor as trying to fix a problem with circuitry will often create more, leave it to the professionals. Are you sure it's the monitor? it could very well be the graphics, Buy a new monitor(or use a friends) to test your computer's graphics card. If the lines appear again then you need a new graphics card. If the lines are not there its time to buy a new monitor
Jun 20, 2010 | Computers & Internet
Lines in monitor
Yes. If you're a techie, you'll need to replace the "Horizontal IC" some circuitry may be corrupted. Otherwise, my answer would be none, there's no way you can get rid of the 5 horizontal lines on the monitor.
Try degaussing the monitor.
Mar 15, 2009 | NEC MultiSync LCD1765 17" Flat Panel LCD...
My monitor give tow horizontal lines
There should be a dry joint at the vert IC with five pin.
Resolder it, then it wold be ok.
Mar 05, 2008 | Dell P793 17" CRT Monitor
Heavy white lines accross the screen
Replace it, it is going bad. I could tell you what would cause this such as bad driver IC etc. but bottom line is its five years old, you got your moneys worth out of it so bite the bullet and get a new one.
Feb 11, 2008 | Envision EN 9110 19" Flat Panel LCD...
Horizontal lines
Horizontal blur can be caused by both a bad monitor or a bad video card/Card Slot on the motherboard.
The easiest way to check this is to connect the monitor to a known good system. If the problem follows the monitor to the good system, the monitor is bad and will need replacement. If it works fine on another system the problem is the video card/slot
Jan 04, 2008 | Dell E207WFP LCD Monitor
Brown horizontal lines sporadically appearing on monitor
I had the same problem. I fixed it completely today. The horizontal lines disappeared. IT IS DEFINETLY THE DEVICE DRIVER. I confirmed my monitor model tyope (dell M783s) and downloaded the specific driver for this monitor.
I had to do these exact steps or did not work.
1) with the problem screen, disabled the display adapter under the Hardware/Device Manager settings.
2) Restart the PC
3) Boot will come up with brown lines still but the screen will low resolution of 600x800.
4) Then I installed the correct device display monitor driver onto the pc. ( you may need to scan for new hardware, then choose the directory with the new hard drive.)
If you need step by step... just reply back.
Dec 02, 2007 | Dell M781S Monitor
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
HP Pavilion dv6000z Notebook Logo
691 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
