Question about Black & Decker 22" Electric Hedge Trimmer
Taking the blade off the electric trimmer
How do i release the blade on the trimmer
2 Suggested Answers
  • 634 Answers
SOURCE: My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Posted on Jul 09, 2009
Electric hedge trimmer only hums when I turn it on. It accidently went through a metal fence. The blade is slilghtly concaved. The hedge trimmer is a black and decker tr1700. I've taken the cover...
look carefully along the teeth of the cutter blades and see if one tooth has not jumped over the opposite tooth thereby locking the blades together
a bent up edge will do the same effect
you can remove the cutter bar and then the cutter bar cams then run the motor
if it still hums , junk it
Oct 07, 2017 | Electric Garden
The trimming blades of my Shaver do not work. my hair got stuck in it. It seem the blades do not move across each other.
Assuming you have cleaned and lubed the blades, then you need to dismantle requiring a torx screwdriver.
Firstly, take off the top cover and remove the foil itself. There are two torx screws there, and another one where the power charger goes in at the bottom.
Once those 3 are removed, pull apart the main black/grey sections. There are 2 more screws holding the battery in place, remove them and the battery. Next bit is tricky - where the 2 grey 'dimples' are, gently loosen the two sections which should leave the black slider holding the trimmer and just one side of the grey outer shell. It felt to me it was going to break, but came apart without issue.
I couldn't work out how to seperate the black trimmer section here, but you can buy replacement trimmer sections so assuming it's possible somehow. From here, I cleaned, and soaked the blades with lube overnight. Then put back together again.
Feb 03, 2011 | Braun Cruzer 3 Electric Shaver
My hedge trimmer has a piece of plant caught in it and won't trim
You didn't indicate if it was gas or electric. Either way the plant has to go. if it's electric, see if you can see the fan blade on the motor. Take s small screwdriver and try and turn the motor backwards, which would open the blades. Be careful and dorn't force it and break the fan. Pay close attention on which direction will move the blade.
Jun 16, 2010 | Garden
Trimmer not working
the trimmer may be jammed with hair particles. clean the trimmer blades really good with an old toothbrush dipped in rubbing alcohol. you can also turn it on with the tip of the trimmer blade dipped in a shallow container of alcohol.
if your trimmer blade is sufficiently clean and still doesnt work, the rocker arm that moves the blade must be broken. Remington does not offer replacements for the trimmer part
Jan 16, 2010 | Remington Microflex R-842 Electric Shaver
Do I ever need to sharpen? If I do, how?
Hey i found this for you i might help. Click on the link at the bottom!!
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results. Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
Difficulty: Moderately Easy Instructions Things You'll Need
  • Work table
  • Two medium size clamps
  • Dremel tool or similar hand-held multi-purpose tool
  • Grinding wheel attachment for hand-held tool.
  • Dremel 971 (or similar) aluminum oxide grinding sharpening stone with a tip small enough to cover the flat facet of a Hedge Hog blade tooth
    • 1 Unplug the electric trimmer before trying to sharpen the teeth.
    • 2 Clamp the electric trimmer to the work table using two clamps if necessary so the Hedge Hog is firmly held down with the blade teeth accessible over the edge of the work table.
    • 3 Insert and secure grinding tip in hand-held multi-purpose tool.
    • 4 Maneuver the grinding tip so it is perpendicular to the facet of the Hedge Hog tooth.
    • 5 Sharpen teeth in one direction, being careful to try and maintain the same cutting edge angle on the sharpened tooth of no less than 35 degrees.
    • 6 Make same number of grinding passes/grind the same length of time a few seconds on each tooth.
Tips & Warnings
  • This task should take about 15 minutes.
  • Keep a light touch; too much force can break the grinding surface.
  • For best results, insert the sharpening bit slightly less than all the way into the tool.
Read more: How to Sharpen a Black and Decker Hedge Hog ' eHow.com http://www.ehow.com/how_7163131_sharpen-black-decker-hedge-hog.html#ixzz1XsAosvvl
Oct 17, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
Electric lawnmower
Need to check blade and replace.Blade is out of balance causeing vibration. If you continue to use cener shaft bearing will also wear out and cause vibration. Buy new blade and if vibration is still there return blade.Mower is not worth bearing replacement. Buy new mower.
Please take time to rate .Thanks
Mar 28, 2009 | Electric Garden
Electric Hedge trimmer will not cut
more than likely it damaged the inner gears or drive pins that make the blades reciprocate and need replaced. if you would like instructions to repair it yourself i will send you them or you can take it to a service center.
Sep 08, 2008 | Electric Hedge Trimmer, 18"
Does not run
With out seeing the trimmers it is a little difficult to tell but with process of elimination - you may want to check the blades to see if the bolts on the blades are to tight there should be very little play so the blades move freely, that wold cause it to heat up, or you may have a short in the wiring which could also cause it to heat up. For the wiring you will have to take the handle and housing apart. If you have to take it apart take your time and lay everything out in order that you take it apart so that all you have to do is go in reverse order to put it all back. Any problems or questions feel free to ask and I will gladly help.
Sep 06, 2008 | Black & Decker 22" Electric Hedge Trimmer
Black & Decker 22" Electric Hedge Trimmer Logo
136 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
