Monitor turns off after 4-5 seconds
19 in proview lcd monator, got it around a year and a half ago at wal-mart. model number pl926wbi 900w...
  • 2 more comments
  • Anonymous Sep 06, 2008
    pl1700-bk.. monitor turns off after 4-5-sec...if i unplug it.. replug : on of 4-5 sec. and off again (black sreen) whats the promb?
  • Anonymous Sep 17, 2008
    I have exactly the same problem with an XA7-17i 700P
  • Anonymous Nov 15, 2008
    Mine does the same sort of power cycling.  It makes a clicking sound from the back of the screen when it shuts off.  Sounds like something is shorting out.
  • Anonymous Feb 17, 2009
    Same problem... Worked fine until yesterday, and I've had it for a year.
  • 3 Answers
Hi every one, i hope this helps and am proud to say/or not that i am now using my philips php-19x (aka proview 900w/Mag LT916s Model 900p/ Xerox) and yes turn on the monitor 2 seconds screen goes black and the blue power light stay lit, but if you shine a torch onto the screen you can see the lcd display is working, and if you turn the power off and on the cycle starts again, like most of us we checked the web to no avail, untill yesterday. I have been playing with this monitor for 3 months on and off after a kind fellow gave me this monitor for free on uk freecycle and of course i checked all the caps on the psu/inverter pcb and more components all seemed fine checked the ccfl lamps by taking them out of the lcd panel (15 minutes to dismantle) both lamps where fine not orange, a nice bright light, and knowing that if the monitor started woking ok and the back lights did not fail it would run like this for ever until you turned the monitor off / video blanking so i was convinced that there was no fault with the psu/inverter board, and as i stated i found the solution at last (yeh) and here it is many that's to all on the bad caps forum and of course the main man -----barry wilkins-----
Re: Mag LT916s Model 900p 19" LCD dropping like flies
I have got to the bottom of this ,after I got one of scopes out (PM 97) the output of the TL 494 IC was disappearing .The IC seems to crash easily ,I think the oscillator on pins 5&6 actually stops.
I cleaned the whole board with an aerosol of PCB cleaner and heated up the PCB up with a small craft heat gun to quite hot .
I fitted a 0.01 mfd capacitor across the IC pins 12 to 7 to decouple the VSS supply ,because I felt the cause of the IC stopping could be interference based
The monitor now runs for all day with no sign of the backlights cutting out.
I found out this LCD display was made by proview.
Barry Wilkins
john r uk.
Posted on Nov 27, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 848 Answers
Monitor turns off after 4-5 seconds? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
200 003 190DTLB5 BH Xerox 860 AB0 190DTLB5 PSH Power Supply Backlight...
Posted on Feb 28, 2015
I have a proview monitor PL926WBI Model 900W
It seems to be that something gets hot inside after a few minutes of operation of the monitor. So I placed a small fan so that air flows thru the monitor and that did it. What gets hot inside , I don't know.
Oct 25, 2009 | Gateway FPD 1510 15.1" Flat Panel LCD...
I have a proview 900w and it comes on but only for a couple seconds then the backlights turn off. Does anyone know how this might be fixed?
check your signal cable from your computer or the port itself. one of those might have a problem causing the monitor to go off.
thanks
wonder
Sep 18, 2009 | Proview PL926WBi 19" LCD Monitor
Computer Monitor Goes Blank
Pink tink = bad LCD Inverter (aka backlight) thats what you will need to replace :)
Jun 26, 2009 | Proview PL926WBi 19" LCD Monitor
19" proview LCD monitor light and signal
How old is this thing? Mine is about 4 or 5 years old... junk it!
Mar 25, 2009 | Proview PL926WBi 19" LCD Monitor
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 900w
this prob is memory is in monitor so contact sevice engg of proview
Dec 11, 2007 | Proview PL926WBi 19" LCD Monitor
Proview 900 series black flat panel monitor
Same problem, and solution 1 given here fixed my Proview 900W. A few of the 470uF caps on the power board were oozing dielectric probably due to overheating. Hopefully the replacements will hang in there for a couple more years...
Oct 17, 2007 | Proview PL926WBi 19" LCD Monitor
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
3,008 people viewed this question
David Payne
David Payne
