Question about RCA P46920BL 46" Rear Projection Television
Rca model P46920BL
Turns self off and on, randomly starts searching for channels rolls from one channel to the next, by itself.
  • Anonymous Mar 30, 2014
    It won't find any channels when searching
  • 277 Answers
This could be a remote problem, try it while the remote it out of range/no batts if so just replace the remote. Pull the batteries out of the remote - fixed? Then: Check the switches, sometimes people clean the set and fluid drips down corrodes the hidden switches and some components near them. If not that check continuity of the switches Another thought, is if you have compact floresent lamps in the room, these can cause some IR interference that can trigger events on your remote control input. last, does anyone near you has the RCA TV? mybe other remote is effecting your TV...
Posted on Nov 15, 2005
My 65" RCA LED flat screen keeps searching for channels even after I've done this several times and i don't have cable.
When you're choosing how the TV gets channels, try using Antenna instead. It will try to search for channels again, but it will take you to the next screen if it doesn't find any channels.
Mar 24, 2015 | RCA Televison & Video
My RCA Home Theatre Television, P46920BL
Shorted Hori output Transistor.
May 01, 2010 | Televison & Video
I'm having difficulities with a RCA entertainment series television. A little while ago my T.V started going crazy. For example, Sometimes when i go to turn it on to change the channel it will say panel...
Best Way reset the set,U right it well reboot itself,before u go to sleep unplug the tv,take out the bateries to remote.Morning,plug in and put the bateris back might reset it self.
Aug 17, 2009 | RCA 32F531T 32" TV
The tv turns channel by it self
hello are you sure 1 of the channel button is not jammed in
Apr 08, 2009 | RCA R52WH73 Projection Television
Channel keeps skipping on rca t.v
Problem with channel skipping has rectified itself. I simply unplugged the set and and started over with remote intructions on signal and channel setting. The tv was also turning itself off and on, this also has ceased. Thanks, hope I don't need you later.
Nov 24, 2008 | RCA Universal Remote Control
the problem is there is engaged button there..only technician can do the job by replacing the button that is always engage.
Oct 22, 2008 | RCA 20F420T 20" TV
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Channel issue
Do you have a lot loose connection inside tunner. Need be re solder. Do this and TV will be ready!!.
Apr 17, 2008 | RCA F27442 27" TV
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
RCA 60" projection tv Turns on and starts flipping channels by it self
replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
Jul 27, 2007 | RCA P60921 60" Rear Projection Television
Televison & Video Logo
83 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
