Question about Linksys Wireless-G WRT54GS Router (e125894)
Hi my name is james
Hello my router is not letting me connect to the internet and everything else is perfect in the computer
can u help me
First check the  cables,then the settings, and the configuration
Posted on Sep 05, 2008
Keep getting kicked off
when sharing internet connection, it's all about sequence when turning it on... Sequence in regard to what's turned on first, second etc... Here's the solution:
1. Turn everything off... modem, router...computers etc..
2. Turn on the wireless router FIRST and let it boot up.
3. Then turn on the modem and let it cycle up...
This allows your modem to lock onto the wifi router.
4. Turn everything else back on...
You should be good to go without drop outs...
If the power goes out, simply follow this sequence...
It's all about the sequence!!
May 31, 2010 | Belkin N Wireless Router wireless router
Tip
How to Configure Belkin routers without installation CD for DSL ISPs ?
How to Configure Belkin routers without installation CD for DSL ISPs :
  • Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using an Ethernet cable.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:
Check for the internet status at the top right hand corner. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
If it is not connected then we need to configure the wired part by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next.
Step 3: HOST NAME leave it blank or you can type anything there and click on APPLY CHANGES.
Step 4: Now check for the internet status at the top right hand corner. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.
If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected. You will not be able to go online in the wired computers.
In this case you need to connect your computer directly to the modem and check whether you are able to go online. If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
The above method is applicable for DSL ISPs only.
List of famous DSL ISPs in US:
  • AT & T
  • Verizon
  • Pioneer Telephone Networks
List of famous DSL ISPs in India:
  • AirTel
  • Bsnl
  • Mtnl
  • Tata indicom
  • Reliance Telecom
Now lets configure wireless part by clicking here...
on May 09, 2010 | Computers & Internet
I have a Linksys wired router, which I have had for years and everything worked fine until a couple of days ago when I was no longer able to connect to the internet. I disconnected the router and connected...
Do this with your network setup. Power down your DSL/Cable modem first by unplugging the power. Power down the router next by unplugging the power. Power off your computer also. Now , power up the dsl/cable modem and let it resync with the ISP ...all lights green and showing activity. Next power up the Linksys router and then do a factor restore reset by pushing in the reset and holding it for a count of 5 (the front lights will go red then flash) let go of the reset as your linksys router is all set to default setttings from the factory. Now power up your computer and try the internet after it boots up. Should hook to the internet with no problems now. Now access your router menu by typing http://192.168.1.1 and hit enter. The router log in menu should now display. just click on the password tab and enter admin the default password and then change your password in the router to something hard to remember and WRITE IT DOWN! There is also great help from linksys web site on networking your home. Good luck,
Nov 10, 2009 | Computers & Internet
Vista Router Wired Connectivity
while seeing this ....please flip it over and post the model numbers on the bottom....I can tell you how to get into the router but with out the static ips from your isp wont help much.... to get into it go to INTERNET EXPLORER (not any other) and type in the address bar as follows 192.168.62.1 and hit enter in the user box that pops up put " admin or user " as user name and " admin or password" as password.....that should access the router...you might be able to assign one but im guessin you will need to contact your isp to get the correct numbers....
May 15, 2009 | Computers & Internet
Connected to the internet, but cannot browse any webpages
i think u have soem firewall isse in router also try to reset router then check .
reset switch in back side of router.pres it for 10 seconds .then it reset to defaults.
Mar 28, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Router problem
hi sir,
check your wireless router brand/model and try to take note of it. you should visit www.portforward.com, go to GUIDES then Port Forwarding Guides by Router, browse the brand and model of your router then select your application you want to run(ex. Texas Poker). It has the step by step guide how to porward port 9339.
If not in there, try to do this manually by accessing your router's web configurator, (ex. http://192.168.1.1 in internet explorer address bar). Go to portforwarding menu...just add an HTTP with named Texas Poker, also enter port number 9339 for it's port assignment.
Winsor
Sep 04, 2008 | Linksys Wireless-G Broadband Router
Hello my name is james and my mam has just purchesed sky bradband unfortentley the computer is not near the telephone line and we cannot connect the yellow enternet cabel to the machine so mam bought the...
Buying a wireless router doesn't solve the entire problem. You will have to purchase a wireless adapter for the computer itself. You will have to remove the side panel and install it internally. With this device your computer will be able to communicate with the wireless router and receive internet signals. Once this adapter is installed you will be able to search for your network signal and log into using the security features. Once connected you will be able to surf the net anywhere in the house, providing you have a strong signal coming from your router.
Good Luck
Jun 27, 2008 | Computers & Internet
No router Detected
Hello, I'm assuming that the dsl modem is connected to the Wireless router and the computer is connected to the router. Bring up a browser and enter 192.168.1.1 into the address window. This will bring up a prompt for user name and password. In username enter {admin} and if needed for password also. This will then let you into the router settings. Look for "Quick setup". Follow directions and see if that helps. If not let me know what it does and we'll go from there. Thanks
Mar 12, 2008 | Linksys Wireless-G Broadband Router
Nintendo usb connector
hi coolsoph,
Firstly, take note that Windows Vista doesn't support the Nintendo USB connector (currently there is now way of making it work on Vista, hopefully this will be resolved with the release of Vista Service Pack 1).
Secondly, and this is if you are using Windows XP as your computer operating system, try these steps to enable XP to share it's Internet connection with other computer (for ex your Wii):
1. Click Start -> Control Panel
2. In Control Panel open the Network Connections applet
3. Right-click on your active connection (will be named something like "Local Area Connection" if you use a cable to connect to your router or "Wireless Network Connection" if you use a wireless technology to connect to your router).
4. Click on Properties
5. Select the Advanced tab
6. Check the box named "Allow other network users to connect through this computer's Internet connection" in the Internet Connection Sharing area.
7. For good measure you can restart your PC after checking the box
I hope this is helpful information and thanks for using the FixYa services
Regards
Feb 12, 2008 | Computers & Internet
Connection Issue ~ D-Link DI 514
Connect to your router, then on the computer click start/run, type CMD at the >, type ipconfig /release, then ipconfig /renew this will reset all ip address from your computer through your router to your modem. this should fix the problem. BPCS
Dec 30, 2007 | D-Link DI 514 Wireless Router (DI-514)
Linksys Wireless-G WRT54GS Router (e125894) Logo
19 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
