Question about InFocus X1 Multimedia Projector
Proector image is dim
The image is dim, but when I replaced the bulb with a good one (bright bulb) it was still dim.
When I tried the bulb in a "good" projector the image was bright but it "flickered".
I updated the "firmware" on the projector, it changed nothing.
Is it the bulb or another component? Is there such a thing as a video card on the projector?
  • 3 more comments
  • Anonymous Sep 05, 2008
    My projector shows a brown and grey line at the right side of the screen-- is this a sign of a bad bulb
  • David Laplan Oct 06, 2008
    Image is very dark but not the projector menus. Changing bulb did not change anything. Changing video source did not change anything
  • nerd1234 Oct 06, 2008
    image dim and flickers
  • dwinters857 Mar 06, 2009
    new bulb but image still dim
  • cvg2jkb Apr 03, 2009
    How did you go about upgrading the firmware? I'd like to try this to solve a problem on my projector.
  • 14 Answers
I have changed the bulb on my LG projector recently. I found the rotating colour wheel to be full of dust. Upon opening the cavity where the light is redirected and reflected onto the imager, I saw all mirrors also had a layer of dust. I don't think it was so dirty that it affected the brightness of the image, but I cleaned it anyway using an earbud. I cleaned both sides of the color wheel as well. You need to be careful in working with the optics of the projector!
Posted on Sep 14, 2008
2007 Hyosung Avitar GV 650 the headlight keeps getting bright then it dims
Hi, Oliver if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lightling coil.
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Why does my headlight go dim get bright
Headlights bright then dim ELD or
HYOSUNG Aquil GV650 Service Manual
HYOSUNG AQUILA GV650 PARTS CATALOGUE Manuals
HYOSUNG GV 650 EFI Owner Manual
Jun 13, 2017 | 2007 Hyosung Avitar GV650
Picture way too dark to watch comfortably. Have already adjust all settings to maximize brightness. Bulb was replaced late last year and says 1,000 hours have been used but projector has not prompted me...
Unfortunately dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspecting its condition. You'll notice black corrosion build up or a bubble is starting to form around the filament of the bulb if it is what's causing the dim image.
Aug 06, 2011 | Mitsubishi HC1600 Projector
The image is very dim, even on maximum brightness. We are considering replacing the bulb, but bulbs for this projector are very expensive and we suspect that since there is some image, the bulb is not the...
Yes, as bulbs age they will begin losing brightness. Most projectors have a bulb life hour clock, that measures the number of hours a bulb has been used. Usually you can pull that up within the menu of the projector. Also that particular model has what is called "Eco-Mode" and when engaged dims the bulb by 25% to cut down on power consumption.
Typical life for a lamp in that projector is:
3000 hours on Normal mode
6000 hours on Eco mode
You can expect a brightness loss of 50% when you are approaching end of a lamps life.
Mar 07, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
Both headlights went out same time . bulbs are good . fuses are good. back lights work and high beam works too. what else can it be? and is this common with these cars . 1998 acura 2.5 tl year is 1998 not...
Test the leads to the bulbs while the low beams are on and then when the brights are on. If you have good bulbs & fuses with no power on low, the problem is most likely the bright/dim switch.
Not exactly sure of the Acura layout, but the covers over the steering shaft should remove with several screws to allow access to the switch (usually the turn signals are also the bright/dim switch) Test the leads out to the headlights from the bright/dim switch, that will tell you if the switch is bad.
Airbags are closely involved with this removal/replacement, it is NOT recommended for a amatuer to undertake.
Dec 17, 2009 | 1998 Acura TL
2005 Jeep Liberty Sport. Headlights. Passenger Side is dim
TEST
remove both bulbs from the lamps but leave them on their wires switch on and see if the bulbs are still different brightness if not they the passenger side lamp housing has damaged mirror is dirty or missalined and needs adjustment. if they are different brightness then this may be a earthing problem.
Nov 13, 2009 | 2005 Jeep Grand Cherokee
Image is dim. How do I adjust brightness
You can adjust the brightness through the user menu, under the picture option. You might want to look at your bulb. It might be time to replace the lamp.
Sep 19, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Headlight one side works on bright the other side works on dim
Try swapping the headlight bulbs or buying a known good bulb and testing that way. Sounds like a shorted bulb filament issue.
Apr 05, 2009 | 2004 Oldsmobile Alero
Dim Image
Check you manual for a dual brightness control that may be activated or even stuck at low level. The manufacturers web site may have a technical help team to consult - have you tried?
Jul 16, 2007 | ASK Proxima DP6860 Plus Multimedia...
InFocus X1 Multimedia Projector Logo
2,214 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
