Os will not come on
Bios will boot up then screen goes black then nothing
    Scholar:
  • 94 Answers
You can try putting the bios in default factory settings.
Posted on Sep 05, 2008
Boot screen
Try these two things:
1. Go to your BIOS setting by pressing F10 immediately after you switch on your notebook, then select your HDD as your First boot drive and then save changes and exit. If it does not works then follow step 2.
2. Reinstall/freshinstall your Windows OS with a windows OS disc.
Jan 17, 2014 | Gateway NV4402u Notebook
Monitor comes up black i can see the cursor but nothing else any ideas? it boots normally but once past the boot screen its all black with just the cursor showing
Nevermind the more I thought about it, your not getting to the operating system. The PCs used to say something to the effect of 'operating system not found' after the POST if it could not find a boot device. I think that's what's happening here, you have to go into to BIOS and see if it can detect the hard drive. When the laptop boots look for a message saying 'press F1 for setup' or something along those lines... if it comes up too quick to see start hitting F1, Esc, Del keys right after the power lights comes on, BIOS is usually one of those keys. Once in BIOS look for a 'devices' type tab and search for where it reads the hard drive If there's nothing there then its your problem, and you need to get the BIOS to autodetect it. Respond if you have questions.
Jan 11, 2012 | Toshiba Satellite A215-S5818 Notebook
I have a packard bell nav50/DOT S2. I wont boot properly. Most of the time it turns on, the possessor kicks in for a bit then stop, nothing on the screen at all. Sometimes it boots with the PB BIOS...
Download and burn a copy of memtest86+ to CD and then boot from that CD and it should automatically start the test program. If you have a bad memory it will be immediately obvious on the screen.
Jul 23, 2011 | Computers & Internet
My pc boots, the the screen is completely black.
If you can see the bios screen at the boot . After that your screen is black.
The OS might be corrupted I suggest you to reinstall the OS by using the re-installation Disc.
If you are getting any beep sound then the error codes of one long beep & 2 short beep Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
If you don't see the bios screen & beeps, there might be problem with the screen or the VGA chip in the motherboard.
If so I suggest you to contact the service center near by.
I am sure this will be helpful for you.
Rate my solution
Regards
May 31, 2010 | Gateway ML3706 Notebook
Will not boot up.....black screen....shows nothing
OS is corrupt...
re-install OS
else check the boot seq in BIOS
try.....
else i will tell u how to do it in detail...
Dec 20, 2009 | Acer Aspire 5100-5033 Notebook
Black Screen after bios Load
There is nothing positive about this. You can try to load windows in "safe-mode" by holding the f8 key when you start windows. Then you can try to do a system "restore" to a date BEFORE this happened. If that doesn't work you will need to load a new operating system on your laptop. Good Luck
Aug 04, 2009 | Acer 4220-2346 Notebook
When i turn on laptop the toshiba leading innovation comes on then the screen goes black/darkblue then nothing
first you have to do is entering bios by pressing "F2" or "del" tab, check the primary bios setup is your hardrive detected or not, if it is detected then go on...
second, still from the bios, configure the boot priority, mark harddrive as the first primary booting...
if it is not work, then u have lost OS, could be infected by virus or some missing program..
in the case u have to reinstall/format your OS
Jun 28, 2009 | Toshiba Satellite Pro L300 Notebook
Gateway laptop screen is black?
This could have several causes, including malware installed on your system, but is frequently the result of some kind of hardware driver conflict. Have you recently installed any new hardware or software to your system? If so, disconnect it and try again.
The black screen is an indication that the windows os is not booting onto the system. If you have the recovery console installed, or have the cds, you can run the recovery console to troubleshoot or repair your installation of windows. This procedure is different for xp or vista, so we need to know what os you're on, as well as any error messages you see when it fails to boot.
To begin with, try tapping F8 as it boots up and see it you can get into the OS options screen, then choose Last Known good configuration to boot windows.
Here's a great article to help you troubleshoot the situation, then let us know how it goes and what comes up..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 15, 2009 | Gateway 7330GZ Notebook
Blinking white dash during boot.
Something has messed with your MBR, master boot record, which is a small sector at the beginning of your first hard drive which tells the bios which partition to boot. You'll have to use your xp or vista's installation disc to repair the system.( Choose; repair this installation of windows when prompted )
While you are in the bios check under the boot section the order of your boot devices. If you have more than 1 HD check that the one containing your OS is first.
May 08, 2009 | Toshiba Satellite A105-S4384 Notebook
Acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
