Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
New replacement lamp ty-la 100rl not working
I have replaced several lamps for my 50" panosonic lcd. i never had a problem and always used the panosonic replacement lamp. This time I ordered the phillips replacement lamps instead. New lamp not working. Based from past experiences I still think the lamp is the problem but I dont know for sure.
  • gmariamd Oct 11, 2008
    I face the same problem.After I repalced the Phillips manifacturing lamp it give me this pulp need to replace.I can't figure out the problem.Can you help me?
  • Anonymous Oct 24, 2008
    I had the same thing happen, when I changed out the lamp with a panasonic lamp it did not light, I sent it back to panasonic and they said it worked fine for them, where to I go next?
  • 10,594 Answers
If you place order for Panasonic lamp again this time, I think you would not face this problem as in past you had no problem.
Posted on Sep 05, 2008
TY-LA 1000 loose wire
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 21, 2014 | Panasonic TY-LA1000 Projector Lamp for...
I HAVE PANASOIC PROJECTION TV PT-5OLC13 WHEN YOU TURN IT ON IT COMES ON FOR 2 MINUTES AND GOES OFF CAN ANY BODY HELP WITH THIS PROBLEM?
If you have not replaced the lamp in this television at any time, it is probably in need of replacement. Lamp # is TY-LA1000. I buy lamps on e-bay from a company called niosales, excellent quality and free shipping. There are also three fans in your television, if the small fan near the DMD module fails the tv will not start ofr stay on. I really believe the lamp is your trouble though.
http://cgi.ebay.com/Panasonic-TY-LA1000-TYLA1000-NEW-PHILIPS-LAMP-CAGE-/390092304715?pt=LH_DefaultDomain_0&hash=item5ad350314b
Jul 12, 2011 | Panasonic PT-50LC14 50" Rear Projection...
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
HI,
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Robert
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
How to reset lamp timer on pt 50L C-13
Their manual says:
After lamp replacement, you must reset the lamp
time. Refer to the instructions enclosed with the
lamp unit (Part No.: TY-LA2005).
lamp unit (Part No.: TY-LA2005)."
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC13
Aug 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I need to find cheaper bulbs/lamps, for Panasonic TY-La 1001
All of the DLP lamps made by Philips as well as by others( "OSRAM", etc).
So I am more than sure that Philips will work just fine. The problem however is that cheaper lamps got much shorter lifespan (due the fact that they was rejected by initial quality control and sent to "Grey market").
So - because free cheese exist only in mouse trap - cheapest way to watch your TV is to spend more money for expensive ORIGINAL long-lasting lamp. Sounds like paradox, isn't it?
Cheaper substitute you will find - more expensive it's going to be on the long run. Especially when you will be forced to replace them every 6-9 months.
Original lamp should last at least 2-3 years for average use.
Russ.
Apr 06, 2010 | Televison & Video
Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
Jun 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Panasonic lamp
Brian, I just helped my buddy replace his Panasonic ty-la 1000 bulb this weekend. I have to tell you that I have a complete illiteracy when it comes to electronics but we got it done in about twenty minutes and were watching it again. Looks great. We ordered the bulb from dlp lamps.com and had it in about two days. They also had super easy instructions to follow. Try it before you replace the entire TV.
Sep 07, 2008 | Panasonic TY-LA1000 Projector Lamp for...
Panasonic PT-50LC13 Television Lamp Replacement
not really, just be careful about getting finger prints on the lamp as the oils from your fingers will shorten the lifespan of the lamp.
Mar 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
