Question about Whirlpool Duet GHW9150P Front Load Washer
Control lock light stays on.
Contol Lock light stays on and I can not program or run washer. I have tried unpluging but did not work. I have looked for reset button but have not found one can you help?
  • 125 Answers
The button you need to push and hold is the cycle signal. it should be the bottom button on the far right side. push and hold until the light goes off, it most likely will take more than 3 seconds. The button your looking for should also have a small icon of a padlock .
Posted on Sep 07, 2008
    Novelist:
    Champion:
  • 261 Answers
Carefully and slowly look for a button, I dont remember which, but there is a button that duels as a child lock if held for three seconds, find this and hold for three seconds to fix:)
The lid lock light won't stop blinking.
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
The control lock light on. Control panel not working. How do I get the contol lock suspended?
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Sep 23, 2011 | Whirlpool GHW9400 Front Load Washer
Contol locked light is on washer wont run
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jun 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The contol lock red light is lit and I can't get it to work
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have an HE3t and can't get the door to open. I have tried rewashing the load that is in there, and I have set and unset the lock. What's going on?
Try unplugging the washer for 10 minutes, plugging it back in and test to see if the door will unlock. If it doesn't then you have a bad door lock mechanism or contol board or both. You usually can manually unlock the door by removing the bottom front panel, with the washer unplugged, and reaching up into the door lock mechanism. There is a tab or ring on the bottom that you pull to release the door. Open the door and look for broken plastic pieces on the door strike or in the latch on the mechanism. Usually you won't see anything. If no broken pieces then remove the top panel, washer unplugged, and find the ccu. This is the main control board located in the back center of the machine. Check for loose connections at the ccu and for broken wires. Jiggle and push the wiring connectors into the ccu to make sure they are tight. Plug washer in and test to see if it started working. We have had a lot of repairs with this ccu unit as the relays on the board have a bad weld that gives an intermittent connection, causing this repair. If the washer works by plugging these connectors in tight then put it back together and use it. If it fails again then replace the ccu. In some instances the door lock mechanism can be bad. Unfortunately there is no good test for this. To replace the lock mechanism, you remove the top panel,(washer unplugged). Open the door, remove the three screws that hold the lock mechanism to the cabinet, unplug the 3 to 4 wiring plugs from the lock mechanism and install the new assembly. Good Luck, Appliance Specialists
Jan 04, 2010 | Kenmore HE3T Washer
Control locked stays on
The following link explains how to unlock the control panel on a Whirlpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
This is a designed safety feature of the washer that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can be inadvertently locked by leaning on the control panel, or during power outages. The instructions are printed on the front panel of the washer and are also included in the owner's manual.
If these steps do not provide you with a solution, you may have a more serious problem than a simple operator intervention. Please let me know if you require additional assistance. I hope this helps you.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock light is on. Cannot get it off. cannot run washer
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Jun 17, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Control locked light come on and stay on, machine not running
take a good look and read on your control panel i don't remember which button you need to hold for 3 or 5 second to lock unlock control panel. it is also called child lock system.
May 21, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
How do you reset the control lock?
book said to hold the end of cycle signal button for three seconds or when the control locked light goes out, good luck
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet
On the far right sode of the control panel there is a unlock control reset button. Hold it for 3 seconds and the fault will clear.
Mar 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
97 people viewed this question
Dan Webster
Dan Webster
Sal De
