Question about Magic Chef CTF2125 Top Freezer Refrigerator
Defrost Problem I have a problem with the defrost unit. I have a Magic Chef side-by-side unit that was purchased in 1995. Regardless of temperature setting, the back of the side freezer unit will eventually frost up. As frost accumulates on the back wall of the freezer, inside temperatures begin to warm up. When the inside termperature approaches 50 degrees I will turn off the refrigerator and thaw out the frost on the back wall of the freezer. Once everything is thawed I turn the refrigerator back on. The freezer remains clear of frost for about 2-3 weeks then frost accumulates again. This cycle has been repeated for a couple of years and much food has gone bad. Each time I thaw the unit the water pan at the bottom of the fresh food side will fill. The pan will collect water even if all of the ice has been removed from the freezer. The fan behind the back freezer wall is working. However, a narrow 1/4" strip hangs from the bottom of the fresh food door. This could be a magnetic strip that holds the door gasket. Air flow from the freezer to fresh food side appears to enter at the bottom, is forced up along the sides of the glass shelves, and recyled to the freezer at the top where the freezer fan is located. At one point, I thought overcroweded shelves were blocking the migration of air from the bottom along the sides to the top. However, clearing the shelves did not correct the problem. I've discounted leakage of cold air through a leak in the door gasket as the problem. I speculate it just doesn't account for enought loss to be the problem, or explain the pathology of the problem. However, I can feel a bit of air flow at the bottom of the fresh food side door. Instead, I have thought the problem was with the defrost unit itself. I guess there are three major components to the defrost unit. I tried putting a circuit tester on the defrost components, but did not get results I could interpret with confidence. It seemed to suggest the heater unit was OK, but cannot say with confidence. Any thoughts on diagnostic testing would be appreciated. Thanks, Bob
  • 51 Answers
Make sure a piece of paper can be trapped between the door seal if not the seel is not tight enough. That would explain it taking so long to ice up. Another posibilty is to close to the back or side wall if you have space try to move it out just a little at a time. If it is overheating in the rear it can cause it to not operate properly.
Posted on Sep 08, 2008
Where is the defrost timer on a Magic Chef Model RB23GA-3A top freezer Refridgerator?
It is located in the mechanical space of the unit. Please review the picture.
Feb 23, 2015 | Magic Chef Refrigerators
Magic Chef fridge, freezer compartment leaks water (side by side). Can't find a drip pan anywhere on fridge.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Magic Chef Refrigerators
My brand new Magic Chef MCBR415SF Refrigerator is building up frost in both - fridge and freezer compartments. Is it normal?
it is not normal . the old saying ( frost clear .) it say's something right .. so you have a defrost problem with this unit look for heater system / defrost terminator / and the timer or what most use is adative defrost control / a pc board . that knowes what is going on .. mm hope this helps ..
Aug 17, 2010 | Magic Chef CTB1502AR Top Freezer...
Magic Chef Side by side...freezer side frosting and Refrigerator side not cooling
Your defrost timer,defrost thermostat and defrost heater need to be checked.
The heater and thermostat are inside the freezer behind the back freezer panel.
The timer is underneath the refrigerator either the left front or right rear.
Jun 25, 2010 | Magic Chef (CSD2610KRW) Top Freezer...
Magic Chef Defrost problem - need defrost heater
did you read out the heater to make sure it's bad,do you have power coming to the heater
Nov 08, 2009 | Refrigerators
Magic chef fridge, 50 - 55 degrees frost inside freezer. whats wrong and how do i fix it. no $$ for repair man. vacumed fan etc in bottom back side of fridge (was really dusty). just emptied food into...
You have one of 2 problems - 1. a bad defrost heating element; 2. a bad defrost timer. The heating element is in the freezer under the coil. The defrost time is probably in the refrigerator.
Aug 26, 2009 | Magic Chef Refrigerators
Magic chef refrig model # MCBR1000W defrost thermostat
RepairClinic.com is a fantastic online site for ordering appliance parts.
Jul 29, 2009 | Magic Chef CTB1821AR Top Freezer...
Defrost problem
If a defrost system is not working you will get, either no cool or frost build up.
Aug 07, 2017 | Magic Chef 19.6 cu. ft. / 555 liter...
Refrigerator problem
I have a Magic Chef 3.6 cu. ft. Model#mcbr3605 thats 3 years old and has stopped working. When I plug it in you hear it start then you hear a "click" and it turns off. If you leave it plugged in the compressor gets hot. Can this be fixed or is it trash ? Thanks in advance.
Sep 01, 2008 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef CTF2125 Top Freezer Refrigerator Logo
165 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
