Question about Krups GVX2-12 Electric Burr Grinder
GVX2 parts where can i order the LOWER burr for this machine> The upper one is available at krupsonline, but I can't find a source for the lower one. thanks, dave
3 Suggested Answers
  • 67 Answers
SOURCE: Krups GVX2-12 Electric Burr... Problem:
First, unlock and unscrew the upper burr carrier. Clean and check the upper burr by gently running your finger over the teeth in the cutting direction. It shoild feel moderately sharp. If it feels very blunt, look at the teeth under a good light. If you see a substantial "flat spot" at the top of the teeth, probably the burr set will need replacement.
For the bottom burr, clean carefully its teeth, and the entire area in which it is housed. Include the outlet orofice as well. You may find a lot of oily deposits within here, so just clean them off as best as possible.
When all is clean, insert the top burr holder back in place. Screw it down until both burrs touch, then back it off (say) 1/4 turn, and lock.
Put some beans in the top, and switch on. Adjust the top burr until the desired grind is obtained.
The ground coffee should feel like a coarse sand when close to the desired grind size.
Posted on Mar 14, 2008
  • 15 Answers
SOURCE: replacement of the boiler cap
Hi Gilbert,
Krups still sell some parts for this model.
If you still looking for the boiler cap I think you can find it here:
http://www.krupsonlinestore.com/product_detail.asp?T1=KRW+MS-0907815&MENU=parts&SELECT=espressomachines&SKW=PARTF872
Posted on Sep 26, 2009
Upper looper thread keeps breaking
try a new needles
check for burrs
make sure the thread is not caught anywhere
Feb 04, 2016 | Sewing Machines
How to change burrs
1 take the bell(bean container) carefully out. 2 disassemble the upper holder of burr 3 you will see now the burrs, clean good coffee remains than disassemble the burrs 4 after disassembling burrs clean good the lower and upper burr holder. 5 carefully switch on the grinder tan switch off(few seconds) during lower plate is rolling touch with marker the surface of burr holder very softly, if it is ok you will have complete circle / if it is deformed you will have incomplete circle( that you must compensate with letter tape ) after each correction you mark the burr with marker to see did you achieved perfect result. once you have lower burr in place you screw bolts in upper bur holder and assemble it back in his place.
Feb 11, 2011 | La Pavoni Jolly (PA-JL) Electric Burr...
It says to "lift the
BURRS are the metal parts that grinds the coffee. There are 2 BURRS in the grinders, The upper burr is normally the one you adjust (Fine or coarse) and the lower or closer to the motor is the one turning during the grinding process.
Jan 25, 2011 | Starbucks Barista Burr Grinder
Rocky has a tumbling (unbalanced) sensation when grinding you can feel and hear. Seems less if you back off grind # to 20 from 8. Been using 8 for a year with no problem before today.
  1. take the bell(bean container) carefully out.
  2. disassemble the upper holder of burr
  3. you will see now the burrs, clean good coffee remains than disassemble the burrs
  4. after disassembling burrs clean good the lower and upper burr holder.
  5. carefully switch on the grinder tan switch off(few seconds) during lower plate is rolling touch with marker the surface of burr holder very softly,
  • if it is ok you will have complete circle
  • if it is deformed you will have incomplete circle( that you must compensate with letter tape )under the burrs you apply the letter tape
  • after each correction you mark the burr with marker to see did you achieved perfect result. once you have lower burr in place you screw bolts in upper bur holder and assemble it back in his place.
Aug 20, 2010 | Rancilio (RAROCKYND) Grinder
GVX2-12 Electric Burr Grinder: blue power light not coming on...
Check all connections and plug then after that it is a short behind the switch and will need to be sent back to the manufacturer.
May 17, 2010 | Krups GVX2-12 Electric Burr Grinder
Fill out water
The Krups Burr Grinder GVX2 featured in the picture is not a coffee maker, per se, it only grind coffee beans to use in other coffee makers. It is a lousy machine, and I would recommend returning it or not buying it.
DO NOT PUT WATER INTO THIS MACHINE. It will cause electric shock.
Aug 24, 2008 | Krups GVX2-12 Electric Burr Grinder
Grinder is slipping.
  1. take out bean container
  2. disassemble 3 philips screws and take plastic out
  3. rotate the knob to try to get out the upper holder of burr. if it does not rotate than disasemble the knob and the gears(plastic big one is attached to upper holder of grinder, the other is together with knob.
  4. tru to rotate it manualy, with help of extra srews puted in gear holder holes.
  5. when you get it out, carefuly clean it, look for metal parts and stones(wich sometime comes with coffee)
  1. turn on the grinder and attach gently one marker to lower burr during spining. after you stop grinder, look if it is perfect circle marked in burr. if it is not than marked side is higher. you should consider getting it ok by putting adhesive paper under lower burr and check it again.
good luck and carefuly.
Aug 02, 2008 | Gaggia MDF Coffee Grinder
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Jun 08, 2008 | Brother 1034D Mechanical Sewing Machine
Rocky Calibration
  1. replacement of burrs after 500 kg grinded coffe
  2. if upper burr holder and the body of grinder does not hold stabile, teflon aplying does not help too much, it is only temporary solution. new upper bur holder would do better.
  3. before inserting upper burr holder you should check if lower burr is rotating syncronized, you should take a bit chalk and sof touch while burr rotates. after that you stop grinder and look do you have circle with same thiknes, that would give you idea where is the problem, if it is in lower burr.
Apr 07, 2008 | Rancilio (RAROCKYND) Grinder
Mar 13, 2008 | Krups GVX2-12 Electric Burr Grinder
Krups GVX2-12 Electric Burr Grinder Logo
95 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
